  • vduniec
    Some FPV touch and go practice from yesterday. RanCam 3 Split Micro.
    https://www.youtube.com/watch?v=sTFp...ature=youtu.be
  • sam51401
    Cut up an expired credit card. You can notice these are slightly staggered by using alternating edge of each imposed VG. If i did this again, i would place them inline and in the center of each imposed location. Not sure if i will do the ailerons as those are on the control surface. A 3D printed strip that can be inset would be fine.
    I also would like to mention the roll/yaw issue that is observed and maybe splitting the ailerons to separate channels and programming in some differential may help. With the listed issue of the BB, i may go ahead and bypass the box on the controls and the retracts so trying some diff is on the list.
  • vduniec
    Originally posted by sam51401
    Click image for larger version Name:	stab.jpg Views:	0 Size:	97.6 KB ID:	262805
    Thought i would post a little teaser on my repaint progress and results. I still need to print the disco ball that fits on top and i have some snazzy metallic vinyl that resembles the red rose tint mirrors very closely. The fuse and top of wing for the darker brown is whats left then i need to cut my vinyl and print a couple of decals.
    I have the same struts as F22 has and ill trade those out later but like to hear more about the issue with the retracts not being able to lift the mains. Those struts are not that heavy.
    Looks good. What did you make the vortex generators out of. I’m thinking I could make a 3D printed strip of them to install.
  • boomer108
    Finally received my replacement horizontal stab today hopefully I'll finish setting up my Broncos and maiden it this week.
  • sam51401
  • sam51401
    How does the Yak nose strut work out?
    Looks better though...
  • yf22raptor
    just an update I have the T45 struts and the do bro 2.75 wheels unfortunately when the plane is upside down the gear will retract into the plane completely when you have the Plane sitting normal the gear will not retract all the way it seems that the retracts provided are not strong enough for the heavier struts and wheels so I ordered the t 45 retracts will update if they work
    might change to lighter or smaller wheel if needed
    Vic, very easy to Dremel the flat you need.
    On an aside I stretched one of my springs on a not too bad landing too. The springs are just lousy quality. I had some old version 90mm F-18 retracts with what appear to be better quality springs and swapped them to my OV. I want to do the T-45 gear too but at least right now my OV isn't listing to one side. :)
  • vduniec
    Originally posted by yf22raptor
    Had to change the struts and wheels to more scale
    used freewing t-45 struts , gonna paint the struts and wheels white .
    Also have a freewing yak 90 nose strut gonna try it out see if it works ..
    Good job! Where did you source your gear pins from, since the T-45 strut holes are 90 degrees off from the OV-10 ones? I like the idea of the compression spring in the T-45 struts as opposed to the extension springs on the OV-10. I’ve already stretched one out due to a hard landing while FPV’ing. Landing this plane normally is no problem but on FPV, it took me a couple of flights to get the correct sight picture. Still not perfect yet on those approaches but that’s half the fun of this hobby.
    Also, what wheels did you use as replacements for the mains?
  • Jpmcdo
    Cool thanks again!
    Originally posted by Jpmcdo
    Thanks for replying. I haven't set up a lot of planes on my iX12 and it's been a long time. So it looks like this is all set up in Dual rates for the measurements?
    Yup. On my Spektrum DX8, I use a different 3-way switch for each control surface. Set up in the D/R and expo menu.
  • Jpmcdo
    The manual states that measurements are labeled "H1 and H2". H1 is up (or to the side). H2 is down (or to the other side) and is the same measurement. For flaps, it only gives H1 since those only go in one direction.
    I go strictly by the measurement and not the % for rate as % can be different to get the desired measurement and depending on what hole is used on the arm. I dial in the high rate and the low rate as stated and one in between for the mid-rate. After flying this plane, I find that I need the high rate with about 30% expo. In fact, the plane is still a bit sluggish for my tastes, so I'm going to increase the rate above what it is for high for aileron. ELE and RUD seem to be fine on mid to low.
    I'm asking this question on the RC Groups forum as well.
    For those who have completed their maiden flights, what are you using for Dual Rates and Expo? The manual, if I'm reading it right is showing travel of the control surfaces and a D/R rate of 80% for low and 100% for high. Am I correct in assuming the H1 and H2 numbers are for the travel of the flight surface so for example the Elevator should go up 20 mm and down 20 mm?
    Thanks
  • Rcfiddy1
    Some ops from yesterday.
  • Jpmcdo
    Thanks
    Nice Vic!
  • vduniec
    Just came back from a couple of flights fine tuning and testing out a gyro (Freewing 3-axis) for the OV. I include the video of the second flight, after the gyro was set. Note that the take off was with gyro OFF. A bit of wind caused it to roll a bit as it left the ground. The first flight with gyro OFF had the same take off (and tough N go) wiggle and with gyro ON, rock solid. Testing different maneuvers with gyro ON and OFF, I can conclude that the gyro made all the difference in the world. With gyro ON, the waggle was gone! Landings without a gyro was a bit bouncy and not too consistent. WITH gyro ON, you can see at the end of the video how that went.
    My first day of flying this plane, I was not all that impressed with it but now that the gyro has been installed, it's a totally different airplane. I was a bit "ho hum" about it at first, but now I really, really like it. Once I get a little more grunt into the drive system, I may actually love this thing. The guys at the field all liked the looks of it, no doubt about that.
    There's a lot of chatter between another club member and myself, not to mention a lot of loud background noise from the gas guys, so turn down the volume or turn it off altogether, however, some of the chatter is relevant to the OV's flight characteristics as it relates to the gyro (and other things).
    So, what are the questions ................................. ???????
