Official Black Horse 2350mm Gilmore Red Lion
    Looking forward to seeing the progress on the other builds. I noticed that there is only one Gilmore left in stock in the U.S. warehouse.
  • djmoose
    It's almost time to get started on mine! I have to finish up a few things, but took some time to assemble THIS 1:32 diecast Red Lion. 😁
ID:	304430Click image for larger version
ID:	304431Click image for larger version
  • RCBobP
    I've been staying put in Florida since the beginning of February, but come mid-April I'll be back in Baltimore, ready to get to work. Ray English has worked on my Saito engine, so that will be delivered in a few weeks.
    DaleD I often wonder the same thing. The roar of crickets is deafening LOL.
    As djmoose said, it's the same 4 bolt drill pattern as the 50cc-60cc DA and DLE gas engines. Do use a proper drill jig for those motors. The holes need to be the right spacing and drilled perfectly straight.
  • djmoose
    That Dualsky motor comes in two versions...one with a single center prop shaft (GA6000S)...and another with the same 4 bolt pattern you would see on a DA60 (and others) with is a 30mm bolt circle. (GA6000)
    You will need to drill your prop for the 4 30mm bolt pattern. There are 60cc prop drill jigs that help with this.
    Originally posted by RC ML
    i have a stupid question, how did you put the wood propellor on the dualsky motor, there is no central screw , only the 4 bolts ... am i missing something ?
  • RC ML
    i used the engine mount to locate the holes for the electric motor mount.
  • RC ML
  • DaleD
    Any update on the newly acquired models and build progress?
    DaleD
  • David5211
    A previous post mentioned a Saito FG 90R3
    I like that idea. It’ll be a while before I start working on this plane though. Buying it to have in my store up of ‘funtirement’ projects.
    David5211 Welcome to Hobby Squawk! Looking forward to some posts with radial installs.
  • DaleD
    Originally posted by David5211
    Just ordered my Black Horse 2350mm Gilmore today!
    Finally. And excited, awaiting arrival. I want to go gas radial with this bad boy.
    That’s the ticket!!! A radial should be perfect for this baby. What motor are you considering? I’m looking at the UMS 5 cylinder 75.
    DaleD
  • David5211
    It's going to get up to 46 degF today. But, there's still a foot of snow on the field. Spring is just around the corner. Looking forward to getting this round cowled beast back in the air.
    How are all of the the other Red Lion builds going?
    Click image for larger version  Name:	Gilmore Flight_1a.jpg Views:	0 Size:	57.6 KB ID:	300837
  • djmoose
    Originally posted by RCBobP
    or 7 if you want to put the choke on a servo
    Fair point!
  • RCBobP
  • djmoose
    Alpha For the guys at motionRC, you might want to fix the product page. It claims you need 7 servos...you only need 6. (5 if going electric)
  • RCBobP
    That helps, since I'm going with the Saito 90FG. Per Horizon's spec's that's 40 oz heavier than the 61 twin.
  • CitabriaDriver
    Or maybe I could do with a bigger radial engine😂
  • CitabriaDriver
    I have a FG61 TS twin fitted, which is fairly heavy. With all electronics in the forward bay around the tank, I’ve had to add a fair amount of lead to the firewall to get it to balance as per to post flight recommendations on here 112mm on a Vanessa Rig. I could do with even more weight. The manual CG is too far back and I’d rather start nose heavy and work back than control a tiger on its maiden!
