    • 5384
    SD... I moved to NC from there when I retired from the Navy. Lived on the border on Lemon Grove and Spring Valley though I wasn't home very much...
    • Av8er278
      • Jan 2021
      • 123
      • San Diego, Ca
      I retired three years ago from North Island NAS with 35years DOD and military time combined. I’m in Chula Vista.
        • 5384
        Thank you for your service!
        • Av8er278
          • Jan 2021
          • 123
          • San Diego, Ca
          And thank you for yours also.
          • Av8er278
            • Jan 2021
            • 123
            • San Diego, Ca
            So talked to MotionRC today and went through all kinds of testing trying this and trying that. Finally out come was when door closes on gear an when gear is retracted door opens back out off gear and gear comes up and door closes back with no problem and nothing damaged. Other than that they couldn’t figure it out either. They did make note on my account for warranty in case I have problems down the road.
            • Oachidori
              • 52
              • Bucharest, Romania
              Because the spring is coming i had some checks on my F22. I saw that when the gear is up and move the stick for the rudder the wheel inside is moving a little? Could be that a problem? Yours are the same?
              Badan Kit - Yak55M 2.8m; EF - Extra 300 2.3m; Multiplex - Funcub;Funjet Ultra2;Parkmaster;FW - F22 90-X45 Xicoy;ROBBE MISTRAL 2.0
              • Av8er278
                • Jan 2021
                • 123
                • San Diego, Ca
                No my wheel doesn’t move it work like it’s supposed to. My only problem is with the door closing on the gear.
                • gooniac33
                  The Original Gooniac
                  • Jun 2016
                  • 1047
                  My dang nose gear mount came loose AGAIN!!! Noticed that the plane was tipping for no real reason but then saw the nose gear flopping around... 🤣 Will get it secured and then get back to flying! Its such a fun plane to fly!!
                    • 8202
                    I lost count how many times I had to modify/strengthen my nose gear. It's the only pet peeve I ever had with this model...Otherwise it's a jewel.
                      Ray, I solved the problem in post 3405 above (and that was after already having fixed it once before using Hysol, and it still broke loose).
                        Gotta print the brace
                          Yes, it works a treat on the F-14, and I'm sure it will on the Raptor too. Haven't flown it again since adding.
                            • 8202
                            I would be happy to add the .STL file to the Support tab on the F-22 product pages? Just let me know (I don't recall who has the file)?
                              Yeah I think I have it on the computer at the house, ill look when I get home. I need to add it to mine since I fly off grass. Just haven't gotten to it yet
                                I did one for my friends avanti and its been solid for his plane.
                                • gooniac33
                                  • Jun 2016
                                  • 1047
                                  Sounds like I am not the only one... I will have to figure out what will work for me... simple is always best for me!
                                  • Mizer67
                                    • 374
                                    My nose gear has been solid, but I did install a 3D printed brace early on.
                                    My only gripe with the model is the main gear connecting pins. Either on grass or any bumps in the runway, they break very easily and my wings have paid the price.
                                    Understand why we have the suspension setup that is there now, but would trade it for a decent set of trailing links.
                                      I found it, heres the file for the brace I have.
                                        • 8202
                                        Thanks bud, with your permission I will add it to the support tab for the product pages...
                                          Make it so my friend.
