Official Freewing 90mm Eurofighter Typhoon EDF Jet Thread
  • Woohoo\o/
    • Feb 2020
    • 186
    • Cape coral Florida
    Originally posted by paulrkytek
    Turnigy 5000mah 60/120amp = 60x5 = 300 amp continuous. Basically 5000mah =5amp x60 = 300 amp continuous. If the edf is drawing 120 amp max you are well in. Turnigy Nanotech 3300mah 35-70c 1 115amp cont ​ . i,e. 3,3ampx35. 120amp edf will be pretty much toast vey quickly as you are asking to draw more amps than the lipo holds.. Chris Wolfe RC Geek does a good video on the subject. in theory 4000 mah 60c minimum rating gives 4x60 240amp continuous which logically is double the max the edf can pull from it. Flight time will be less than a 5000 mah 60c. To guestimate flight time I use the following formula :-edf power calc for Avanti rhino 4000mah 50c 4/55x60x0.70 = 3 mins i.e 4amp hr battery consuming average of 55amp over flight time. The tricky bit is guessing the average power consumption and that depends on flying style. If the flying time is known for the Eurofghter on a 5000 you can use the formula to work out the ave amps consumption ad feed that back in for 4000mah to get a light time for the 4000. It works for me ! The Hobby Eagle A3 lite basically is a windy day gyro to smooth out the bumps, either on or off at the rates you set it at on a 2 way switch, no auto level. The A3 super 4 is a bit more feature filled, allows auto level, servo reverse, individual gains amount on rudder, elevator and ailerons. It also has 2 aileron and 2 elevator outputs which gives you more control and more choices such as servo reverse on say left and right canards and servo reverse on left and right tailerons I would suggest you ask Motion r.c. customer services if the A3 Lite works ok with the Eurofighter and how it is wired bearing in mind the canards. I prefer an auto level gyro to give me that extra second of recovery time in moments of lost orientation/brain failure . ​​
    Thanks for the info. Very useful information. As for the eagle a3L I’m sure will work out just fine with the euro. I’ve used it on all my previous 80/90mm freewing jets including the older version of the eurofighter. I’m definitely liking the sound of the extra features of that super eagle gyro.
    • Woohoo\o/
      • Feb 2020
      • 186
      Is it necessary to mod the battery bay in order to fit an HRB 6s 5000 pack further back?
      • paulrkytek
        • Jun 2019
        • 542
        • North of England
        Freewing version of super4. Worth watching the video https://www.youtube.com/watch?v=4KIT9KenYYA
        • Woohoo\o/
          • Feb 2020
          • 186
          I ordered one. I’ll put the eagle lites on my hsd 200 and hsd viper. Thanks.
            • 5426
            From where? Motion shows them out of stock.
            • paulrkytek
              • Jun 2019
              • 542
              • North of England
              did you order the programme card at the same time ?
              • kallend
                • 1877
                Just be aware that "C" ratings are for the most part just inventions of the marketing department.
                • Woohoo\o/
                  • Feb 2020
                  • 186
                  Yes I did
                  • Woohoo\o/
                    • Feb 2020
                    • 186
                    How reliable is the control board? (I’m also asking on other forums).
                    • Reptielenfreak
                      • May 2024
                      • 153
                      I recon its the same as the other freewing models, i havent seen any negativs.
                        • 5426
                        There are a few people that have had issues and when one causes a crash it’s a major issue and, rightly, they are vocal about it.
                        • kallend
                          • 1877
                          The ones in the early release had glacially slow retract sequencing speed. But it was reliably slow.
                          I'm told the recent ones are faster.
                          • Woohoo\o/
                            • Feb 2020
                            • 186
                            From motion. They had them when I ordered them. I checked now they still say in stock.
                            • Airguardian
                              Post Stall Svengali
                              • Aug 2020
                              • 1688
                              • Catalonia
                              This jet is friggin' awesome and it shows!!
                              • Reptielenfreak
                                • May 2024
                                • 153
                                Looks awesome, im thinking about getting one.
                                so i was told it came with some tail weight? Did you add +-30gr extra or just the +-30gr in the tail?
                                  • 5426
                                  When I put mine together I expected a very nose heavy plane so I bored a hole in the tail cone to allow TWO of the 21g slugs. One that cam e with this plane in the parts bag and a second I had removed from another plane.
                                  • kallend
                                    • 1877
                                    And if you need more:
                                    https://www.thingiverse.com/thing:5899318
                                    • Mustang95
                                      • Oct 2024
                                      • 4
                                      • DFW Texas
                                      Absolutely my favorite EDF hands down!
                                        • 2716
                                        Sweeet! Looks like the absolutely perfect Fighter Jet Landing!! Love your livery as well.
                                        • Airguardian
                                          Post Stall Svengali
                                          • Aug 2020
                                          • 1688
                                          • Catalonia
                                          Flying to music at a recent event ^^
