Official Freewing 70mm F-16C Falcon V2 Thread
    Leave the ESC, where it is is a good place in air flow for cooling. Moving it you'll need to do a lot of soldering too.
    Agreed. It's where it is because of the cooling factor but I may have to move it forward if there continues to be a balancing problem. It was a hard decision between the two places because there were other concerns. Besides the balancing, it's prudent to have the motor wires long and the batt wires short. That way I wouldn't have to add caps.
    Not afraid to solder but there's also crimp connectors.
    • Originally posted by Suprawill1 View Post
      70mm RC Lander 2200kv EDF and a 100A ESC. Another difference is that I have a 3200mah which is probably lighter than the 4000 pack. A 4200 is on the way but in its own right is a bit light for its amperage. 440.4g as opposed to the 3200's 394.8.
      Well, there you go. No doubt that's why you're having a CG problem.
        Not sure which case you're referring to. The ESC, the EDF, the battery, the position of the ESC?
        • So, it seems I will have to relocate the ESC to the front to get a practical CG. The heaviest battery I'm going to use will almost get the right CG and that's moved as forward as possible. Don't mind doing this but I won't get the airflow I would in back. Not too worried about that though because it was forward in the V1 F-16 I had these components in and there were no ESC heating problems.
          • My Fw F16 with very high perfmance, dis som mods to it..
              • Nice flight! What did you do to create more airflow to the fan?
                • Comment
                  • I didn't find a thread for the eFlite F-16 70mm so here's a flightvideo of mine which I repainted into a Japanese F-2.
                    The video was recorded during a really nice EDF meeting in Venlo (NL) some weeks ago.
                    Enjoy!
                    • Originally posted by Icarus the 2nd View Post
                      Enjoy!
                      Nice, and nice afterburner!
                        Enjoy!
                        Good looking F16 and smooth flying. Earlier this year I put aside my F16 in favour of other models but my uprated suspension arrived yesterday so its now ready for a re maiden on Monday. FMS 70mm 12 blade 3060 1900kv fan and flaperons. I use take off flaps off our grass runway.
Name:	F16 tiger sept 2.jpg
ID:	356983Click image for larger version
Name:	F16 tiger sept 1.jpg
                        • Marvelous flight. Skilled pilot. Wanna see more flight video.
                          • Maiden flight of my F16 70mm today.
                            • Unlimited vertical wow.
                              Was asking if anyone knows is the FMS and the e-flite F-16 70mm the same foam airframe, are the parts interchangeable?
                              • Oh, I think so. The FW is not.
                                • That is what I though. I remember hearing that on a H.H. Video.
                                  • The video was of the FreeWing one. I didn’t see unlimited vertical in the video, did I miss something?
                                    • Yes that was a Freewing. The H.H. Video was for the Eflite F-16. It was a release video I think.
                                      • Originally posted by Iamrcpilot View Post
                                        Not the same airframe, See Merry Boozer comparison video
                                        • Comment
