    It's not hard to see the difference between the 80mm and 64mm plane. The 64mm plane is tiny and it's a hand tosser (700mm wingspan vs 1200mm) Also, a 64mm fan is NOT going to have a 64mm exhaust hole at the back of the plane.
  • Herp_Derpula
    If it's an 80mm fan, it'll be a 6s system, so if you put a 4s battery in it, I'm surprised it actually flew. Those early 80mm Sabres, even on 6s, were quite anemic. It likely also has the 80A ESC in it. The newer, "high performance" ones, have 100A. Do you know if it's an 80mm fan or is it the smaller plane with the 64mm fan.
    Without taking it apart, I honestly couldn't tell you. I would bet its an 80mm because I found a video of the old owner flying it and it didn't look too bad, although it was using concrete for a runway and not grass. To clarify, I did not fly it on 4s lol I just read somewhere about there being a 4s version and didn't want to throw 6s at it full throttle on launch without knowing.
    I suppose without taking it apart I can't really check if it's 80mm? I measured the outlet on the back of the plane and its right around 64-65mm on calipers. If I open the calipers to 80mm and put it near the fan it does look to be 80mm and not 64mm. I'll attach a picture, not sure how helpful it'll actually be. Looks like I can pull the wing off with just four screws.
    Originally posted by Herp_Derpula
    I just picked up one of these from an old friend, and it appears to be the older 12 blade version. The ESC has the heat shrink cut off where the label is, so I'm not sure if this is a 4s or 6s bird. I'm leaning towards 6s, especially since its underpowered, but it's hard to know. It powered up fine and took a quick burst of full throttle on 6s, but continuous who knows. It was bought prior to 2016, don't know the exact date.
    Does anyone have insight? I'd appreciate it! Lucky for me it came with a flysky rx and some no name stabilizer/gyro and I could bind it directly to my Jumper T16 MPM. A bit concerned with the range, so i may put a crossfire 915mhz control link in...
    If pictures would help, let me know :)
  • Herp_Derpula
  • gooniac33
    Originally posted by Jbkinwa
    I am showing 318g for unit weight. Amp draw is 67-75. Hmmm I am not seeing a huge improvement. 2.5-2.8 Kilograms thrust with my current unit. I have 600’ of close cropped grass to fly from. I should be able to fly as is. Thx
    The newer 9 blade is a pretty significant increase in performance over the outrunners. They even have a 12 blade inrunner that would do well in this bird too but the 9 blade is the lightest. I have seen it fly at my field with the new set up and it moves really good!!
  • Jbkinwa
    The latest "Tiger Meet" Mirage comes with the inrunner, 9-blade, 3658 1920kv ................. Static Thrust: Around 3.0Kg - 3.1Kg (93A).
  • Jbkinwa
    I haven’t been able to find the spec sheet on the new power system. The manual available is still the one from a couple of years ago. I bought the version that was supposed to be the 3530-1750 Kv w/ 12 blade. I actually received the 3530-1680 KV with 12 blade. 80A esc. The improvement note in my manual rates it at 2500g or 88.18 oz.
    Does anyone have the improvements notes for the 9 blade version?
  • Laserdude
    Originally posted by greg
    has anyone measured static thrust with the upgraded 86?
    I just did. My method is not very sophisticated. With the plane setting on its gear I tie a string around the main gear and attach an electronic fish scale. I ran it up twice and got 4.5 pounds on both runs. That was on a fully charged HobbyStar 6200 50C pack.
  • greg
  • PHF
    Excellent work on the drop tanks.
  • paulrkytek
    Originally posted by Builda
    I never got around to adding my drop tanks, and now i prefer it without them added so possibly never will-had mine 4 years, fantastic plane! No plans to swap the fan, the 12 blade outrunner works just fine. Photos on the runway at Tokoroa, NZ last summer.
    Looking good Builda, thats a lot of years relaxed flying ahead, enjoy them all.
  • Builda
    paulrkytek, I like it big time. Great work on your Sabre. Best, LB
  • paulrkytek
    Decided to paint the drop tanks for better visibility in our grey sky
  • paulrkytek
    Here is my F86 Sabre Ultra High Performance version converted from Mig Killer to Covid 19 Killer complete with not one but two top secret totally unproven magic blunderbusses of ultra sonic light and virus seeking death rays. Cannot wait to get those little covid kill stickers mounting up next to those little red stars!!!! If it doesn`t work I suppose they will have to do for landing and position lights. Oh yes and seasons greetings to one and all from Paul.
    paulrkytek , Nice modification. Could double as a 'gun fire' mod as well Best, LB
  • paulrkytek
ID:	288817Click image for larger version
ID:	288815 lights fitted, just the weathering to sort out now, the photo gives white out to the red and green but to the naked eye it works well, hence the green with lights off Click image for larger version
  • paulrkytek
    Very nice PHF, its definitely been worth the time and effort
  • PHF
    I just love the new big motor version, but wish they would update the plane, Compared to my T-33 it's a little crude. However it is still my all time high favorite plane. Here is my new one done up as a CL-13 Mk6.
