Just took the plunge myself and actually ordered the 8’s version. Looking forward to setting up hopefully maiden this weekend, planning on doing the battery tray mod and see about stiffing the front gear spring as was suggested for grass ops. I went duel 4K 4400 4’s packs so I can save my 6s for my other jets. Either way will post on how things go she’s a beautiful plane, seems to be another FreeWing Motion hit keep it up guys
I just got my packs in running SMC green 4400’s and have a set of ChinaHobby 4500 packs coming also. Once SMC gets some 4s hivolt packs in of course I have to run them. Put her together yesterday still need to do a battery tray mod hook and set up the AR10360t+ then install the KMRC blue burner. Hopefully I’ll maiden Sunday or early next weekComment
So have a question, like a few others, mine came with a red ESC, wanting to replace it, I see the replacement one is out of stock. However, the old F-16 (V1) in the replacement parts for it, has the ESC with identical specs it seems to the new one...including thrust reverse. Is this the same ESC as the V2? I did reach out to the tech support and was told " the internals" are different.....not sure what to think...Comment
Assuming you’re running 6s? I can’t answer on the Eflite ESC but I have the blues in all of my 90’s without any issues at all. My 90 F16 is 8s currently running 2 4s 4400 Green SMC’s, just got in 2 hivolt 49/4200 packs. Think I’d would rather go 5000 myself mixed flying so far getting 3 min from the 4400’s maybe the hivolt packs will do better will update as I get to try em out. 12th flight on the F16 today finally have her dialed in, I’m 2 fingers behind factory CG marks which seems to be the sweet spot for me, I have had to turn down gains had some oscillation going on at higher speed flights. Running a AR10360t+ high speed gains asset 18/26 no more oscillation of course for alphas gains are raised. I am running tailerons saw no need in flaperons or thrust reverse in my grass field, one suggestion check you front retract trailing arm set screws mine were loose caused front gear to collapse fortunately no damage other than the front gear door which I made my own hinges as stock doors are out of stock still. One speed pass in level today she doesn’t do bad at allSo have a question, like a few others, mine came with a red ESC, wanting to replace it, I see the replacement one is out of stock. However, the old F-16 (V1) in the replacement parts for it, has the ESC with identical specs it seems to the new one...including thrust reverse. Is this the same ESC as the V2? I did reach out to the tech support and was told " the internals" are different.....not sure what to think...Comment
Have the 8S version but yet to build. What are the thoughts on flaperons ? If I want to get it as slow as possible for landing, flaps and tailerons? I have watched 2bros and it looks like it handles really well.
Any pointers , will be running ELRS receiver .Comment
On the F-16, if you use flaperons, you should definitely use tailerons (on the elevator), otherwise the landing approach will be spongy and difficult to control. If you do it this way, you can land much more slowly than without flaperons, but only with tailerons on the elevator. Yes, 100% servoweg of taileronsComment
