New Avios Mig 17 ?
  • gooniac33
    The Original Gooniac
    • Jun 2016
    • 1047
    Finally a flight that is not hat cam!! take a look...
    • themudduck
      -TMD- Foaming at the Mouth!
      • 1041
      • Burton OH (near Cleveland)
      Great job! I'll have a new video posted soon. I got a couple of flights in with the burner today!
      • gooniac33
        • Jun 2016
        • 1047
        Sweet!! Looking forward to seeing it!
        • themudduck
          • 1041
          OK here you go! This video was shot on Monday, we had what will probably be the last nice day until next April of May. Unfortunately Gooniac's afterburner didn't show up well in the daylight during the flight, partially because of the angle to the camera, but the video does include a shot on the ground which shows it off. This flight also includes "the sound" - my favorite thing to do with this plane is to make a high-speed dive and then cut the power - the result is a "compressor stall" that sounds TOTALLY cool, but is hard to get on the camera mike.... so here it is.
          I also made a perfect landing - after trying and trying without a lot of success to get rid of the bounce, I finally did it. The solution for me was to mix in a little bit of up elevator with full flaps. I also increased the flap throw and replaced the original hard nose wheel with a soft foam one. Poof - problem solved, perfect landing!
          Here is the proof! https://www.youtube.com/watch?v=SJwzcAgt-JI
          • WrightBrosRC
            All Things Aviation
            • Feb 2019
            • 195
            • Hillsboro, OR
            I was hoping to fly mine today, but the build yesterday hit a snag...
            • gooniac33
              • Jun 2016
              • 1047
              What I think stands out the most about this plane is the way it sounds!! It sounds awesome screaming past! Its a lot of fun to fly and my only issue with it is the tail being so easy to crunch with car doors etc...
              • MrSmoothie
                Scale Warbirds & EDF's!
                • Oct 2017
                • 177
                • Gainesville, FL
                Happy to see a thread on the Avios Mig-17 over here on HS. I'm "done" with the thread on RCG -- every second or third post is from the same jack*** (yes, I mean that) who posts his new videos flying his Mig irresponsibly (the way that is causing, and will continue to cause, all kinds of issues by the FAA for law-abiding AMA member flyers).
                That said, here's my Mig 17. I replaced all the servos with Freewing hybrid metal gear. The inner doors worked -- until they became intermittent and I decided not to fool with them any longer, as I could barely tell if the wheels were covered or not in flight. All wheels are Freewing replacements (F-4 Phantom). 3D printed cockpit and pilot. New color scheme -- BEHR flat latex uppers, Testors silver (spray can) lowers. I did my own grahics in CorelDraw, printed out for me, as always, by Callie. My pitot tubes are partly 3D printed (tips and wing-nubs) with plastic straw in-between, in case they snag.
                My latest lipo is the one suggested by The RC Geek -- Roaring Top, 6s, 6250mAh. So far I'm very impressed. Vertical is virtually unlimited (when it gets too high to see, that's high enough, right?).
                Click image for larger version  Name:	IMG_5830.JPG Views:	0 Size:	160.0 KB ID:	223581Click image for larger version  Name:	IMG_5831.JPG Views:	0 Size:	156.8 KB ID:	223579Click image for larger version  Name:	IMG_5778.JPG Views:	0 Size:	99.4 KB ID:	223578Click image for larger version  Name:	IMG_5774.JPG Views:	0 Size:	123.4 KB ID:	223577Click image for larger version  Name:	3020 Best Image Mig 17.jpg Views:	0 Size:	33.5 KB ID:	223582Click image for larger version  Name:	Untitled-11.jpg Views:	0 Size:	109.9 KB ID:	223583
                  • 4857
                  MS, Bravo Zulu, Sir. It is inspiring to see talented modelers using 3DP, Corel, and whatever other tech is available to do such great work. Best as always, LB
                  • themudduck
                    • 1041
                    MrS, that cockpit looks terrific. Great job on that, and the rest of the plane! It really looks sharp.
                    • mavdriver
                      • 38
                      • Hesperia , California
                      Nice I would do a Red Bull version
                      • MrSmoothie
                        • Oct 2017
                        • 177
                        • Gainesville, FL
                        Thanks! I should have pointed out that I bought a file for the cockpit components -- he posted in the RCG thread and the price was modest. Took some time to print and paint them of course. The pilot file is a modified Max Gruder file (CGTrader) --I have purchased several of his pilot files are well worth the cost. In this case I used his jet pilot body, but a Luftwaffe (109) pilot head, as the North Vietnamese still used flying helmets in the 1960's. The O2 mask is a combination of sculpted spackle, plastic tubing, ans wound solder.
                        If anybody wants to pursue the cockpit files, I'll dig up the contact information.
                        • MrSmoothie
                          • Oct 2017
                          • 177
                          • Gainesville, FL
                          If I was going to do a civil version, I have long admired the Stoli showplane. In fact, years ago I started doing the graphics for it -- for a day or two I'd thought about faking that scheme on the UMX Mig 15.
                            Stoli would be easy to see, that's for certain. I would also like to see someone do a Red Bull version someday.
                            Excellent cockpit detail, MrSmoothie!
                            • MrSmoothie
                              • Oct 2017
                              • 177
                              • Gainesville, FL
                              Thanks Apha! Hey, how's the 1700mm Mosquito coming along (heh heh).
                              If I ever do another Avios Mig, it'd have to be this scheme!
ID:	223756Click image for larger version
                              • Dirty Dee
                                • 768
                                • Northern Illinois
                                Its a great scheme! I did that for my 3d printed MiG. Very visible in the sky.
                                • MrSmoothie
                                  • Oct 2017
                                  • 177
                                  • Gainesville, FL
                                  I meant to add some information on the 3D printed cockpit parts -- I purchased these files for a modest amount from
                                  Patrick Verlinden <pat.verlinden@telenet.be>
                                  There are a number of parts, so I just took my time and printed one or two a day and basically made myself a kit. I think it's good to support young modelers who go to such trouble and hoping to make a bit of money to put back into their projects.
                                  As I mentioned before, my pilot was made from combining and modifying Max Gruder designs found on CGTrader. If anybody is selling nicer pilot files than Max, I sure haven't seen them yet.
ID:	224297Click image for larger version
                                    • 4857
                                    MrSmoothie, Your work is great, Sir. I have purchased a couple of Max Gruber's pilot file sets and his work is exceptional. Modding the prints is about as close as we're going to get to custom pilots in these smaller scales. Let's hope he'll continue to design as I'd like to see him do an "US Modern Jet Pilot". Best, LB
                                    • tengarang
                                      Banned
                                      • 382
                                      • Yay Area, California, USA
                                      Soo Soo much Exciting new updates.....well well.....welll loook what we have here some Mig 17'ners!!!!!!!!!
                                      • mshagg
                                        • 541
                                        • South Australia
                                        I didnt know there was a thread for this jet on here :)
                                        Here's my non-scale mig-15 paint job on the Avios. Honestly the way this jet flies still scares me a little lol, she is far from the heaviest EDF i own but for some reason just feels like she is throwing her weight around more.
                                        Looks good in the air and in the hangar though.
                                        • gooniac33
                                          • Jun 2016
                                          • 1047
                                          Its an awesome flying machine! Like that paint scheme!! Nice job!
