  • Kangi1954
    Originally posted by glyrenden View Post
    Yes It work well for me. At that mark, with out the batteries, it is very tail heavy and I choose to use the 5s 5000 to add the weight. I was going to use smaller batteries, but better live weight then dead weight. I had to move the batteries as close to the steering serve as I could to get it to balance.
    Thank you. The information you included on your maiden video was very helpful as well. Always good to know what works.
  • glyrenden
    Originally posted by Kangi1954 View Post
    Welcome to the forum. Nice job on the build and maiden flight! Did you find the specified CG at 85mm from leading edge worked well?
  • wrangler1
    X Wave retracts are in stock. Just ordered mine.
    Rick
    I just ordered 2, just in case
    jejeje
  • Kangi1954
    Hello all,
    I've been lurking and following for a while.
    Wanted to share with the group my first flight with my Bronco. Just a Short testing and Triming.
    I'm really happy with this model. flew great with almost no need to trim anything. I'll post more video when I get out to fly it again!
  • sam51401
    Good to have TLAR and glyrenden onboard and to share their setups on this Bronc. I have my wing and fuse center recovered and doing flight surfaces next. Im toying with some ideas on making some closer to scale functional main struts and a semi opening rear fuse fairing but i rather get this flying and go back later for that. I think it was wrangler that posted about battery sizes and the room under the cockpit tub may not allow 6s 6000ma batteries. Any further thoughts or pics on that as most of mine are 6s 5000 on up for my FW EDF's.
  • wrangler1
    Hello all,
    Great Video , thanks !!!
  • MikeT
    Hello all,
    Great. That's the same power set up I'm planning on using.
    Mike
  • glyrenden
    Hello all,
  • TLAR
    No shims or changes to mounting angle required for the Eflite retracts. My nose wheel does stick out about 1/4 inch when retracted with the supplied wheel. However, the mains are fully retracted.
  • Kangi1954
    Originally posted by TLAR View Post
    Hi, new guy here. To help out GBL who is an outstanding videographer of my Bronco, I'll post some specs of my OV-10 to answer some questions that were asked on this thread.
    Motor - Rimfire 32 x 2
    ESC - Talon 90 x 2
    Props - APC 13 x 6.5E x 2 (one is reversed)
    Spinners - DuBro 2.5 inch x 2
    Batteries for motors - 4s 5000 x 2
    Electronics battery - 2200 Life
    Retracts - Eflite 90-120 90 degrees x 3
    Servos - Hitec HS-225MG Mighty Mini x 8
    Graphics - Callie Graphics 1/7 VMO-2
    Flying weight, I don't really know because I have not weight it yet. I get six minutes of flight time and landing around 50%. Mixed throttle, to include high speed passes. Most of the flight are done at 1/2 to 3/4 throttle. Since the video was taken, I got brave and have been doing basic aerobatics that this aircraft would do IRL. More than enough power with this set up. She takes off from grass with no problems. Very stable flyer with the counter rotating props. Pilots and exhaust will be added as soon as they arrived to add more scale to this a/c. The only mod I really had to do was extending the standoff for the motors. The retracts were all dropped in with no issues and the supplied struts slipped on with no modifications.
    Welcome to the forum! Thanks for sharing your set-ups. You were able to install the nose retract without modifications to the mounting surface? No shims or change to mounting angle? Does the front wheel retract fully into the wheel well?
    Rick
  • MikeT
    Me Too.
    Mike
  • Kangi1954
    Originally posted by wrangler1 View Post
    Looking at the Robart 105 retract that i have here i assume that will have the same travel as the eflite that i installed on my plane. So looking at that, i assume anyone that will decide to use it will have to do the same work that i did on my Nose retract wood base.
    Photos below
    Yep. it looks like the Robart will require the angled shims as well. I just ordered the X Wave retract from Motion, so hopefully that solves the problem.
  • Kangi1954
    Rick
  • TLAR
    ESC - Talon 90 x 2
  • wrangler1
    I’m most interested in what nose gear retract he used and what mounting modifications, if any, were needed. If any of you guys have installed the Robart 105 degree retract, I'd also like to know (see) how that worked out. Please?
    Photos below
  • Kangi1954
  • MikeT
    I'm also interested in what set up he used. Be great if you could post that information. The Eflite 60-120 mains just got pushed to a September delivery date.
    Mike
  • sam51401
    Thanks GBL.. for the video. I actually took a snap at the end and used as my desktop!! How about some details on his setup if you can so we can start compiling what works and what doesnt. First question, i assume those are the Callie graphics for VMO-2? Same set im using as i grew up watching these in person. Camp Pendleton is where i started my RC hobby and on the same airfield that very plane was based.
  • TBolt
    Very Nice GBL, thanks for posting
  • Woodcock
    Originally posted by GBLynden View Post
    How about a flight video guys? :D
    That is truly a beautiful flyer. Very Realistic looking. I think I now know why Charlie likes them so much. The electric motors add to the Turbine persona very nicely.
    Woody
