  • Jdcrow
    • Mar 2019
    • 193
    • Bentonville AR
    Same Great Plane..... Just a new canopy, repaint, and some Strike Eagle influence.
    2 Seat Direct replacement canopy available from Keith "Sparky" Sparks for just $7.00 at www.parkflyerplastics.com https://parkflyerplastics.com/cart/i...roducts_id=894
    While i was at it, couldnt resist adding the digital dash from StemWings. https://stemwings.com
    • Jdcrow
      • Mar 2019
      • 193
      • Bentonville AR
      More F-15E influenced refinish
      • Jdcrow
        • Mar 2019
        • 193
        • Bentonville AR
        I ended up replacing both pilots as the stock pilot (right) doesnt seem to be available from Motion as the spare part pilot listed for the F-15.
        • Capt. G
          • Jun 2022
          • 17
ID:	352292 My 16 th freewing jet , fast , stable, landings are easy, no power and 1/2 flaps
          • Capt. G
            • Jun 2022
            • 17
            Probably the best detail I've seen on a freewing e
            • Capt. G
              • Jun 2022
              • 17
              Dang phone, meant Jet!
                • 4856
                Jdcrow Great detail modifications. Diggin' the exhaust nozzles and the cockpit mods. nicely done, Sir. Best, LB
                • Capt. G
                  • Jun 2022
                  • 17
                  Little eye candy
                  • Capt. G
                    • Jun 2022
                    • 17
                    Aluminum tape
                      • 4856
                      Capt G Very nicely done, Sir. Looks authentic to me. By the way, welcome to "The Squawk". Best, LB
                      • Tommy D
                        • Jan 2023
                        • 5
                        Hi all, would love to compare my DX9 setup with someone's trusted setup, anybody willing to share the setup file please?
                          • 4856
                          TD, Welcome to Hobby Squawk, SIr. Be patient, there is great info here and another member will no doubt have an answer for you. That said, the manual setups are a good place to start, though I usually find a 'mean or average' CG suggestion from the posts of the airframe I am finishing and go from there. Hope I have helped some. Best, LB
                          • Tommy D
                            • Jan 2023
                            • 5
                            Thank you Elbee, appreciate you assistance in deed, just want to make sure I got it all set up right, although I'm not new to RC, but new }or to lazy to sign up to HSQ until now} I have spend some time on RCG since 2010. Best regards
                              • 4856
                              TD, the introduction of FreeWing's Eagle precedes my tenure here, otherwise I might have had better answers for you. It is on my 'bucket list' however. Post pics if that suits you. Always, like seeing how everyone finishes out their models, even if that is 'bone stock'. Best, LB
                              • Capt. G
                                • Jun 2022
                                • 17
ID:	368834 C G by book ,rates by book but I do 75% on ailerons for low, elevator neutral in pic top dot recommended bottom dot after flight trim. ( Notice seam , bottom dot is between seam and fuse bottom) half flaps elevator mix is zero, full is 10% . flairs great. I land power off half flaps , my style.
                                • Tommy D
                                  • Jan 2023
                                  • 5
                                  Perfect, all I needed Capt.G. Awesome thx a lot.!
                                  • Tommy D
                                    • Jan 2023
                                    • 5
ID:	369036 Hi there, is there a good acrylic grey color match to use with the airbrush? tamiya, hobby color, mr.paint... or so? thank you
                                      • 4856
                                      TD, that's a good question. To match the OEM colors, I go to Home Depot with a panel from the model and have it color matched in exterior latex sample size jar. But to airbrush that is difficult, ask me
                                      how I know.. Hang in there, someone might have a answer for you; otherwise the HD Behr paint is a plan B. Best, LB
                                      • Tommy D
                                        • Jan 2023
                                        • 5
                                        This mix worked out in order to make the covers to look more scale
                                        • The43rdHammer
                                          Smithy
                                          • Aug 2019
                                          • 118
                                          • South East England
                                          Hi all, I just pushed the button on the F-15C and am going 8S... I thought screw it , why not! Could one of you kind gentlemen direct me to a photo of the battery install on 8S for me? I'm planning on using 2x 4S 4000 unless somebody tells me differently?
