  • Rcjunkey
    Love that RC stuff since 1990
    • May 2018
    • 23
    What is the current recommendation for drop in replacement servos for the elevators?
      • 5385
      Is there a reason you are replacing them? Many of us are 8, 10 and 12S wringing the plane out hard without issues. That said FW does have the new, slightly stronger stab servos for the MiG-29 or you could go to the Corona that Jandro recommended. I have them on the stabs of my Mig and like them.
      Corona DS238MG Digital Metal Gear Servo 4.6kg / 0.14sec / 22g (hobbyking.com)
      • Rcjunkey
        • May 2018
        • 23
        No reason in particular why I want to change them other than I have been reading a lot of posts as to the full flying stabs having a good deal of pressure against them during flight and hard maneuvers.
        • jaldendifer
          • Feb 2019
          • 14
          I’ve got approximately 50 or 60 flts on my 8cell, and I wring the heck out of it ( why it’s so much fun)! And this is no 2! Doesn’t need changing! Probably best jet FreeWing makes!
          • Rcjunkey
            • May 2018
            • 23
            Well that's good news thanks for the information!
              Agreed with the others. I have tons of flights on 12S, no issues with the stock servos.
              • gooniac33
                The Original Gooniac
                • Jun 2016
                • 1047
                Originally posted by Av8er278
                Hi I’m new to this forum and love your center burner. Where can I get one for my F-22? And is there a install video to see how it’s done. Thanks
                Sorry I haven't been on forums much...I hope we were able to connect up for the burner!
                • Av8er278
                  • Jan 2021
                  • 123
                  • San Diego, Ca
                  Hi Ray yes I sent you payment and you answered back saying you got it that I did it right. This is Art
                  • gooniac33
                    • Jun 2016
                    • 1047
                    Oh ok sweet!! Glad we connected! The F-22 is one of my all time fave birds!!
                    • Av8er278
                      • Jan 2021
                      • 123
                      • San Diego, Ca
                      I’m still working on mine. Confused on the flap to elevator mix. I use a DX9. I don’t have flap system just mix. But if I go into aircraft it’s on normal for wing type.
                      • gooniac33
                        • Jun 2016
                        • 1047
                        I have flaps set up on mine but don't use them. The plane is really good at coming in High alpha and slow...
                          • 5385
                          Set it up one aileron, one flap
                          • Av8er278
                            • Jan 2021
                            • 123
                            • San Diego, Ca
                            Ok I did that and plug in battery and flap goes to takeoff flaps. So just go back and adjust linkage again?
                            • Av8er278
                              • Jan 2021
                              • 123
                              • San Diego, Ca
                              I’ll set them up but all the other planes I have had I never had flaps so this is new to me,
                                • 5385
                                Go into the flap menu and set them up there.
                                • Mizer67
                                  • 374
                                  As Evan D mentioned, if you set the plane up as 1 Ail, 1 Flap in the Aircraft Type menu on the DX9, then in your F-22 menu you should have a Flaps selection to make where you can set up your deflections.
                                  • flyinhigh042
                                    • Dec 2018
                                    • 100
                                    My uncle just picked up the 8s F-22. So many battery options for the 8s. What are your favorites?
                                      • 5385
                                      Right now Power Hobby 5200 50c 6s and Coddar 5200 60c 2s are my favorite but batteries change all the time.
                                      • Av8er278
                                        • Jan 2021
                                        • 123
                                        • San Diego, Ca
                                        I went with two 4s 5000mah 55c with 110c burst from CHNL Hobbies. Only cause I can use 4s in my other plane.
                                        • Av8er278
                                          • Jan 2021
                                          • 123
                                          • San Diego, Ca
                                          Finally all done setting up rates and ready for flight. Is there a way to make gear come up faster?
