    rms, Great looking Hornet. Your LE Flap mod is outstanding. Best, LB
  • rms
    Evning flight with my F18. Did make LE flaps to be able to fly high alpha approach/ landing like the stock one. Click image for larger version
Name:	Freewing F18 Blue Diamond.jpg
  • jasmith41
    Originally posted by Aros
    This isn't 100% perfect but it is certainly good enough for small dings and hangar rash touch up work.
    Click image for larger version Name:	colormatch.jpg Views:	0 Size:	85.5 KB ID:	357276
    Thank you...
    Originally posted by jasmith41
    anyone have a source or color code for the blue angels blue...?
  • jasmith41
    Originally posted by jetpltrich
    Um, that’s a real scratch your head moment right there.
    No need to scratch your head for very long. I have purchased many motors, ESCs and planes where those wires have NO color coding whatsoever. I always thought most everyone in this hobby knew that it doesn't matter what wire goes where. Hook them up any way you want to begin with. If the motor doesn't run the direction you want, you simply switch 2 of them - ANY 2. It doesn't matter. In fact, if you hook them up and then close the plane up, there is a step in most ESC programming where you can just reverse the motor direction from there if you need to change it. Some of the newer "reversing ESCs" even make it possible for you to simply "throw a switch" via the TX to have thrust reverse. If you want "normal" at one end of the switch position rather than the other, just reverse that channel. Where each of the 3 wires are plugged in are of no consequence.
  • jetpltrich
    I have learned that the color of the motor wires really don't matter. They are quite arbitrary and only for reference so you remember which wire goes where to make the motor run in the correct direction.
  • InTheTubeDeep
    HTML Code:
    Thats not the F18 is it!? You move the ESC on top??
    No it is not the F-18 but it is an ESC for a 90mm which I removed from that airplane to an F-16 90mm. I took that pic to ascertain the correct wire configuration less I screw up. F-18 ESC is no different in your pic. My experience has been white is always the middle and the yellow and red are the outer, you’ll either hook it up backwards or forward. This pic should help you. White is like the white or yellow on a servo, I forget what that wire is called but you know what I mean.
    Rich
    HAHA YEAH I THOUGHT IT WAS THE FW 90MM F16 THE CHEATER VENT LOOKS VERY FAMILIAR!
    I have learned that the color of the motor wires really don't matter. They are quite arbitrary and only for reference so you remember which wire goes where to make the motor run in the correct direction. Once you get them hooked up the correct way, you can simply use the same color of heat shrink on the black ends so you can easily match it up if you ever need to take the fan out and put it back again.
  • jetpltrich
    HTML Code:
    Rich
  • InTheTubeDeep
  • jetpltrich
  • InTheTubeDeep
    Fun flight with Ute on nice morning, Surf Report was Epic
Name:	Screen Shot 2022-09-15 at 1.47.37 PM.png
ID:	356959Click image for larger version
Name:	Screen Shot 2022-09-15 at 8.43.35 AM.png
ID:	356960Click image for larger version
Name:	Screen Shot 2022-09-15 at 8.44.29 AM.png
  • InTheTubeDeep
    Originally posted by Juan De La Garza
    My parts came in. Need guidance on installing the ECS. Thanks in advance.
    Click image for larger version  Name:	306921783_6184654074883278_2498663488328195857_n.jpg Views:	0 Size:	66.2 KB ID:	356951​ Click image for larger version  Name:	ECS Unit.jpg Views:	0 Size:	112.3 KB ID:	356950
    Just remove the 2 screws holding wood strip on top of ESC, use long phillips head through the intake grill, attach 3 pole wires same as existing or in existing hook up and test, if reversed just swap 2 of the wires- really easy! Run the Burner wires in same duct
    You need to tell us what it is that you need guidance for. We don't know what you know or don't know. Some well worded questions will be helpful.
  • Juan De La Garza
  • jetpltrich
    Just don’t crash!
  • InTheTubeDeep
    High 5!! Hey Megan Heather Chrissy- can't go wrong!!
    https://www.youtube.com/watch?v=KT4z63dBO6k​
Name:	Screen Shot 2022-09-13 at 6.21.45 PM.png
  • InTheTubeDeep
Name:	Screen Shot 2022-09-12 at 8.21.14 AM.png
  • InTheTubeDeep
Name:	Screen Shot 2022-09-11 at 6.44.30 PM.png
