    didier n Wow, that is a lot of work! You're very dedicated! This bird is actually a great candidate for a 3DP cockpit set, because you're right, the canopy is so large and there is lots of extra space for detail along the side panels. I look forward to seeing your finished results!
    Are you going to keep the stock main instrument panels, or modify those, as well?
    • didier n
      • Oct 2019
      • 109
      • leopoldsburg Belgium
      Thx for the compliments, i keep the stock instruments, but removed the clear covers, they looked just silly in my opinion. I'll be adding some more detail in the back of the cockpit to round things up..
      It could indeed be a candidate for 3D printing, but i'm more of an "old skool" builder.. Of course i use 3D where needed, but always try to make parts myself... just me...
      • WrightBrosRC
        All Things Aviation
        • Feb 2019
        • 195
        • Hillsboro, OR
        I hope to maiden my Bronco this Thursday, but the weather window is sketchy. It has been air worthy for more than a week but between transmitter repairs and bad weather I've had to wait... :disappointed:
        I spent this rainy day scratch building some machine guns. They need a little paint and detail, but they work from a distance.
        • MikeT
          Here......Hold my beer.
          • 1060
          Looks great.
          Mike
          • WrightBrosRC
            All Things Aviation
            • Feb 2019
            • 195
            • Hillsboro, OR
            Today is the opportunity I've been waiting for to maiden the Bronco. The forecast weather still suggests a brief clear and partially sunny window around 1pm. Often the clouds don't quite burn off. The forecast for all of next week is more rain and possibly snow later in the week. I took a few pics before loading her up just in case the weather doesn't clear today.
            • didier n
              • Oct 2019
              • 109
              Good luck with the maiden!!
              In the meantime i've done some more work on the cockpit. Some more detail was added behind the back seat, and i've started the paint job... it's slowly coming alive
              not done yet....
              • TBolt
                Rekitting kits at an extraordinary rate
                • Aug 2017
                • 50
                • Chandler AZ
                looking good didier n
                • WrightBrosRC
                  All Things Aviation
                  • Feb 2019
                  • 195
                  • Hillsboro, OR
                  Thx, but got rained out... Your cockpit looks sweet!
                  • WrightBrosRC
                    All Things Aviation
                    • Feb 2019
                    • 195
                    • Hillsboro, OR
                    Finally a break in the winter weather!!
                    • WrightBrosRC
                      All Things Aviation
                      • Feb 2019
                      • 195
                      • Hillsboro, OR
                      A nice pic.
                      • didier n
                        • Oct 2019
                        • 109
                        Congratz on the maiden! what setup did you use?
                        I've finished the rear of the cockpit, time to put it all together this week...
                        • WrightBrosRC
                          All Things Aviation
                          • Feb 2019
                          • 195
                          • Hillsboro, OR
                          I used the setup recommended by Motion with a few changes.I plan to share the build later.
                          I really like your cockpit electronics detail.
                          • WrightBrosRC
                            All Things Aviation
                            • Feb 2019
                            • 195
                            • Hillsboro, OR
                            I got another flight in yesterday with the Bronco. Feels so comfortable, like an old house slipper. (but much cooler!)
                            • jasmiller
                              • Oct 2015
                              • 36
                              • Atlanta, GA
                              Very Cool
                              • sam51401
                                • 368
                                • Sellersburg IN
                                WBRC, what camera are you using to get those great inflight shots?
                                • WrightBrosRC
                                  All Things Aviation
                                  • Feb 2019
                                  • 195
                                  • Hillsboro, OR
                                  Insta360 ONE X
                                    WrightBrosRC Would you mind posting a photo showing your mounting setup for your Insta360? I've been mulling over that device, I think it has lots of potential on models of a certain size. Your shots make it all the more tempting!
                                    • WrightBrosRC
                                      All Things Aviation
                                      • Feb 2019
                                      • 195
                                      • Hillsboro, OR
                                      Thanks Alpha, I may be doing a video soon dedicated to how I use my cameras and such. I'll share a lot but not everything. I use double stick tape mostly, that's the easy part. Learning where to and where not to place cams on your aircraft and why is the complicated part. If you look at the latest video, as the aircraft turns to taxi back after landing, you can see a cam stuck to the leading edge of the starboard wing. For a nice perspective its great, but any real aerobatics would sling the cam off the end of the wing.
                                      I haven't lost a camera yet, but there are risks involved. $600 of camera lost in the duck pond would be very upsetting.
                                      • didier n
                                        • Oct 2019
                                        • 109
                                        That was some nice scale flying there Wrightbrosrc ! and really nice camera work as well.. keep 'm coming
                                        • WrightBrosRC
                                          All Things Aviation
                                          • Feb 2019
                                          • 195
                                          • Hillsboro, OR
                                          Many thx!
