  • vicentel
    I finished weathering my F-14 as well as refinishing the cockpit with 3D printed pilots, ejection seats, consoles, and yokes. Missiles are 3D printed and installed AIM 7, AIM9 and AIM 54 (phoenix). I flew it in this refinished configuration but had issues with the landing gear deploying during the landing. I managed to get her down with minimal damage (Praise God!) and its already been repaired. I did figure out the landing gear issue. I will try to get some flight video as soon as I can. The video demo's the wing-sweep, all 3 positions!
    Thanks
    Vic
    Originally posted by Nfun
    Got my NSAWC blue #20 f-14a repaint finished, just waiting on decals from callie!
    NF, beautiful work, Sir. Bravo Zulu. Best, LB
  • nuts-n-volts
    Sweet! Nice job!
  • Nfun
  • jasmith41
    Originally posted by kallend
    Google found this in about 4 seconds:
    https://www.rc-castle.com/index.php?...roduct_id=9009
    thanks... only nominally diff than the v2 in thrust... or at least that's what i'm seeing. i bought a few of these from an ebay vendor and put one in the EFL F18 Blue Angels and man does it sound good and really rips... very turbine-like sound...
  • kallend
    Originally posted by jasmith41
    Where can these v3 FMS fans be purchased from...?
     - With Up-Grade 3665 2000Kv Motor To Provide More Thrust And Less Drawing Current.- Rotor Blade Material : Nylon Composite With Fiber- Outer Diameter: 84mm- Length: 67.0mm- Weight: 320g- Rotor: 80mm , 12 Blade- Motor:: 3665 2000Kv Inru
  • jasmith41
    Maiden +2 done on my second F-14. This one with the MiG-29 fans and ESCs. Flawless flights. Had to wear my USS Constellation T shirt with my retirement from the US Navy on the back. When I retired from the Navy in '96 I was ships company and my ceremony was held on the Flight Deck of Connie.
    Click image for larger version  Name:	87EA5509-8ECC-4F77-91AC-C17B5FCE1B57.jpeg Views:	1 Size:	97.4 KB ID:	349041Click image for larger version  Name:	F948E462-866F-4786-9A91-F93A5159CE6F.jpeg Views:	1 Size:	113.2 KB ID:	349042Click image for larger version  Name:	9A2A0A50-974F-4F0B-A914-C16DA8896D18.jpeg Views:	1 Size:	108.1 KB ID:	349043Click image for larger version  Name:	62587CCC-C7BA-41AB-9C4B-548633F10F93.jpeg Views:	1 Size:	96.0 KB ID:	349044Click image for larger version  Name:	C0AF5200-D4CD-4D88-A320-C832F7725472.jpeg Views:	1 Size:	129.3 KB ID:	349045Click image for larger version  Name:	41D8BDDE-3BC4-497B-97EE-B851EDCA9BC5.jpeg Views:	1 Size:	130.2 KB ID:	349046Click image for larger version  Name:	6D4BA36E-129D-40FE-BFFF-81158FF39C8D.jpeg Views:	1 Size:	112.6 KB ID:	349047
  • Big12fan
    Originally posted by vicentel
    I'm running the stock MiG-29 power system (EDFs and 100amp ESCs) in my F-14. Also, I'm running the FMS 80mm V3 12 Blade Pro 3665 2000Kv EDF For 6S in my MiG-29 and they give me a lot of static thrust. I was thinking of swapping out what I currently have in my F-14 for the new FMS 80mm V3 12 Blade Pro 3665 2000Kv EDFs.I would just have to modify the mounting holes in the F-14 since they're in different locations on the EDF.
    I do like those. I have the V3 in my Rafale.
  • vicentel
    I have the FMS 2100s in mine and it's much livelier than the stock setup.
  • kallend
    Originally posted by Big12fan
    Hmmm, yeah, cause I was thinking of putting those in mine since I have 2 sitting around. I love how the 2100’s awakened my eflite and FMS 80 mm jets.
  • Big12fan
    That post was 4 months ago and we never heard the outcome. I'm **guessing** the experiment was not a great success.
  • kallend
    How come you went away from the 2100 kv set up?
  • Big12fan
    Originally posted by Gvasiloff
    Just installed a new power system and landing gear. Out with the FMS 2100kv units and in with some Jetfan V3 fans and HET 700-68-2250kv motors. Controlling them are Hobbywing 120a ESCs with 150a burst capacity. These motors are a combined ~350g heavier than the FMS units. I'm coming out a touch tail heavy even with my heaviest batteries (~800g/ea) ALL the way forward! I know it can be flown like this though.
    I also installed the E-Flite 25-46 90 degree retracts with the trunnions drilled out to accept the 5.1mm pins from the stock struts. I added Robart 2.75" rubber wheels and RC Geek 3D printed hub caps. They look amazing!
  • vicentel
    what main struts did you use on this?
    These are the F4U 60-120 Eflite struts, E-flite - EFLG520F4U (https://www.horizonhobby.com/product...FLG520F4U.html) mated to the Eflite 25-45 90deg. retract set.
    Once I maidened my F-14 I decided to refinish it with the Wolfpack VF-1 livery. it's still a work-in-progress but I thought I'd share where I am in my build.
    VC, nicely done, beautiful repaint. Diggin' all the 3DP parts and your choice of livery. Bravo Zulu, Sir. Best, LB
  • Nfun
    Once I maidened my F-14 I decided to refinish it with the Wolfpack VF-1 livery. I 3D printed the ordinance (2xSidewinders, 2xAIMs, 4xPhoenix). I redid the undercarriage using a 1.5mm ABS plate with naca inlets. I fashioned anther set of missile rails for the additional 2 Phoenix missiles. The Wolfpack graphics were sourced from Callie Graphics. it's still a work-in-progress but I thought I'd share where I am in my build.
    Cheers,
    Vic
  • vicentel
    Cheers,
    Vic
  • kallend
    My club did a static show at Daley Plaza in downtown Chicago today, right in front of the huge Picasso sculpture. The F-14 got a lot of attention, especially when I taxied it around the plaza and lit up the "afterburners". Click image for larger version
  • primodus22
    All stock on two RCBattery 6s 5000.
