  • Carlbrainiac
    • May 2019
    • 242
    not sure how it flies yet as I've only just installed it. Will let you know when I fly it hopefully this Friday/Sunday
      • 2700
      Originally posted by Elbee
      I do not see the 3672-1900kV inrunner motor with 9-blade fan "Upgrade" offering for the MotionRC F-18C on their website. Is the OEM Fan the same so the only change out is the inrunner motor? I have the original "Basic Gray" version. Inquisitively, LB
      Elbee it's not listed on Motion's website under "upgrades" for the base grey version. It is listed as a "spare part" under the F-18 BA version or under the power systems, EDF, 90 mm 3672-1900Kv Inrunner (no photo yet) for $89.99, but not yet in stock. This is the upgraded inrunner they put in the revised Blue Angel version and the fan itself is not yet available as a stand alone. I asked Alpha about that upgraded fan several months ago and he let me know that it wouldn't be available for purchase separately until mid-summer, so it will probably get here relatively soon.
      Or you could just buy the F-18 Blue Angel, take the fan out, and send me the rest! That sounds like a good plan, no? :face_with_hand_over
        • 4851
        Elbee it's not listed on Motion's website under "upgrades" for the base grey version. It is listed as a "spare part" under the F-18 BA version...you could just buy the F-18 Blue Angel, take the fan out, and send me the rest! That sounds like a good plan, no? :face_with_hand_over
        Hugh, I suppose the BA would require some special attention, too, but you did an outstanding job on your Canook Flight Team, so maybe no mods. I have put in a 'Notification' for the "Spare Part" so we'll see how long that might take. We're in FL for another few days after we get over to St; Augustine for the Fourth. I haven't been home for almost a month, so I am in serious building withdrawal. Best, LB
          • 2700
          Elbee you can also install the 4068-1835 Kv 12 blade inrunner instead. I put that fan in my F-16 and it's sweeeeeet! A couple other guys have posted here that they installed this in the F-18, much more power and speed and the sound is so much better than a 9 blade, although the cost is a few dollars more at $158. I'll be upgrading my F-18 with that fan one of these days, but want to get some more flights in with the stock, for now. Even with that fan, it's still got more than enough speed for this "little old lady from Pasadena" and more than enough juice to get off grass. I'm flying it on a RT 6250 and get 4:30-5:00, so not in a rush, but I do have it (the 12 blade) on my wishlist (along with way too many other things)!
          How are you enjoying the Florida heat :hot_face:, we've been setting records for the last 3 days in Miami but I assume it's not that bad up in northern Florida. BTW, if you haven't already, try out Columbia Restaurant while you're there.
            Elbee commented
            Editing a comment
            Love the heat. I like the idea of the your upgrade suggestion. After watching some vids and listening to the 12 blade EDFs, I like the 'whoosh' along with the 'whine'. I have a few $USD burning a hole in my pocket and Alpha hasn't hinted at anything new from Flightline or Freewing in the queue, so I think I'll go ahead with that improvement. Columbia Restaurant, is that in St. Augustine, then? Funny you should mention the weather as it looks like FL is going to be wet for awhile, LOL So we're thinking about a change of plans and heading back home early ??? We'll see. Thanks for the info. You're one of the "Good Guys", Hugh. Best, Steve
          • 4851
          Hugh Wiedman, Do you think I would need to change out the ESC? I don't recall the ratings of the OEM ESC in the kit box, but I will look those up. Best, LB
          Quick note Hugh, We're going to St Augs in spite of the weather forecast and Happy Fourth to you and yours.
            • 2700
            No, the stock Freewing 130 Amp with 8 amp BEC should be fine. I put that 12 blade inrunner in my F-16, but bought the ARF version without an ESC. I then got the Gecko 144 Amp ESC, however, I had major problems with it. The timing was off and whenever I cut the throttle to 0, it wouldn't restart. Motion told me I needed to get some programming cable and adjust the timing and that was a long standing issue with the Gecko, but I didn't want to go through that, so returned it with a refund and put the Castle Phoenix 130 Amp in with a separate 10 amp UBEC. I generally use Castle ESC's unless I'm using the stock ones. With that being said, the Freewing 130 Amp would have worked just fine if I started with that. In power testing on that fan using a GT Power meter, the highest amps drawn where 117.5 amps on a fully charged Roaring Top 70 C battery on the bench going from "0-full throttle". Of course that would be less if the fan had any air entering the intake ducts from actual air speed, so let's say 120 amps is likely the highest draw you will encounter.
              Elbee commented
              Editing a comment
              Again, Thank you. Steve
          • thisguy65
            • 509
            Thanks guys for the support, those that order the battery tray/ NG reinforcement they are all out and on their way to you!
            Planes
            • ColtPilot
              Hobby Squawk Advanced Pilot
              • Jun 2015
              • 538
              • Saint Clair Shores, Mi
              Just ordered the BA HP version PNP. Someone mentioned that the elevator needs attention as in upgraded. I'm trying to find the thread on that.
              • ColtPilot
                • Jun 2015
                • 538
                Aros, Sorry a bit off topic, but I am going to have to buy a video camera or an SLR that shoots decent video. I remember a thread started awhile back talking about cameras, video cameras and how to shoot better pictures/vids. Has there been much activity there lately? Need to check it out myself. Between MotionRC and Callie Graphics running the occasional photo contest, I hope that forum gets more attention. Is the only way to post videos on Hobby Squawk through uutooob? Best, LB
                I'm using a Canon Vixia HD HF 20 video camera with Dolby Sound. My SLR is a Canon Rebel T5 with a 70mm-300mm lens. What I could afford. YouTube Mrtcoltpilot.
                • ColtPilot
                  • Jun 2015
                  • 538
                    • 5401
                    There is a lot of discussion on the forums, probably more on the RC Groups forum and it resulted in a bulletin on the motion site under the support tab for the F-18.
                    https://www.motionrc.com/pages/produ...f-a-18c-hornet
                    Newer kits should be good. Many replaced the servos but to be honest mine was in the first batch and has been good now for about 130 flights.
                    • Rcfiddy1
                      Professional Crash Test Dummy
                      • Aug 2015
                      • 186
                      • Manalapan, NJ
                      Finally got around to upgrading the hornet to the new 1835kv. Flies great and hit top speed of 128mph. Forward to 9:20
                        • 2700
                        https://youtu.be/KVjxtRbMTeI
                        Rcfiddy1 excellent flight, gotta love the sound of the 12 blade, I have that fan in my F-16 and it performs great. I hear that fan is a drop in fit for the F-18 (it was for the F-16), no? Assume you stayed with the Freewing 130 amp ESC. What battery are you using and what kind of flight time are you now getting.
                        • Rcfiddy1
                          • Aug 2015
                          • 186
                          • Manalapan, NJ
                          It was a drop in. I did keep the 130a esc. This flight was on a RT5000 landed with 3.87 at 3mins. I have a 6000 I am going to try tomorrow. I ordered the last 1835 from motion Today for my f16. Heard so many reports that the stock power was lacking punch. Now I won’t worry too much with this motor.
                            • 2700
                            Rcfiddy1 thanks for the update, appreciate it. I haven't felt that the stock outrunner really lacked punch, but since I can't compare it to the inrunner you are using until I upgrade it, I can't really say. Sounds like you're very satisfied with it though. I'm using the RT 6250 35C on the stock 9 blade outrunner and get almost 5 minutes on it (looks like you'll get that easily as 3.87 is about what, 55% left? The 1835 Kv inrunner you are now using that I also have in my F-16 gets me only 3:15 flight time on a RT 5500 70C (coming in with 20% left), but about 3:45 on the 6250. The 35C with that inrunner produces about 5-7% less take-off thrust than the 70C, but the additional flight time is worth it. On the outrunner, both the 35C and 70C produce almost the same thrust for some reason, so I can use the 35C without loosing anything, plus it weighs 30g less. I'm waiting on the Hobbystar 8000 mah 100C to try on the 1835 Kv fan, so we'll see how that goes. It just fits in the F-16 but not sure it will fit in the F-18. If I can fit it in, we may be looking at 6-8 minutes but would definitely need the extra punch of the 1835 inrunner!
                              • 5401
                              It fits Hugh. I was surprised that I didn't get as much of a flight time increase as I thought I should in my planes where I tried 5200, 6200 and 8000... I didn't do it in my F-18 since I built it 8S.
                                • 2700
                                Thanks Evan D I'll probably leave the 8000's for the F-16 and SU-30. Actually quite pleased with just the RT 6250's and the stock outrunner, flies very well for my style, not a speed demon, and get's enough flight time to keep me happy.
                                • Carlbrainiac
                                  • May 2019
                                  • 242
                                  has anyone tried a hobby eagle gyro in their F18 yet? Just wondering what gains you are finding work well
                                    • 8804
                                    Yes. Start with 25% and work up till there's oscillation at max speed, then back off a little. The other option is to hook up the master gain (you'll need more channels), start with the gain at 50% and the knob on the TX at around 11 o'clock and increase little by little till it oscillates, then turn it down till it stops when at max speed. Make a note of it on the inside of the battery compartment so you know where to put it the next time out. On this plane use ONLY "normal" gain. Don't use "3D" gain at all - set it to zero.
                                    • Merry Boozer RC
                                      Wesley
                                      • Jul 2019
                                      • 178
                                      • Webster FL
                                      Hello fellow squawkers we finally got our maiden flight in on our FW F-18 and boys this one is amazing. We upgraded to the new HP motor and wow virtual is almost unlimited now. I’m truly amazed every time I fly one of these now and I really do recommend everyone try’s one. If you have a grass field there is no other F-18 on the market that will treat you this good. Anyway check out the video hit that like and we will see you on the next one.
