Official Freewing 64mm F-14 Tomcat Twin 64mm EDF Jet Thread
    • 5397
    Auto, shown in the video.
      I got plans to run full pan and tilt digital fpv on this one, pilot and rio positions, per my normal setups.
      • 3D-Seth
        • Mar 2023
        • 35
        Originally posted by kallend
        Since you appear to have information on it: Are the flaps automatically raised when the wings are swept back, or does that have to be done manually like on the 80mm version so as not to break the flaps?
        There is electronic programming in the sequencer/gyro to prevent any issues. If you have the flaps down, the wings won't sweep. If you have the wings swept, the flaps won't go down. Wes goes over it around 20 minutes into the assembly video that is on the product page if you want to see what I mean.
        • kallend
          • 1874
          Thanks. On the 80mm one I had to program that into my transmitter.
          • hcew
            • Nov 2020
            • 10
            I'm looking in the Europe warehouse, but nothing to find.
              • 5397
              Read this thread and you will be enlightened.
              • James
                Administrator
                • Aug 2017
                • 1543
                Join us live at 2pm EST today for a Q/A session with Wesley about the F-14. He will have the model on the table and will show everything you want to see. Join us!
                • aRCe
                  • Jul 2021
                  Any grass ops videos planned? It helps for the pilots to determine if this gorgeous model will work out for them on their grass fields.
                  • Tom
                    Super Moderator
                    • Sep 2013
                    • 905
                    You are likely wondering who 3D-Seth is? Seth has been at Motion RC a bit over a year. He is a highly skilled product manager/developer here at Motion RC. Seth can answer loads of your questions about this plane.
                    • Cape Jets
                      Member- Jet Jockey
                      • Dec 2020
                      • 120
                      • Cape Cod, MA
                      Well my Arrows F-15 lost signal today and had a nose on encounter with mother earth So perfect opportunity to pick up an F-14 ARF version, so I just did
                      The Freewing 2500kV EDF's and 60amp ESC's as well as the 7 Channel receiver I had updated in the Arrows F-15 will work great in the F-14. Should be here next week. Can't wait......
                        • 5397
                        The F-14 needs more than 7 channels unless you bypass the gyro and reversing.
                        • Cape Jets
                          Member- Jet Jockey
                          • Dec 2020
                          • 120
                          • Cape Cod, MA
                          Already figured that out, I'm taking a AR 8020T receiver out of my T-33 for the F-14 and putting my now extra RX637T receiver in the T-33. So problem solved. ​
                          • kallend
                            • 1874
                            I just watched a video by Wes where he says that out of the box his gyro was connected with the pitch correction reversed, and he showed how to correct it.
                            I hope all purchasers check their gyro function!
                            • kallend
                              • 1874
                              AR10100T going in mine.
                              • kallend
                                • 1874
                                Mine arrived:
                                1. The gyro is correctly installed.
                                2. If you don't plug in the gyro mode lead, the gyro defaults to "basic gain" (rate) mode. If that's all you want, it saves you a channel.
                                • HamiltonsHangar
                                  • Feb 2021
                                  • 13
                                  We added the KM RC Model double
                                  Universal afterburners in the New Freewing F-14A They look amazing!! Just a slight modification needed for these and the stock screws do not fit because the 64mm has smaller holes than the 80/90mm EDF units. We also added in scale lighting to the back for the strobes, and the nose light, as well as the additional pilot will be placed in there tonight! I do not have any additional small green lights at this time. Otherwise I would have one in the cockpit as well. The maiden will be tomorrow if the wind is not as bad. We are super excited!! Motion RC #HamiltonHangar​
                                  • MJG3
                                    • Jan 2024
                                    • 2
                                    well went ahead and bought it today
                                    • kallend
                                      • 1874
                                      How hard was it to thread the wires for the afterburner through the fuselage? Did you have to remove the perforated cover over the ESC compartment?
                                      • handyman220
                                        • 160
                                        Told myself I really don't need another F-14, but the smaller size was too hard to resist along with all the upgrades. The hard part is going to be explaining it to my higher authority.
                                        • Pete914
                                          • May 2019
                                          • 18
                                          Man I love how Motion operates. Super fast shipping on the East Coast.
                                          Seems like mine arrived in good shape. The wings look tiny! I'm sure it will have some presence though when put together.
                                          Stoked :) Click image for larger version
ID:	398949 Click image for larger version
ID:	398950 Click image for larger version
