  • nickwildman81
    • Nov 2025
    • 17
    • North West, UK
    I see them in stock at Motion.
    Ah, I'm defaulted to the EU warehouse as I'm in the UK. They haven't had them for a while now.
      • 8814
      I C. They are "out of stock" at RC Castle, too. If they do come back into stock, there is a possibility that more current power systems would be in place. However, if a particular model was a poor seller, it may not ever come back. Having said that, the Freewing twin 80mm MiG-29 was out of stock for a very long time (@RCC) and it came back (small production run) with more powerful (than original) EDFs, reverse thrust and vector thrust already installed (went out of stock very quickly at RC Castle). The later version was not designated a V2.
        • 5401
        On the flip side the 10+ old F-14 still comes with the ancient outrunners...
          • 8814
          Yup, that's "pre-historic". I have a mind to install the latest inrunners from the A-10 V2.
          • HairyTacco
            Foam Aficionado
            • 20
            • Canberra, ACT, Australia
            Hey Team..
            I managed to pick on of these up NIB for less than 1/2 the retail price, which is a good saving when its $1100 Dollareedoos down here. I've been keen to try a B-2 as the real aircraft is amazing and looks super cool..
            Been working through the forums to get a feel for what I need to ensure successful flights on this bird but it seems to come with 'rules' like a Gremlin! ie wind <5kts, crosswind bad, never feed after midnight etc..
            I've got a Assan nosewheel gyro spare so I'll be using that bad boy for this plane too. I'm lucky enough to fly off a geotex type field but its pretty icy in the early morning this time of year so I'm hoping the nose gyro will help the tracking..
            Better get back to reading...
            Cheers,
            HT
              • 8814
              Originally posted by HairyTacco
              Hey Team..
              Cheers,
              HT
              If you're using the Assan steering gyro, make sure to turn OFF the stock steering gyro. I find that the stock one is just fine so long as you crank the rudder gain to MAX, especially for take offs and landings. I don't use the little invisible rudder. Don't try to land on the glide - it's too slow. Fly it to the ground with some speed. I've also programmed the drag rudders to act as full ON speed brakes after touch down. It could roll off the end of the runway. I fly off GeoTex, too.
                • 8814
                Hey Team..
                Cheers,
                HT
                If you're using the Assan steering gyro, make sure to turn OFF the stock steering gyro. I find that the stock one is just fine so long as you crank the rudder gain to MAX, especially for take offs and landings. I don't use the little invisible rudder. Don't try to land on the glide - it's too slow (it could cartwheel). Fly it to the ground with some speed. I've also programmed the drag rudders to act as full ON speed brakes after touch down. It could roll off the end of the runway. I fly off GeoTex, too.
                • GliderGuy
                  • 1412
                  Slight modification suggested…
                  Change from: “Fly it to the ground with some speed…”
                  Change to: “Fly it to GROUND EFFECT” with some speed…”
                  Once in ground effect, hold her off as long as possible…like a Piper Cub 3-point landing. Why? If you touch with too much energy, she can begin crow hopping, and you will destroy the nose gear servo and or mount.
                  If you touch with the absolute minimum speed possible, she has no energy to crow hop.
                  I fly with the invisible rudder…personal / individual preference. Good either way.
                  -GG
                  • HairyTacco
                    Foam Aficionado
                    • 20
                    -GG
                    Thanks for the advice guys.. GROUND EFFECT speed bleed it is!!
                    Is it worth changing the wheels out to Dubro low bounce ones to help with the landings??
                    Cheers,
                    HT
                    • GliderGuy
                      • 1412
                      Can’t say…no data. Just focus on making the best no bounce landings you can do and all will be well.
                      I’ve flown her a lot, and only have to replace nose servos rarely. But, you bounce her and she hits on the nose wheel…have a spare servo handy.
                      -GG
                      • f4u ausie
                        • 1240
                        • Melbourne
                        Does it fly off not manicured but well mown grass
                          • 8814
                          I tried to fly mine from grass. I wouldn't call it well mown but just mown. With stock wheels, it won't get up enough speed to lift off. So I got the "grass" wheels that were offered as an option. That did NOT work either. It just can't get up enough speed to actually fly. This is with a 400+ feet of max throttle rolling. I think it would have to be golf green grass.
                          I gave up and put the stock wheels back on and only fly it from our GeoTex runway. If it were twin 80mm from the latest EDFs, it probably would do it.
                          • f4u ausie
                            • 1240
                            • Melbourne
                            At my new field (12 months now). Some of the 80 mm. Example f22. Needs to be popped off the grass:face_with_raised_ey meaning give no elev. Then quickly full. It pops up.. but if U go with slight up. As U would on pavement. It won't get up
                              • 8814
                              Oddly, the B2 just doesn't have enough thrust to get rolling fast enough. One fellow tried with both the stock wheels and the "grass" wheels. He said he managed to get it up once but it was scary. He never could do it again and gave up on it. A single 70mm can do it, but the B2 is just too big and heavy and low to the ground. If it had some nose up rake (maybe 3 to 5 degrees) or twin 80's, it could do it. I just didn't want to spend the effort to modify the nose gear to be longer.
                              • Balsa Bob
                                • Sep 2020
                                • 59
                                • New Hampshire
                                Which is the recommended (or best) video for setup ? I thought there was one on the Motion website ... but I can't find it.
                                Thanks. Bob
                                  • 8814
                                  This one .................................................. ........................ ?
                                  If you go to YouTube and put "Freewing B2 bomber setup in the search, you may find other set up videos.
                                  • seanpatrick
                                    • Mar 2025
                                    Has anyone tried running an f405 and inav in it for waypoint missions ?
                                      • 8814
                                      It doesn't fly long enough for you to do "missions". On a single 6000mah, 6s battery, it'll only fly for 5 to 8 minutes.
                                      • HairyTacco
                                        Foam Aficionado
                                        • 20
                                        So it was maiden day on Saturday, and what a day it was. Perfect conditions with sunshine a not a breath of wind..
                                        Took off dead straight with and ASSAN nose gyro and all she needed was a couple of clicks of trim and she flew beautifully! It was quite and awesome look in the air and certainly drew a lot of attention at the field. Landing was a non-event with the solid advice provided by the Squawks brains trust. Got her into ground effect and held off touch down with her settling nicely on the wheels. :-)
                                        I put a total of 7 flights on her this weekend and had a blast.. Been getting about 5-6min on a 6000mah pack which is about the level of my attention span.. I will say though, the wind picked up on my last flight as I was landing and I got the dreaded kangaroo bounce on landing! My fault entirely but the B-2 suffered no ill effects. As you guys said, you got to respect the little to no wind rule with this one..
                                        I do like this birds uniqueness!
                                        Cheers,
                                        HT
                                        NOTE: I much preferred the RC Air Marshalls setup video to other out there. Just a lot less stuffing around with the drag rubber linkages
                                        • GliderGuy
                                          • 1412
                                          Good job HT.
                                          Fortunate that you took the time to read and implement the tips.
                                          If you kangaroo bounce and the nose retract servo survives, then count your blessings.
                                          It’s recommended you keep a few nose retract servos on the shelf. Even on calm days, if you go to sleep during landing, you will eat a nose retract servo.
                                          Keep a plastic nose servo mount or two handy.
                                          She’s a crowd pleaser.
                                          -GG
