  • Wrthog
    • Feb 2020
    • 55
    Anyone else not impressed with the 80mm 9 blade fan combo? My buddy just got one of these and it’s not very fast, not that it’s suppose to be a speed demon but it really isn’t that impressive.
      • 2137
      • On planet earth....right
      For a PNP unit, one that draws roughly 100A and that is reasonably priced, I have been impressed with the performance of the new 80mm EDF 9-blade 1920kv inrunner motor system.
      This may sound obvious, but can be easily overlooked, but did you calibrate the ESC's throttle range?
      • James
        Administrator
        • Aug 2017
        • 1543
        Originally posted by T-CAT
        For a PNP unit, one draws roughly 100A, and that is reasonably priced, I have been impressed with the performance of the new 80mm EDF 9-blade 1920kv inrunner motor system.
        Sounds like the classic non-ESC calibration. The T-33 can boogie
          • 2137
          Yeah, I have yet to meet anyone that has said the T-33's performance isn't impressive on the stock power system.
            • 8747
            Mine is quite fast but then, I did the throttle calibration.
            • timmybeetle
              Warbird addict
              • 132
              • Netherlands
              ESC Manual
              Well, Freewing should have mentioned in there manual about this specific ESC how to calibrate it and how to adjust it if necessary ore wanted by the pilot.
              The manual can be found I thought some where here in this threat.
              grts Hans
              • WarPug
                • 46
                Mine was very impressive! Do a little troubleshooting. Loved that jet :(
                  Hans,
                  ESC programming guide is located in the Support tab of each plane that uses it.
                  https://cdn.shopify.com/s/files/1/10...iles/fwesc.pdf
                  • MikeT
                    Here......Hold my beer.
                    • 1060
                    Not sure what your looking for speed wise. Everyone here thinks mine is pretty quick. .
                    Mike
                    • Wrthog
                      • Feb 2020
                      • 55
                      Programmed esc , still pretty weak IMO, not my plane just thought it would be faster than my FMS viper but it’s not even close in comparison. 🤷‍♂️ Just had me thinking the twin mig29s I have in order are gona be dogs as well
                        Something is definitely not right then, the T-33 is a speed demon.
                        • timmybeetle
                          Warbird addict
                          • 132
                          • Netherlands
                          Hans,
                          Hi
                          Not true checked it for both eu and states
                          grts Hans
                          • Wild Man
                            • 526
                            • Rapid City, S.D.
                            I always do an ESC throttle calibration on every plane I have prop or EDF. Just one more of the things to add to your pre test flight check list, before flying IMHO
                            • tab28682
                              RC addict
                              • 334
                              • Fort Worth, TX
                              Many people at my field and at events I attend remark on how fast the T-33 is.
                              Are you sure the batteries were up to the task?
                              • ClintonStrate
                                • Sep 2020
                                I have a T-33! I love it was a little Disappointed in the speed. Is there a way to calibrate the ESC. I am running a gen ace 45c 5000 pack. It just does seem to perform like the video with the speed. Any suggestions would be great
                                • Mizer67
                                  • 374
                                  I'd stick it on a watt meter first. Make sure to rule out the batter(ies) especially under load.
                                  You can calibrate the ESC. Look at the Hobbywing ESC manual. Basically, plug the battery into the model, turn the radio on with the throttle on high and wait for two beeps if I recall correctly, then reduce throttle to zero. It should be calibrated. There should be a manual for the T-33 in the support section on the MRC web page. If not, check another plane that shares the ESC, they're all the same for the 100A's.
                                  PS - I've tested my "good batteries" against my "bad batteries". Both brand new, or nearly so. The "good batteries" are good for 7 more mph on the top end. I didn't expect that kind of a difference, but it's there. If you have really poor batteries it could explain the issue.
                                    The best way to calibrate the ESC to your TX throttle stick:
                                    1. Turn on the radio, move the throttle to full.
                                    2. Plug in the battery, and as soon as you hear the first beeps stop from the ESC, move the throttle stick to off.
                                    3. Unplug, turn off everything, then back on to test. You should be good to go from there.
                                    • Cws
                                      still flyin
                                      • 112
                                      • Ft worth texas
                                      I have a 80 mm fan from my late Eflight F4 phantom. Does anyone know if it will drop in fit the T 33 without modifications??
                                      • Mizer67
                                        • 374
                                        The FMS shroud is longer than the Freewing one and a touch larger in diameter.
                                        It will require modifications, but they're not too bad.
                                        • Turbinefancy
                                          Head-tracking FPV Advocate!
                                          • 294
                                          • Irvine, California, USA
                                          I really like how my T-bird handles, especially after removing the nose weights. Now the nose doesn’t drop as fast on knife edge. Might even attempt to hold it for the length of our 650 ft runway next time. For now quite content with how the point rolls and basic aerobatics feels. Aiming for precise handling then flat out speed flying. Thinking about what other moves I want to include in aerobatic routine. Any suggestions?
