    • 8202
    The F-18 problems are the result of the lack of working leading edge flaps. LEFs imcrease the usable sustained-high-alpha range and fix the nasty stall that haunts the airframe, as demonstrated by many people already, who modded the jet with working LEFs ;)
    IF FW develops a new gen version, I hope it comes with LEFs! That and/or a slightly lighter wing load.
    • Airguardian
      Post Stall Svengali
      • Aug 2020
      • 1662
      • Catalonia
      Fully agree. Lighter wingload would be great, but working LEFs would work better and make the jet more interesting ;)
      • Airguardian
        Post Stall Svengali
        • Aug 2020
        • 1662
        • Catalonia
        Originally posted by Elbee
        Airguardian.
        Where do suppose I might find a picture of two of said modifications?
        Best, LB
        Hard to say... they were sent to me privately through Discord and Facebook Messenger, sooo...
        I could bug a friend to post his 3DP files somewhere though.
          • 4814
          AG,
          I could design it, just like to see his methodology.
          Did he cut off and reuse the OEM LE? Does it drop downward, slide forward, or a bit of both?, stuff like that.
          Always thought an additional 0.5" at the root and a 0.5" at the tips 2" overall in wingspan would help and still not ruin the wing shape.
          Fun things to ponder.
          Best, LB
          • f4u ausie
            • 1224
            • Melbourne
            Lb. The more complicated... The more interested U r. Luv it
            • Airguardian
              Post Stall Svengali
              • Aug 2020
              • 1662
              • Catalonia
              One did exactly that, just cut the wing's LE and hinged it on the top side. The other didn't cut anything, but made a LE extension that fit on top of the original LE. It hinges on the bottom in a way that when deflected, the top part doesn't leave a gap. This one, you could say extends forward a bit. The good thing about this one is that in the fully up position you know it can't deflect up under heavy loads because it sits tight against the original wing's edge, so it has some extra safety.
              Edit: Just a disclaimer, I am talking about the FW F-18 here, not the F-16!
                • 4814
                Hah,
                Mom always said, "Use your powers for good."
                Truthfully, I'd thought about the LE mod when I was building my Hornet, but she was already getting heavy with the cockpit, extra lighting and repaint.
                I sketched an LE extension that moved forward and went looking for LE material.
                That's as far as I went, so now it's a someday project for another airframe.
                Best, LB
                  • 4814
                  Thanks, AG, both are great ideas.
                  Best, LB
                    • 8746
                    Don’t know if this link will work. It’s from a Facebook video about LE thingie.
                      • 4814
                      https://www.facebook.com/share/r/1D1...ibextid=wwXIfr
                      xviper Airguardian
                      Thanks, great vid.
                      Beautiful design, though a bit more radical than I had in mind.
                      Flexing the wing skin, WOW.
                      I'm thinking more an open framework cam & pin attached to a separated LE.
                      This is not my original drawing, different author, in theory the principle would be similar.
                      Linear servo(s) for deployment; could be mixed with "Flap switch, Throttle setting, both???
                      Great vid.
                      Best, LB
                      Click image for larger version  Name:	LE Slats bw.jpg Views:	0 Size:	7.8 KB ID:	445701
                        • 8746
                        Like all the "firsts" put on modern day RC planes - sequential gear doors, LED lights, quick attach wings, reverse thrust, thrust vectoring, flight controllers, "blue boxes", pre-tuned gyros -- Leading edge slats may be the next "big thing" in model aircraft. A great time to be in this hobby.
                        • Airguardian
                          Post Stall Svengali
                          • Aug 2020
                          • 1662
                          • Catalonia
                          That wouldn't be scale for a Hornet though. Hornets (as most modern fighter jets), use leading edge flaps, not slats. They don't leave a gap nor extend forward, only droop down. ;)
                          As for implementation logic, I'd go for the following:
                          1 - Droop down with flaps. (Easiest)
                          2 - G-force induced through telemetry. (The higher the Gs, the more droop, on a ramp that went from 1.2Gs to 4Gs, 0 to 100% deflection, for example. This would need fine tuning though).
                          3 - Alteratively, gyro controlled (unidirectional) so that when there's pitch up rate, the LEFs droop down).
                          4 - Pitch input linked (Droop down above certain elevator stick input).
                          5 - Switchable offset (Drooping down on a 2 or 3 position switch like flaps, but without flaps, for things like sustained high alpha).
                          Ideally you'd only want them to be actuated as a function of AoA, but estimating AoA on a model aircraft isn't trivial, so the options above cover some of the scenarios of interest.
                          • f4u ausie
                            • 1224
                            • Melbourne
                            Keep up the teck stuff guys. Goog learning
                            • 400driver
                              • 38
                              Finally getting around to opening this box up, was planning on flaperons and tailerons.
                              Can someone offer some guidance as to how much deflection for take off and land flap settings?
                              Air Guardian , i see in your videos you are using flaperons, cant quite see how much you are using.
                              Many thanks
                              Mark
                                • 5384
                                I use about 5mm for take off and 10 for landing. 50% taileron mix.
                                • Gopher
                                  • Oct 2019
                                  • 16
                                  Concerning making or adding Leading Edge Flaps/Slats (LEF). I am not a good scratch builder, and I decided to add LEF's to my F22 for slower landing. I added two servos and connect both to my main (right and left) flaps. I am not a good pilot and like slow flying and landings. The LEF's solvd my problem. Pics attached.
                                    • 4814
                                    Gopher,
                                    Great modification...well done.
                                    Best, LB
                                    • 400driver
                                      • 38
                                      much appreciated
                                      • Airguardian
                                        Post Stall Svengali
                                        • Aug 2020
                                        • 1662
                                        • Catalonia
                                        Many thanks
                                        Mark
                                        I don't know where I left my measurements... but it's probably about 7-10mm for take off and 15-18mm for landing (Measured at root).
                                        • 400driver
                                          • 38
                                          I will try that ! Thanks.
