Not sure if yeh EDF would cause enough vacuum to stop the servos from opening the doors. I’ve never had that issue on my F-16 and have well over 50 flights. The doors do not have a perfect seal so not sure how can there be enough vacuum. I would think that if the servos can close the doors after take off, more air pressure holding them open, they should have enough power to open them. The voltage for all servos in my F-16 are set to 6v and landing gear to 7.4, so voltage should not be your issue. I remember you having and issue with your rudder/steering when you added throttle, what if the issue is RF interference, the routing of the satellite wires could be a problem 🤷♂️
On the MFC you can also adjust the degree of rotation of the gear doors. What if you reduce the closing end point of the servo door leaving the doors a hair open.
