  • RCJetFanatic89
    • Sep 2020
    • 14
    Originally posted by kallend
    Does this imply that you have roll input to the canards?
    Yes, I’m using canards as well in roll
    • Apriliamgt
      • Oct 2017
      • 73
      So what's the best recommend rates ??
      • RCJetFanatic89
        • Sep 2020
        • 14
        Originally posted by RudyD54
        I’m not sure where you’d end up in the canards as I only use them in pitch but I imagine you’d see a similar result.
        so using sticks to the corner to measure the canards out as well?
        • janmb
          Slow and low
          • 729
          Originally posted by JLambCWU
          ANY aircraft will be lacking in control when the AoA gets too high. (hence the wing drop) A single TV nozel won’t change this.
          Yes and no.
          Roll and pitch authority stays fine into really, really high alpha, both with vectoring and without. All that requires is good CG, which you probably have never tried.
          Yaw authority on the other hand goes down the drain without vectoring, and remains solid with. So for yaw, which this really boils down to, vectoring is day and night difference.
          • kallend
            • 1877
            Define "best".
            • Airguardian
              Post Stall Svengali
              • Aug 2020
              • 1676
              • Catalonia
              Originally posted by RCJetFanatic89
              Any hell is greatly appreciated!
              Have a hell!
              • RCJetFanatic89
                • Sep 2020
                • 14
                Have a hell!
                LOL! Didn’t even realize there was a typo. That’s too funny
                • Airguardian
                  Post Stall Svengali
                  • Aug 2020
                  • 1676
                  • Catalonia
                  Couldn't miss the chance!
                  • RCJetFanatic89
                    • Sep 2020
                    • 14
                    I would’ve done the same!!
                    • HockeyMac!
                      • Nov 2019
                      • 34
                      Lmao!!!
                      • Airguardian
                        Post Stall Svengali
                        • Aug 2020
                        • 1676
                        • Catalonia
                        Smoke for the Smoke God!
                        • Dan McKeag
                          • Sep 2020
                          • 22
                          Thank you for the great videos---impressive!
                          • Airguardian
                            Post Stall Svengali
                            • Aug 2020
                            • 1676
                            • Catalonia
                            Thank you for the feedback! :)
                            • Pogo
                              • 452
                              • Waterford, Ontario, Canada
                              Well it took longer than I'd thought (go figure) but the leading edge flaps are done. Thin plastic from a Xmas wrap box was used to cover the bottom wing gaps- these slide back over the wing as the flap comes down. I have them on a 3 position switch and deployment is slowed to 2 seconds- flight modes are also being used, allowing for separate trims in each position (Hugh W. will approve :).
                              Weight gain is about 20 grams per wing- haven't re-checked the CG yet but may be able to remove most of the lead added for the maiden flights.
                              I'm really looking forward to trying the flaps out in flight, but that will probably have to wait 'till spring. Now on to the wing pylons...
                              Merry Christmas all!
                              Tom
                              • janmb
                                Slow and low
                                • 729
                                Tom
                                Looks great, looking forward to hear the results!
                                • Airguardian
                                  Post Stall Svengali
                                  • Aug 2020
                                  • 1676
                                  • Catalonia
                                  Have some more Gripen joy!
                                  This jet makes it so convenient to attach smoke cartridges on the wingtip rails...
                                  Use some isolation though if you do, or you will melt them.
                                  • HaroldAnderson
                                    • Mar 2019
                                    • 101
                                    • Oklahoma
                                    Nice flights. The smoke looks especially good down low when you have a background. It looks like you don't get many sunny days in your region that are great for smoke. It would be cool to see it backlit with smoke on.
                                    • kallend
                                      • 1877
                                      I asked previously but didn't see an answer. How are the smoke cartridges ignited?
                                      • killickb
                                        • 118
                                        Looks like he uses cigarette lighter ?
                                          • 8814
                                          It doesn't show them being "lit". I've used the kind that you pull a wire at the end of the cartridge and that triggers the ignition.
