Well, it's fairly simple... i draw all the lines, including the distance between each rivet, and that's the most time consuming part.. then i place the rivets with a styringe using white wood glue... It just takes patience.... done about 5000 rivets so far...
If you need more info just ask
DidierComment
didier n Nice work! I know the feeling of having to engrave something or work on it in some way to bring out more detail. Did you use a scriber, or just a hobby knife?Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
Thanks, guys,
I already made the gun barrels, i'll add them once the plane is fully painted. The chutes will not be made because the acces to the outer part of the pylon is not easy... maybe i'll paint them on...
Panel lines are made using a very thin jewlers file, making mutiple passes to get the desired depth....
Grtz,
DidierComment
Nice TG ……. The very first is still around
I was never aware so thanx for sharing
Hey Didier,
regarding the pylons, a guy in a forum recommended to fill the hollow pylons with „pressure-free“ construction foam (what ever this should be?
) to make them more stable.
can you give me any advice building the M60s ? Or anybody? I would appreciate it...
AxelComment
Hey Axel,
Hey Didier,
Axel
I built mine from brass tubing, pinstripe tape and superglue.
DenThere are hundreds of RC aviation videos viewable here; WBRCComment
Hi Axel,
I used about the same method Den did, haven't got any decent pictures yet... Take a good look at the full size, on one side they are on the inboard side of the wing, on the other the outside... i almost missed that one...
DidierComment
Ref my post #303 or do a thread search on 225MG
If your sticking with the size that best fits the mounts on the hatches, HS-225MG and digital 5225MG are what im using. Plenty of torque and best fit with digitals on the flight controls(5) and analog on the flaps(2)Comment
