I did this mod some time ago and I think it was a great thing. It allows the battery to move as far back as possible and drops the ESC down into the airflow as mentioned. With the battery at the back, the tailpipe should drop slowly to the ground. I got that from an old YouTube video by an Aussie who posted as : KJetgirl : FREEWING F86 SABRE 80mm JET HANDLING DEMO NARRATIVE... -
Anthony,
Not sure if you've done this mod yet but it you haven't, trust me it's worth doing. This bird has a huge CG window especially for a swept wing fighter. She will fly sweetly with anything from a 4000mah to a 6250mah battery all in the exactly the same location.
Unscrew your ESC and place the wooden brace below it on the side of the intake and screw it from the bottom, take a dremel cutting disc and cut off the excess lengthon the screws. It creates a little recessed shelf for your esc to fit into, the battery holds the ESC in place from the top. Placement puts the ESC in the airflow of the intake for better cooling and allows you to place the batteries dead smack on the CG, back up against the foam bulkhead. You can fly with any 6s 4000mah or larger that will fit under your canopy, (I shaved a heck of alot of foam off the inside of my canopy, personal preference, nobody see's the inside anyway and I like to have battery options), and you will always be on CG.
As for elevator mix with flaps, I land my F-86 with flaps full the majority of the time, max mechanical travel, and have never needed to mix in any elevator.
Let me know if you need pics for the mod.Leave a comment:
I dont have any mix set up on the radio, but have a tendency to fly this thing a little nose heavy. I'd just take it up and see how it reacts, i dont think it will balloon on you.Leave a comment:
If it's anything like the smaller version of the F86 you wont need much elevator mixed in with your flaps at all. I would start with a small amount of up elevetator. Maybe 5% and see what it does and then adjust from there.Leave a comment:
Hi guys,
I just finished up setting up my radio for the F-86. There is no specs in the manual for the flap/elevator mix. Can anyone tell me how much elevator you are mixing in with the flaps ?
Thanks!!
AnthonyLeave a comment:
Just make sure you don't breathe in the dust from cutting anything carbon (carbon fiber).
Also, if you have any small camping tents that are probably never going to be used you can rob one from that.
Thanks!!!!!!The Avanti wing tube is 8X450mm so grab one and take the Dremel cut-off wheel to it.
https://www.motionrc.com/products/fr...rbon-wing-spar
Thank you for the help!!!
Just about any Kite shop has carbon tubes. 8mm is .315".
Here is an example: https://www.kitesandfunthings.com/Pr...ULTTUBE36.aspxLeave a comment:
https://www.motionrc.com/products/fr...rbon-wing-sparLeave a comment:
Just about any Kite shop has carbon tubes. 8mm is .315".Help! Trying to find carbon tube wing spar, for my Freewing F-86 80mm. I crashed one of my F-86s last summer, and during this Covid19 stay at home time, I've rebuilt her.....everything repaired, like new..putting back together AHHHH!! I forgot the wing spar carbon tube had been broke in the crash.
I went to MotionRC site and didn''t see the part listed. Googled online, and places that sold 8mm x 5mm x 280mm are all out of stock that i could find without ordering from China. Anyone know of a source so I can get this bird flying again??
I went to MotionRC site and didn''t see the part listed. Googled online, and places that sold 8mm x 5mm x 280mm are all out of stock that i could find without ordering from China. Anyone know of a source so I can get this bird flying again??Leave a comment:
Hi guys,
Callie is going to make the red, white and blue stripes for the fuse and drop tanks for me. I have taken measurements for her to use making the stripes. I will post some pics once it is finished.Leave a comment:
Thanks guys,
I have liked the F-86 in this paint scheme since I was a kid. I was worried while doing the painting that I might not get the proportions right and the angle of the blue/silver separation line would not be on the correct angle to match the black/white USAF decal. I have emailed Callie asking her if she can make me the fuselage stripes if I supply the dimensions. I would hate to spend a hundred bucks buying six different rolls of pinstripe tapes.
Later!!
Bravo Zulu, Sir. Best, LB
