  • Av8er278
    • Jan 2021
    • 123
    • San Diego, Ca
    I hope I get it soon. Just emailed him last week and he said they will ship out in a couple days but still waiting.
    • gooniac33
      The Original Gooniac
      • Jun 2016
      • 1047
      Originally posted by Gmack908
      I waited almost 3 months for my Gooniac burner but it was worth the wait.
      USPS has been my main go to since it is the easiest for me. I tried to keep to the local branch but it has proven to be problematic. The whole system was really messed up in feb though which affected parts deliveries as well. Thankfully I found another smaller branch near me that isn't delayed at all and the service is much faster. It shouldn't matter where I drop off packages but I am noticing that it does now. I dropped off some packages on friday and people had them in hand by monday.... so it looks like I found a solution to my problem... FINALLY!!! I have also finally gotten ahead on the parts orders that were held up from over seas... I appreciate the patience and have told people that they are worth the wait! Glad to see you agree!
      trust me man it is just as frustrating for me as it is for you! I had a whole set of the wrong parts show up and then had a bunch of them fails during testing. The return process took so long and it messed things up big time. Remind me which person you are and I can get an updated status. I sent out 15 over the last couple days and have another 6 going tonite
      • gooniac33
        • Jun 2016
        • 1047
        now back on topic of the F-22.... I averted disaster the other day! I have been running a crazy Gooniac higher performance 6s set up in my bird for a while now. Leopard 4092 1730kv inruner with the older 12 blade individual blade fan. Plane was a total beast but had a slightly high amp draw... (150amps peak) no problem for the packs I use and I only use full throttle in bursts. Well after performing flawlessly for over 5 years the rotor finally came loose. I caught it before a flight but it now needs something new. I am thinking of either going 8s or fitting the new FMS 6s set up that just came out... 1850kv 12 blade!
        • Av8er278
          • Jan 2021
          • 123
          • San Diego, Ca
          Hi Ray I’m Art Sims my order is the F22 8 cell.
          • gooniac33
            • Jun 2016
            • 1047
            yours is on my bench right now. will have it out today and shipping info will get sent via paypal. thanks for your patience! been a roller coaster the last couple months!!
            • Av8er278
              • Jan 2021
              • 123
              • San Diego, Ca
              Thanks Ray for the update. And for those that’s ordering this product even with the delays he has had it’s still within the 6 to 8 weeks on orders. Again thanks.
              • gooniac33
                • Jun 2016
                • 1047
                You should have gotten an email from paypal with the shipping info. It is on the way to you!
                • Av8er278
                  • Jan 2021
                  • 123
                  • San Diego, Ca
                  Yes Ray I got it. Thank you so much.
                  • Big Dave
                    • Apr 2021
                    • 17
                    Hi all, I think I am going to pull the trigger and buy this jet as my first non RTF dc plane. I would like some advice on what is needed to complete for a newbie. I am thinking of getting the dx8e transmitter but would like recommendations on a good receiver for someone that knows nothing about them. Also, should I be purchasing y harness to bypass the blue box or expect it to work just fine ? I don’t have the inventory that most of you have so I want to make sure I’m not making 10 different orders to get this thing completed . Also , what is the standard battery selection ? Thanks .
                    • SanExup
                      • 912
                      • Western Wy.
                      LemonRx or Spektrum for the receiver, it's worth getting a receiver that can accept a satellite add on. You will want extensions and not just Ys. With that 8 channel you'll have more channels to separate the control surfaces, not just bypass the blue board and then essentially accomplish what the blue box is doing with the Ys. I don't have this plane but it's at the top of my list currently. And I would like to set it up as others have, with full flaperons and spoilerons, rudder brakes. But full span flaps at least requires servo extensions. Spektrum has an 8 channel receiver with as3x and safe. The forward programming features are nice. Sorry I forget what the part name is for the receiver. The 6 channel version is the ar637T.
                        I bought a pristine F-22 from a buddy...He added nav lights both top and bottom...I just freaking love how great this jet flies! And lands so buttery smooth every time.
                        • Av8er278
                          • Jan 2021
                          • 123
                          • San Diego, Ca
ID:	307210 Hey guys do I have to cut foam to make my afterburner fit? It hits the V portion and fan won’t fit. It’s about 1/2 to 3/4 inch to long. Click image for larger version
                            • 5416
                            Sure looks like it...
                            • Av8er278
                              • Jan 2021
                              • 123
                              • San Diego, Ca
                              I really don’t want to cut it and disrupt the air flow. And from the looks of it if it was cut the burner wouldn’t be as bright with it inside of the V.
                              • SanExup
                                • 912
                                • Western Wy.
                                Can you smoothly shape where you cut into a blunt V? To keep the light essentially inside the duct? And maybe use reflective tape in that area...
                                • Av8er278
                                  • Jan 2021
                                  • 123
                                  • San Diego, Ca
                                  I really don’t want to cut up my plane. And if I did the only problem with that is the very end where there are led’s would be inside only the led’s on the side would be lit and not sure if that would be bright enough for the full effect. If the light unit was shorter there wouldn’t be a problem. I wonder if the others that have this had this problem and what did they do.
                                    • 5416
                                    Yes, they cut it. Just do it. Add some aluminum tape back there to help reflections.
                                    • Gmack908
                                      • Jan 2021
                                      • 80
                                      • United States
ID:	307320Click image for larger version
                                      Yes I had to as well. I used a potato peeler.
                                      • Av8er278
                                        • Jan 2021
                                        • 123
                                        • San Diego, Ca
                                        Thanks Gmack908. Looks good guess I’ll have to do the same. Did you use aluminum tape also?
                                        • Gmack908
                                          • Jan 2021
                                          • 80
                                          • United States
                                          What’s that? Inside the exhaust cone to make it shine brighter? I did not. You can see it in broad daylight no problem. If it’s in your house or in the dark the lights so bright it makes the whole back of the fuse glow lmao
