  • Airguardian
    Post Stall Svengali
    • Aug 2020
    • 1681
    • Catalonia
    • Airguardian
      Post Stall Svengali
      • Aug 2020
      • 1681
      • Catalonia
      • Airguardian
        Post Stall Svengali
        • Aug 2020
        • 1681
        • Catalonia
        Finally got to post the vids of the power upgrade with FMS fans... :)
          • 2715
          Very Nice. I installed those early on and have never regretted it.
          • Airguardian
            Post Stall Svengali
            • Aug 2020
            • 1681
            • Catalonia
            The extra power is very noticeable... tomorrow I'll put some more flights in! :D
            • Airguardian
              Post Stall Svengali
              • Aug 2020
              • 1681
              • Catalonia
              Took me long enough...
              • kallend
                • 1877
                I still think your SU-35 is better.
                • Airguardian
                  Post Stall Svengali
                  • Aug 2020
                  • 1681
                  • Catalonia
                  I still think so myself... hardly an argument.
                  As far as I'm concerned, the Su-35 beats everything else scale (or not) EDF, not just the MiG-29!
                  • kallend
                    • 1877
                    Interesting that this warning now appears on Motion's site for the Mig, despite the fact that it uses a separate UBEC.
                    Power System and Electronics Compatibility:
                    This model is designed to operate using the included ESC and its integrated BEC, which is specifically matched to the onboard electronics. To ensure reliable performance and prevent damage, always power the aircraft's receiver and electronics through the installed ESC using the main flight battery. Do not use any power source other than the main flight battery to power the model, otherwise damage will occur to the electronics.
                    The receiver, servos, and other onboard electronics included with this model are rated for a maximum input voltage of 5.5V. When selecting your ESC and power system, verify that the BEC output supplied to the receiver and onboard electronics does not exceed 5.5V. Using a higher voltage will damage the aircraft's electronics.
                      • 5407
                      As Motion tends to cut and paste information it’s not surprising.
                      • kallend
                        • 1877
                        Marketing and engineering not talking to each other?
                          • 5407
                          I don't think so. I think the person(s) at Motion that creates and updates pages just doesn't take the time to proof read. Things like different motor sizes on the same page should be real obvious. Or creating a new page and using a different model as a starting point and it has information that is just wrong for the new model. A new V2 of a model is released but the link to the manual is the V1 version. As I said cut and paste issue.
                            • 5407
                            Sounds like a Mig29 to me.
                            I'm not a fan of SMC but am a fan of HV batteries and I would use lighter batteries.
                            The FreeWing 2150 fan would be my recommendation.
                            You have updated servos if they have the red arms.
                            • flyjets01@gmail.com
                              Flt Test
                              • Apr 2026
                              • 30
                              • Western NC
                              Thanks Evan fixed the error. I saw you had a Mig 29 while back.
                              I'll try the LHIV ion the old Hobbyking ESC see the Amp draw and thrust output.
                              Click image for larger version  Name:	20260715_090424.jpg Views:	0 Size:	68.3 KB ID:	450993
                              Management is doing things right; leadership is doing the right things.​
                                Flt Test
                                • Apr 2026
                                • 30
                                • Western NC
                                Hi Guy's
                                I picked up a used Mig 29 that has never been flown it has the 9 Blade motors. The hardware appears to be the upgraded linkages and the Stabs have the red metal arms.
                                Batteries
                                I'm going thru it now and have ordered SMC HV3 22.8v/6s
                                Motors
                                I was wondering has tried these motors and it the thrust improvements are good for Grass?
                                Speed Controllers with reverse thrust any idea's ?
                                Last I'll replace the Stock Stab Servo's any idea's ?
                                Thanks in advance
                                Ian​
                                • Airguardian
                                  Post Stall Svengali
                                  • Aug 2020
                                  • 1681
                                  • Catalonia
                                  w00t
                                  • Airguardian
                                    Post Stall Svengali
                                    • Aug 2020
                                    • 1681
                                    • Catalonia
                                    Long overdue... :p
