  • Radar-Guy
    AirBorn Jetworkx
    • 364
    Thanks, Gentlemen!
    Jackcannon Well, I‘m in Germany. Please look for a local print service
    Flying Dutchman Go to post #850, it‘s the attached „Lower Front Panel“ file
    • Flying Dutchman
      • 26
      • Near Amsterdam, The Netherlands
      Originally posted by Radar-Guy
      Thanks, Gentlemen!
      Oops, I managed to miss that one in my earlier downloads of your files.
      Many thanks!
      • FredGB
        • Feb 2020
        • 19
        Hi all, I am most likely to fly my T33 (German scheme) next weekend and was wondering if i should wire the servos directly to the receiver instead of into the blue box and then the receiver as i have heard of others ending up losing their planes due to the box.The plane worked fine on the bench and all of the control surfaces landing gear etc worked fine when plugged into the blue box and so i was just wondering others thoughts on this as it is my first plane from MRC and first Jet after flying warbirds for some time .
        Thanks again
        Fred
        • Oxotnik
          Actung, Spitfire!
          • 931
          • Huntsville, AL
          Thanks again
          Fred
          The blue box isn’t needed, unless you don’t have enough channels available in you radio system. Personally, I have pulled the blue box and the wing-interface connectors from my T-33.
          RE: First Jet...
          I think that you’ll find the T-33 very easy to fly. Most of us have all had really easy maidens. Coming from prop planes, just remember that you can’t cheat airspeed with blips from the throttle. There’s some latency from the time that you advance the throttle until you see a response. She’s also a bit of a floater. So, your first landing or so, may be long.
          Good luck on your maiden. I hope you enjoy your T-33 as much as the rest of us enjoy ours.
          Warbirder
            • 5409
            The people had problems with the older blue box. The MCBe in this has been very reliable. But as Ox says there’s no real reason for it in this plane since there are no lights an landing gear synchronization isn’t needed.
            • FredGB
              • Feb 2020
              • 19
              Thanks Evan D and Oxotnik i appreciate it
              Fred
              • Cws
                still flyin
                • 112
                • Ft worth texas
                I have several flights on my T 33 now I believe it is the best edf I have owned. I have found using full flaps on landing will result in a slow touch down and short roll out.
                the Admiral stabilized rx600 receiver in this airplane has made it possible for me to get back to flying edf planes at 79. Thank you Motion RC.
                • Jackcannon
                  • 26
                  Thanks, Gentlemen!
                  Will do. Thanks radar guy
                  • Radar-Guy
                    AirBorn Jetworkx
                    • 364
                    More 3DP stuff...
                    Here are parts for the speed brake, loosely based on Brent's design. The servo mount is designed for a Corona (!) DS-939 MG servo. I had to remove a bit of foam from the fuselage to give room for the servo. It should be easy to move the servo closer to the "brake boards", if desired. You may notice a "step" at the aft end of the boards. That's caused by an issue with my printer, it's not in the model.
                    Frank
Name:	Speed Brake.jpg
ID:	237764Click image for larger version
ID:	237765Click image for larger version
ID:	237766 ​ ​ ​
                      Elbee commented
                      Editing a comment
                      Frank, Dittos on the great work here. And thank you for your efforts/results. Best, Steve
                  • Gilatrout
                    RC Pilot Addict
                    • 806
                    • Albuquerque NM
                    More 3DP stuff...
                    Frank
ID:	237766 ​ ​ ​
                    Many thanks.
                    Can you describe how the pushrod is made?
                    I would also be indebted to you if a certain high res decal document were posted😁
                    In all seriousness, truly thank you for sharing this work
                    • Radar-Guy
                      AirBorn Jetworkx
                      • 364
                      Two pushrods, made from the „servo wire catcher“ that comes with kit. Z-bend on one end, quick link connector on servo.
                      It‘s still in my mind! I‘ve started applying my DIY decals yesterday, making further mods to the sheets during the process. You‘ll get it soon!
                      Click image for larger version  Name:	D28D3766-0E6B-4FF1-8C18-1EDC9B069E0E.jpeg Views:	0 Size:	17.4 KB ID:	237811Click image for larger version  Name:	1D896A0F-310A-4AC6-8129-D870BE7A6ACC.jpeg Views:	0 Size:	13.9 KB ID:	237812Click image for larger version  Name:	E6635EFD-042B-4C75-8D5F-767E9A920E52.jpeg Views:	0 Size:	23.5 KB ID:	237813
                      • Icarus the 2nd
                        • Aug 2018
                        • 164
                        • Pajottenland, Belgium
                        very nice! your 'real' german T-33 is a true work of art! can't wait to see the final result
                        • Icarus the 2nd
                          • Aug 2018
                          • 164
                          I added some leds to my T-33. A solid green & red on the wingtips, a white beacon on top and a red beacon below.
                          I used some clear lenses/mounts where these high power 1w leds fit in perfectly, as you can see it gave good results and I could install them without showing or damaging the foam.
                          • Icarus the 2nd
                            • Aug 2018
                            • 164
ID:	237824Click image for larger version
ID:	237826Click image for larger version
ID:	237827Click image for larger version
ID:	237828Click image for larger version
ID:	237829Click image for larger version  Name:	IMG_20200204_220032.jpg Views:	0 Size:	84.6 KB ID:	237822Click image for larger version  Name:	IMG_20200204_220055.jpg Views:	0 Size:	75.7 KB ID:	237823
                            • Corsair nut
                              Jets...warbirds...mmm hmmm
                              • 218
                              • Tehachapi ca
                              Those speed brakes are awesome!!! Well done!
                              I had my t33 out on friday in some 15 to 20mph winds amd it took it like a champ. Reeallly enjoying the t33. I like it so much.id buy another for sure if this crashed. (And i dont say that about many models!)
                              • Corsair nut
                                • 218
                                • Tehachapi ca
                                Also...for anybody that's curious about the aft fuse/tail pipe reduction I did...Justin La and I did a fly off head to head test of 100% stock vs mine with reduced tail pipe...mine took off faster...had a faster cruize and faster top speed. Not by a ton...but the conclusion is that for a 15 minute mod...it certainly didnt hurt performance. 0 loss in vertical perdormance over stock. In fact it might have been sightly better. And I was using a 5 year old zippy 5800 30c pack. Basically Justins reaction was... "I guess I know what I'm doing to my T-33 tonight.."
                                • Gilatrout
                                  RC Pilot Addict
                                  • 806
                                  • Albuquerque NM
                                  Here are 3DP files for better looking seats, based on the Martin Baker MK GU5 as used in later Luftwaffen T-33s. Parts printed with ASA Filament. Warning: This is a kit Please refer to the pictures for assembly.
                                  Click image for larger version Name:	Seat 2.jpg Views:	0 Size:	42.0 KB ID:	237360Click image for larger version Name:	Seat 1.jpg Views:	0 Size:	36.9 KB ID:	237361Click image for larger version Name:	Cockpit Parts.jpg Views:	0 Size:	56.3 KB ID:	237362
                                  I've been printing happily and I have a few questions.
                                  In the above pic, you show a lower portion for each cockpit panel. The supplied files only includes one. The only difference appears to be that the center portion is longer on one than the other. If so, then no problem I'll just print a second and trim the part.
                                  Second, do you have or can you recommend a background image for the instruments?
                                  Finally, the pilot busts look awesome. Where did you get them? Are they also of your own design? Are you using a PLA printer?
                                  Many thanks
                                  • Radar-Guy
                                    AirBorn Jetworkx
                                    • 364
                                    I‘m very interested in this mod, but don‘t like to cut my freshly painted fuselage. What is the outlet diameter on your model? I would like to model a 3DP reduction piece for the tail pipe.
                                    • Radar-Guy
                                      AirBorn Jetworkx
                                      • 364
                                      1. In the above pic, you show a lower portion for each cockpit panel. The supplied files only includes one. The only difference appears to be that the center portion is longer on one than the other. If so, then no problem I'll just print a second and trim the part.
                                      2. do you have or can you recommend a background image for the instruments?
                                      3. Finally, the pilot busts look awesome. Where did you get them? Are they also of your own design?
                                      4. Are you using a PLA printer?
                                      1. Both are printed from the same file. I started fitting the panels to the foam cockpit (front panel first) and trimmed that part in question. Doing this, I realised that the front cockpit needs a new coaming. I will work on that today.
                                      2. I used an image from this site: http://aviation.watergeek.eu/t33-panel.html
                                      3. The pilot bust are really awesome, not my design. Here is the source: https://www.thingiverse.com/thing:3806310
                                      Scaled to size
                                      4. All parts were printed using ASA. According to the specs, it‘s getting soft at around 110 deg C.
                                      • flazz
                                        maiden this!
                                        • 40
                                        • USA
                                        #913
                                        Yesterday, 11:33 AM
                                        "I added some leds to my T-33. A solid green & red on the wingtips, a white beacon on top and a red beacon below.
                                        I used some clear lenses/mounts where these high power 1w leds fit in perfectly, as you can see it gave good results and I could install them without showing or damaging the foam."
                                        IT2:
                                        Very cool, I'm planing on do something similar. Can you give us a source for the LEDS and the lens covers? Also, what flashing unit are you using?
                                        thanks for any info.
