    • 4878
    ahajr
    Welcome to Hobby Squawk. Glad to have you onboard. Best, LB
    • MetallDanny
      • Sep 2023
      • 28
      • Netherlands
        • 2716
        SWEET, love the Plus RX as well!
        • MetallDanny
          • Sep 2023
          • 28
          • Netherlands
          Yes the new + update on the as3x is SuPeR!
          but... the rear gear was out of line (out of the box) the tires where running crooked.
          not good for the gear when you thouch the ground. Check your rear wheels there not in line. I filed it down where the screw touches the rear gear. It was a tip from 2BRC
          • MetallDanny
            • Sep 2023
            • 28
            • Netherlands
            • MetallDanny
              • Sep 2023
              • 28
              • Netherlands
              Having FUN with my TwiN80mm!
              Click image for larger version  Name:	20250404_203435.jpg Views:	0 Size:	89.3 KB ID:	423247
              • yogi
                • Dec 2024
                • 4
                Originally posted by ahajr
                This is a new Freewing Redstar MiG-29 Fulcrum Twin 80mm. I am having an ine is the same issue where the thrust vector module is jamming and stalling the servo. I have checked the servo and the ball links. They are all fine out of the system. In the attached video you can see what I'm talking about. Does anyone know the internals of the outer and inner housing? Is there an internal pin that may be broken or loose? I'm not looking forward to busting this all loose on a new unflown plane to see how it works. I am wondering if there is a known fix. I am thinking there is a broken pin or a warped outer or inner part. Customer support says these are the fix https://www.motionrc.com/products/fr...nkage-set-n329​. However these don't look anything like what is on my plane unless they are internal to the mechanizm, which I can't see without taking it all apart.
                Mine is the same did you ever get a response or fix from Motion RC or the forum ???
                • lusek_pl
                  • Sep 2020
                  • 49
                  • Polska
                  After 3 years of sitting in a box, I think I'll finally finish it:]. By the way, the F-16 is tiny compared to the Mig...
                    • 2716
                    These were the upgrades I did to the Mig's horizontal stabs. 2-ProModeler DS150CLHV servos, 1 servo reverser and a Hangar 9 4 1/4 inch titanium control rod. The ProModelers are priced competitive to the MKS and hitec servos, but in my opinion, are better. And Made here in Florida. They are powerful, quiet, smooth as silk and consistently return to neutral. No chattering searching for 0. There are others more expensive out there, but these are more than sufficient for me and these aircraft.
Name:	#3 FW Mig 29.jpg
ID:	426174 Click image for larger version
Name:	#4 FW Mig 29.jpg
ID:	426175 Click image for larger version
Name:	#2 FW Mig 29.jpg
ID:	426176 Click image for larger version
Name:	#1 Freewing Twin 80mm Mig 29.jpg
ID:	426177 Click image for larger version
ID:	426178 Click image for larger version
ID:	426179 Click image for larger version
                    • paulrkytek
                      • Jun 2019
                      • 542
                      • North of England
                      Splashed out on a Radiomaster Boxer with Edge TX for the Mig29 complete with TV kit, just waiting for some EC5 to XT 90 connectors then it is maiden flight time.
Name:	Mig29 photo 1.jpg
Name:	Mig29 photo 2.jpg
Name:	Mig29 photo 5.jpg
                        • 2716
                        [QUOTE=paulrkytek;n427205]Splashed out on a Radiomaster Boxer with Edge TX for the Mig29 complete with TV kit, just waiting for some EC5 to XT 90 connectors then it is maiden flight time.
                        Nice, you will love flying it, especially with those TV units. Gotta say this is probably my favorite EDF now, great presence in the air, highly maneuverable with the TV and lands easy and smooth. Suggest you balance it at least 10-15mm aft of recommended CG for best results. She's just a big, bad sweetheart!
                        Without TV it will get stuck in the falling leaf high alpha, but the TV unit easily corrects that. ENJOY!!
                        • paulrkytek
                          • Jun 2019
                          • 542
                          • North of England
                          [QUOTE=Hugh Wiedman;n427259]
                          Thanks Hugh. Done my homework and watched countless videos. I already have CG set at 15mm aft also using separate 600mah 2s lipo for BEC and 2 number CHNL 4000mah 70c G series weighing in at 610 gms each and A3 super4 gyro. I have setup the reverse thrust on a momentary switch but with any luck landing on the slight upslope of our grass field means I should not need it. Connectors have arrived now so just waiting to pick a good day
                          • Alphonso
                            • Aug 2020
                            • 101
                            • Hastings, UK
                            [QUOTE=paulrkytek;n427377]
                            This one lands quite slow, particularly with TV induced flair just before touch down, I don't think you' ll have any problems.
                            your flights will be very short with 4000 std V packs and thrust robbing TV. There is a 3DP cheater grill mod out there and I got 400g more thrust per fan by doing it.
                            we can get SMC HV lipos in UK now from unmannedtechshop, the 5900mah HV2 is perfect in the Mig.
                            • paulrkytek
                              • Jun 2019
                              • 542
                              • North of England
                              [QUOTE=Alphonso;n427503]
                              Thanks for the update , just waiting for the back in stock e mail from unmannedtechshop. I already have a couple of HRB 4500mah 60 to 120c lipos on the way at 630gms each so I wiill go for the 4900 smc packs at 645gms as I have gyro, rx set up in the middle with 2s bec lipo in the nose so it should not be a problem to push the front lipo back and relocate bec and 600 lipo to rear to get back to my cg mark ( 15mm aft of stock ). I am tempted to go for the smc 6700 pack for my SU35 ( same weight as my older Turnigy 5000 packs !!!!)
                              • paulrkytek
                                • Jun 2019
                                • 542
                                • North of England
                                do the standard escs for the Mig29 take the smc hv packs without any adjustment , i.e 6 beeps on connection to lipo
                                  • 2716
                                  Yes Sir! I'm also using the SMC HiV V2 5900 in the Mig, as well as almost all over aircraft EDF's and props. Use the 8S version in 3 others, no problems with the ESC's. Flying the Mig about 20-25mm back and get over 5:00 flight time, depending on how crazy I get with the TV. Tried 2 SMC HiV 6700's but didn't get much more flight time. The extra weight offset a lot of the extra mah, so believe the 5900's are the sweet spot, at least for me.
                                  • paulrkytek
                                    • Jun 2019
                                    • 542
                                    • North of England
                                    Thanks Hugh, I will try the SMC HCL-HV2 5900 in the my FW SU35, at 100gms lighter than my normal 5000mah 6s packs I should get 4 mins. I will use the 4900 smc packs for the Mig to keep the weight down and with the 2150kv in-runners I should get 4 mins which is ok for me, besides I would prefer to avoid the HIV
                                    • t33jetman
                                      • 515
ID:	428603 Click image for larger version
ID:	428604 Click image for larger version
ID:	428605 Click image for larger version
                                        • 4878
                                        t33jetman
                                        She's a beauty and congratulations.:trophy:
                                        Best, LB
                                          • 2716
                                          t33jetman Outstanding, I always loved your repaint of the Mig (and a whole host of other aircraft). And the chute is Boss!
