  • thomasnwilliams
    I can print but not design, Any chance you could design the long nose modification for the OV-10D? I know that's asking alot, I'd be willing to pay for a working thingiverse file solution. Thanks for the files you've done so far great work!
  • vduniec
    Here's one more file tonight. These are the APR-39 Radar Warning Receivers for the later model of the USMC OV-10's. I also have the cockpit indicator designed and will upload hopefully this week.
    There are 4 APR-39 Radar Warning Receivers on the late versions of the OV-10. Two are positioned on the nose and two are positioned on the top of the tail booms. Look on the web for placement details. The indicator was placed on the top of the instrument panel coaming.
    Click image for larger version  Name:	APR Placement.jpg Views:	0 Size:	136.6 KB ID:	265465
    Guess my connection was givin me fits, worked this time. Lol
  • Dwalkerp47
    Originally posted by Jpmcdo View Post
    I won't be flying my maiden flight for awhile. I'm using an AR637T receiver and it's not working correctly. Every time I hook up the batteries the receiver has to be rebound. I'm using an IX12 and tested it out on my older DX9. On both I have had to rebind each time.
    Double check your Throttle Leads coming from the ESC. I was having some of the same issues and found that the Throttle Cable that is Y'd off into the Receiver Plug had an issue. I replaced the Throttle Wires and used a Y Connector at the the 637...I finally got everything to work properly after replacing the cable.
  • thomasnwilliams
    Link worked for me without problem, Printing now. Thank you Sir!
    Works for me Vic
  • vduniec
    Originally posted by rifleman_btx View Post
    I cant get the link to work
    If you're referring to my post, the link works fine for me. I'm relatively new at posting some stuff on Thingiverse and sometimes have not had the best luck searching for things. If you search for vduniec, it should take you to my designs where you can find it that way.
  • vduniec
    Here is the Thingiverse link for the FM Antenna humps that go on the twin tail booms just aft of the wings. I glued them in place and put a nylon bristle from a floor broom in the hole.
    These are the antenna mounting humps that are on the top of the twin tail booms of the OV-10. They are scaled to fit the Flightline OV-10 Bronco. I used a bristle from my nylon house broom to replicate the whip antennas. The actual antennas are vertical when the plane is stationary but they bend slightly in flight. The nylon bristle does provides the same effect.
  • boomer108
    Originally posted by sam51401 View Post
    All this talk about tail wag just made me think to my airline days as mech, its called a yaw damper. The Jetstreams and EMB-145 and vast number of planes i have worked had yaw dampers. OK so im going to install a simple yaw damper in mine, just like the real ones have!!!! Now how do i get it to fit is the next question??????
    I remember a number of times when the yaw damper would malfunction on the KC-135 we would get that tail wag but using the A-3L gyro on the Broncos as some in this post it acts like a yaw damper.
  • sam51401
    Originally posted by The Sheriff View Post
    Thanks xviper
    I didn't see that post earlier, thought I was keeping up with the thread. It was difficult to see in the gyro on/off video, but the commentary was good. Are you able to adjust the gyro okay in the limited space?
    I mounted it such that I could still have my battery placement and have the ability to get a small screwdriver to the gain pots. However, I lucked out and where the gains were set from the last plane it was in is where it happened to work really well and I've never had to touch it since.
  • The Sheriff
    Thanks xviper
    Has anyone had success flying in moderate winds with a gyro? I've tinkered with the A3 Super 3, but not in this plane and haven't really used gyros otherwise. Has anyone tried an A3 Super 3 in the Bronco? If so, where did you mount it? Does a gyro help with the wobble that occurs in low to no winds?
    That last video I put up was with gyro ON the whole flight and the video I posted before that, I showed what the plane looked like with gyro ON and OFF. It may have been too small in the video to see but I did comment about it in the post.
    You don't need such a fancy gyro on this plane to fix the tail waggle or to tame it down in strong crosswinds. Yes, I've flown it in very strong cross winds. I use a simple 3-axis Freewing gyro. The cheapest HobbyEagle A3-L, 3-axis gyro will do the same thing. I built a wooden platform for it and mounted it above and just behind the batteries. I've posted up a picture of that installation earlier in this thread.
  • The Sheriff
    Well, I had an incident on Saturday. The wind was howling and gusting. Normally, I fly my Carbon Z Splendor in these conditions, but the Splendor was down due to a canopy issue. Having done about 20 flights on the Bronco without incident, I boldly proclaimed, "This thing is a tank" as I walked to the flight line. As it turns out, that was mistake.
    I regretted my decision immediately after liftoff. The turbulent gusts were forcefully shoving the Bronco into uncontrolled 90 degree banks. After 3 or 4 approaches I managed to get lined up over the runway only to be hit by another gust inches off the ground. An input of heavy aileron correction leveled the plane as it touched down on the center-line on the mains. The crowd of 2 murmured unenthusiastic cheers while my blood pressure returned to a healthy level.
    As I taxied back, I could see the right wing sagging with the prop having barely enough clearance for ground maneuvers.
    I removed the right boom and repaired the gear by straightening the connecting pin with a vise. Then I removed and re-glued the plastic mounting bracket. Also, side note, the connector from the ESC wire ripped out so I soldered that. She's now fully operational and ready to rip. Aside from some scuffed ordinances, there is no sign of damage.
    I love this plane, and will limit flying it to calm days if need be. I would, however, like for it to be an everyday flyer if possible.
    This morning's flight. Gyro ON for the whole flight.
    Warning: hatcam
    Todays first flight.
    Welcome to the forum. They all do it and no one has a cure except installing a gyro...
  • XairBoss
    I just have 5 flights on my Bronco. One thing I noticed was an oscillation in the roll axis in turbulent conditions. The oscillation is worse at lower speeds. The oscillation diminished as the conditions became calmer. I don't have a gyro on this model. I texted a friend from the field about it and he told me his old 80' Rich Uravitch Bronco did the same thing, that it was a tendency they have. So, is there a hack to make it go away? I was thinking of towing the rudders in a few degrees. I noticed the model is extremely sensitive to rudder inputs. I'm guessing that might have something to do with it.
    ronwc Keep us posted. Interesting experiment.
