Anyone else not impressed with the 80mm 9 blade fan combo? My buddy just got one of these and it’s not very fast, not that it’s suppose to be a speed demon but it really isn’t that impressive.
Originally posted by T-CAT View PostFor a PNP unit, one draws roughly 100A, and that is reasonably priced, I have been impressed with the performance of the new 80mm EDF 9-blade 1920kv inrunner motor system.
This may sound obvious, but can be easily overlooked, but did you calibrate the ESC's throttle range?
Hans,
ESC programming guide is located in the Support tab of each plane that uses it.
https://cdn.shopify.com/s/files/1/10...iles/fwesc.pdfPat
Originally posted by Wrthog View PostAnyone else not impressed with the 80mm 9 blade fan combo? My buddy just got one of these and it’s not very fast, not that it’s suppose to be a speed demon but it really isn’t that impressive.
Mike\"When Inverted Down Is Up And Up Is Expensive\"
Not true checked it for both eu and states
T-33 Shooting Star USAF 80mm EDF Jet - PNP from Freewing - FJ21715P Version Info: This version of the T-33 now comes with the updated 3658-2150KV inrunner brushless motor with 12-Blade EDF. Motion RC is excited to announce the new Freewing T-33 Shooting Star in 1/9.5 scale. Honoring the popular T-33 that flew with over
T-33 Shooting Star USAF 80mm EDF Jet - PNP from Freewing - FJ21715P Version Info: As of 4/28/2023 this model now comes with the upgraded 3658-2150Kv inrunner brushless motor and a newly designed 12-Blade EDF. Motion RC is excited to announce the new Freewing T-33 Shooting Star in 1/9.5 scale. Honoring the popular T-33
grts Hans
Originally posted by ClintonStrate View PostI have a T-33! I love it was a little Disappointed in the speed. Is there a way to calibrate the ESC. I am running a gen ace 45c 5000 pack. It just does seem to perform like the video with the speed. Any suggestions would be great
You can calibrate the ESC. Look at the Hobbywing ESC manual. Basically, plug the battery into the model, turn the radio on with the throttle on high and wait for two beeps if I recall correctly, then reduce throttle to zero. It should be calibrated. There should be a manual for the T-33 in the support section on the MRC web page. If not, check another plane that shares the ESC, they're all the same for the 100A's.
PS - I've tested my "good batteries" against my "bad batteries". Both brand new, or nearly so. The "good batteries" are good for 7 more mph on the top end. I didn't expect that kind of a difference, but it's there. If you have really poor batteries it could explain the issue.
The best way to calibrate the ESC to your TX throttle stick:
1. Turn on the radio, move the throttle to full.
2. Plug in the battery, and as soon as you hear the first beeps stop from the ESC, move the throttle stick to off.
3. Unplug, turn off everything, then back on to test. You should be good to go from there.Pat
Originally posted by Cws View PostI have a 80 mm fan from my late Eflight F4 phantom. Does anyone know if it will drop in fit the T 33 without modifications??
It will require modifications, but they're not too bad.
I really like how my T-bird handles, especially after removing the nose weights. Now the nose doesn’t drop as fast on knife edge. Might even attempt to hold it for the length of our 650 ft runway next time. For now quite content with how the point rolls and basic aerobatics feels. Aiming for precise handling then flat out speed flying. Thinking about what other moves I want to include in aerobatic routine. Any suggestions?Flying RC EDF Jet precision aerobatics using head-tracking high definition FPV view in cockpit. Best viewed on large screen. 0:00 FPV Aerobatics Takeoff 0:36...YouTube: https://www.youtube.com/user/motionsic
