Official Freewing 64mm F-14 Tomcat Twin 64mm EDF Jet Thread
  • EDF-Jetpilot
    Jets are a lot of fun
    • May 2024
    • 134
    • Aarburg, Schweiz
    Traumhaft schön!
      • 8217
      V2 has arrived! The finest flying foam EDF F-14 on the market. Click the link below to see what the hype is all about!
      Get yours ASAP, these puppies will not last, guaranteed.
      Freewing F-14 Tomcat Twin V2 64mm EDF Jet - PNP
      Buy Freewing F-14 Tomcat Twin V2 64mm EDF Jet - PNP online at Motion RC. Order online with fast delivery.
      Freewing F-14 Tomcat Twin V2 64mm EDF Jet - ARF PLUS
      https://www.motionrc.com/products/fr...plus-fj11421ap
      • freakbrother
        • Jun 2022
        • 16
        • Ottawa, IL
        Why a V2 so soon after the initial release? Meanwhile the 2015 version of the 80mm, which could really do with a makeover, continues.
        Does the new wing fix the tip-stall issue? If so, can it be retrofitted to the V1?
        • JamesonC
          MRC fanboy
          • 619
          • Laurens, SC
          A V2 of the 2024 released 64mm F14 instead of the 2015 released 80mm F14........someone make it make sense!!! Please do the V2 twin 80mm F14 already!!!! :sob:
            • 5397
            My opinion is that the 64 hasn't sold well (for the reported wing tip stalls maybe) while the 80 is still selling well. I'm waiting for a V2 80 with 2150's, 100A reversing ESCs and the rescue decal not upside down.
            • Quickstopdf
              • Jun 2023
              • 2
              Yes! New wings can be retrofitted according to Wes on the video
              • stitch
                • Dec 2014
                • 142
                Well was wanting one but not red, hoping they do this one with improved foam on leading edges around battery hatch like they been doing on there other planes. For that price I pass!
                  • 5397
                  Already asking for a V3...
                  • JamesonC
                    MRC fanboy
                    • 619
                    • Laurens, SC
                    He'll get it before I get a V2 80mm. :worried:
                      • 8217
                      The mold prices on the 80mm are astronomical. Trust me, it's not like Freewing doesn't want to release an updated 80mm version. Personally, as much as I would want a 80mm with all these upgrades and latest tech, I am happy they are at least offering something that still gives you similar presence with a less-taxing wing load and more aerodynamic wing. I want one!
                        • 5397
                        Nothing I want would require new molds.
                        • kallend
                          • 1874
                          How about a nice 80mm Hawker Hunter, then?
                          • f4u ausie
                            • 1239
                            • Melbourne
                            I like the V2 scheme
                            • Tcwoodie
                              • Mar 2021
                              • 2
                              What spektrum reciver are you using.
                              • Tcwoodie
                                • Mar 2021
                                • 2
                                So I want to use my nx8 so what reciver are you using with there gyro, or pulling it and going with a spektrum receiver.
                                  • 8789
                                  Originally posted by Tcwoodie
                                  So I want to use my nx8 so what receiver are you using with there gyro, or pulling it and going with a spektrum receiver.
                                  It shouldn't matter what RX you use so long as it has enough channels to do what you want. Since you only have an NX8, you are restricted to 8 channels*. You'll have to decide what you can do without - reverse or gyro mode. If your RX has a built in gyro, you need to choose whether you want the RX's gyro or the stock Freewing gyro. Whichever one you don't want, go into the programming and set all the gains to ZERO. Personally, I would prefer to keep the stock gyro as it's already programmed to fly the plane as it was meant to.
                                  * If you really want to do everything you can do with this plane, you can do so by going with Spektrum smart RX, Spektrum smart ESCs. Then things get a bit more complicated. Are you good with Spektrum stuff and a bit more of "complicated"?
                                  • kallend
                                    • 1874
                                    Not true. The NX8 can send up to 20 channels if it has been updated to firmware V4.00 or later (2024-May-08). You run out of switches and knobs before you run out of channels.
                                    Details here: https://spektrumrc.cachefly.net/chan...Log_v4.01A.pdf
                                      • 8789
                                      I believe it is TRUE, because my statement had a caveat ----- (please read what I put a * in front of) That caveat being that he MUST also use a Spektrum smart RX. If he used a Spektrum compatible RX like, as an eg., a Lemon RX, those remaining 20 channels do nothing. Additionally, if he does NOT have Spektrum smart ESCs, those ESCs won't understand what the RX is trying to tell them, no matter how many of those extra channels are used. A non-Spektrum smart ESC will still need to be hardwired into an unused port.
                                        • 8789
                                        Aside from what I said in post #176, you would need a 9 or 10 channel receiver. Only then would you have the port to plug that gyro mode lead or reverse lead into. Or, as I said before, if you are using only an 8-ch RX, you must eliminate one or the other (gyro mode or reverse).
                                        Sorry, I keep not answering your question. I use a Lemon 10-ch with satellite, with the gyro NOT activated and keep the stock gyro. You can also use a Spektrum 10-ch RX, again don’t activate the gyro if it has one and go with the stock one. Your NX8 will work either of these.
                                        • f4u ausie
                                          • 1239
                                          • Melbourne
                                          U tell em viper. :exploding_head:. Thanx 4 all ya(correct help):hugging:
