That has been my credo when it comes to RC planes. Nothing wrong with putting your own touch to any plane but I've seen things go wrong so many times, so many ways. I've flown with fellas who spend weeks and months getting a plane just right, looking just right before they fly them. The amount of detail, care and attention was immense. Then the thing crashes the first minute into the maiden, sometimes with little to nothing left to salvage. You can't help but shed a tear or two for those guys. I fly first, mod later.Comment
Yep, agree with that, seen several guys spend months on a bird and crash it on maiden, I'm not a scale guy when it comes to painting and detail, I fly them, sometimes I will change out the wheels as I plan on doing on the F-18, thats about it and a coat of gloss Minwax on the BA version, I might get a Grey one too down the road and put on some Callie graphics, I like the low visibility livery myself, slap them on the Grey one and call it good.:) Hope to maiden my BA this weekend, only thing is, I ordered the ARF version and I'm not sure my extra ESC from the F-4 is going to work, I see the part numbers are different.:Confused:That has been my credo when it comes to RC planes. Nothing wrong with putting your own touch to any plane but I've seen things go wrong so many times, so many ways. I've flown with fellas who spend weeks and months getting a plane just right, looking just right before they fly them. The amount of detail, care and attention was immense. Then the thing crashes the first minute into the maiden, sometimes with little to nothing left to salvage. You can't help but shed a tear or two for those guys. I fly first, mod later.
Will find out Wednesday I guess.;)Comment
I never said anything about full span ailerons. I don't intend to run ailerons at all, spoilers at the most.You can't do full span ailerons on this plane since they can not deflect upwards. I have them on the F-22 but had to turn them off on the Hornet.
He is correct about added up elevator with full span flaps. Regular flaps for me needed 6% of up elevator with flaps, 3% with half flaps.
Thanks for the valuesFreewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversionComment
In general, tailerons add a LOT of roll authority, so I would recommend trying with a few dual rates ranging from very little to quite a bit.Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversionComment
I received a message requesting what the 90mm F-16's ordnance looks like on the 90mm F-18, so here it is on my repainted bird. The AIM-9s and AIM-120s slot right in, and as you can see in these various angles the overall proportions are good. The fuel tanks, however, are too large in my opinion. For a center tank, at least the smaller capacity that VFC-12 flies, the 80mm A-6's wing tank is a good overall shape and length. I haven't had time to paint and install it yet, though.
If you have any requests for photos of other ordnance combos, let me know. I'm going to use the 90mm F-4's double AIM-9 pylon to mount two AIM-9s for a 6x AIM-9 configuration I saw online.
Excellent as usual Alpha! I haven't bit just yet.... too many projects ahead of this. Decided to Keep my F-14 and do a full repaint. But it is destine for my hanger!
Current Hanger: FW, F4.F22,F14, Byron T-6, Top Flite P-47, Top Flite P-40, Top RC P-51 H9 P-51, SebArt Avanti, Yellow aircraft Spitfire, T Jeti Extreme Flight EDGE, DS-24 Carbon,Comment
I'll be putting a couple coats of gloss on mine. I put it on my Tigercat and really like the way it looks. But I'll be painting mine in pieces before I put it together, just easier to handle, I think. And yes, I could put it together, fly it, then take it apart and paint it, and then put it back together. I guess I just don't want to do it that way. :PComment
DX9 and an Admiral 10 channel Rx. Used 8 total channels (6 normal + 2 extra) and 6 mixes (3 for Flaps>Ail and 3 for Ail>Elev). I may end up applying Tailerons to all the flight modes at some point and not just landing flaps. Would be really easy to do.Comment
Go for it! My gray one I will fully mod before flying it because sometimes I like to live on the edge.... :Silly:I'll be putting a couple coats of gloss on mine. I put it on my Tigercat and really like the way it looks. But I'll be painting mine in pieces before I put it together, just easier to handle, I think. And yes, I could put it together, fly it, then take it apart and paint it, and then put it back together. I guess I just don't want to do it that way. :PComment
I've had the same issues using an XPS RX on the L-39 and F-22. I will be putting a Graupner in the F-18 and will report on whether or not there are issues.
Mine arrives today, so currently printing up Radar-Guy's wheel covers. Will also paint the struts and interior wheel wells white.PatComment
