  • Cobra1365
    Have you guys figured out the yaw problems (Tail waggle)?
    I feel the under wing CG is a little nose heavy compared to how it feels flying. I'm about 1/4" (not much really) behind the marks.
  • ronwc
    I agree with you completely, if It won't balance right with the 2500's I'm not going to add weight , that would totally kill any benefit. But my 3600's aren't all the way forward, they are in there about 3/4" inch back (most of these planes have a nose-heavy starting CG). So we'll see. I will post a report!
    I fly everyday down here in FL, and have flown my OV-10 a lot, just got three more flights this morning. I have three different pairs of lipo's I use, 2500, 3300 and 3700. I move them all the way forward with no extra weight added, and the Bronco flies great on all of them. And for those that didn't see some of the earlier post, the power is not overwhelming, but what I would call adequate. Changing out to APC 10x8 two bladed props helped a lot in speed and pull.
  • themudduck
    Balancing the plane may become a problem. The twin 4000mah batteries are already as far forward as they will go to balance this plane. If you use 2500's, they may not be heavy enough to achieve the desired balance. What will you do? If you have to add weight, then the whole point is likely lost.
    Very nice.
  • thomasnwilliams
    Here is my solution for the wing pylons, I used a spare #4 pylon from my A-10 80mm, I added the Male weapons attachment to each wing from the MotionRC F-16 90 spare parts. I used single Sidewinders from these kits as well. For the dual racks I printed DirtyDee’s Aim-9 Sidewinder and his LAU-105 Dual Rail. Have Fun!
    https://www.thingiverse.com/dirtydee/designs
  • f4u ausie
    thanx
  • KC8REH
    Its mainly light control and distribution. The rudders and sterring servo, outboard flaps, ailerons and landing gear all connect to the blue box. I would order a set of wing ribon connectors and use Y cables to connect the flight controls dirrectly to the rx. Same with the gear. You do need to run gear signal to the blue box to run the landing light.
  • f4u ausie
    Can I ask is the blue box purely for distribution purpose or. Sequencing. As well. ???
  • Mad Baron
    I still have to build my F/L OV-10 as its still in the box it arrived in and I'm concerned about the blue box issues some folks are having. I am still in the building process on my DVIII which takes over the entire workbench. So the OV-10 is next on the list to get built.
  • KC8REH
    I'm going to take a jab at it and say you may have had one of those "faulty" blue boxes. Loosing only aileron control is not likely due to a receiver issue, as you've already shown by using that RX successfully since the crash. I had a similar situation but mine was more of "glitch" in the aileron response in my T-33. After hooking up the ailerons directly to the RX, the ailerons worked perfectly. As long as there continues to be reports of crashes that point toward these blue boxes, I think I'm going to bypass the BB for all critical control surface functions - AIL, ELE. Rudder is debatable since you can always "bank and yank" a plane.
    That is what My testing has determined. However I have been told I do not know what I am talking about and technical is insiating I return the box or they will not help. I have been working with Electronics for 40+ years and repair My own Amatuer radio gear. I think I know more about this than they do. Also when I took classes for My Federal Aircraft Mechanis license co ering Airframe and Powerplants I built all of My own test equipment from kits. Trouble shooting and repairing what I built was a Fun time.
  • vduniec
    Click image for larger version  Name:	8D53D958-12DF-496E-9B9E-7CFE58E10AE3.jpeg Views:	0 Size:	119.0 KB ID:	263492
    Originally posted by sam51401
    I printed this last night and it is usable with some touch up but not sure why the upper portion printed great but had earlier layer separation. Using a Geeetech A10.
    Click image for larger version Name:	alq1.jpg Views:	1 Size:	75.2 KB ID:	263483Click image for larger version Name:	alq2.jpg Views:	1 Size:	55.2 KB ID:	263484
    I printed mine on a Creality Ender 3 with no issues.
  • KC8REH
    Originally posted by Jpmcdo
    Did you check the telemetry after a range check? I’m going to try a new AR637T. I don’t trust the first one after 733 frames lost. Loss of aileron control sounds like a receiver or transmitter problem. I’m now waiting for basically the whole plane in parts to show up.
    is anyone who has been having successful flights using the AR637T?
    Telemetry shod no holds and 12 or so packets lost. The radio tests fi e along with the reciever. I have been flying for over 30 years and have Never had 2 crashes in subsequent flights were the Same issue was the cause. The first flight was with an Orange 6 channel rx which has sense worked Flawlessly in My 450 Helicopter. The AR637T has flown in a Dynam F6F Helcat also with no issues. The TX is not the issue or I would have seen it by now.
    Originally posted by KC8REH
    It was Not My AR637T. It has flown sense with No issues.
  • sam51401
    Originally posted by vduniec
    I don’t have the wing pylons made yet. Hoping to design and print them at some point. If you’re going to do a Desert Storm bird, you may want to add this. It is the ALQ-144 IRCM “Disco light” jammer. It goes on the bulge on the top at the back of the fuselage.
    Here’s the link on Thingiverse: https://www.thingiverse.com/search?q...&sort=relevant
    Click image for larger version  Name:	FA303E78-E5DC-459B-A5AA-C3E735FE8497.png Views:	429 Size:	49.5 KB ID:	261171
    Originally posted by boomer108
    Thanks Xviper! I was hoping I wouldn't have to pull tray and wires back out but if that's the only way to correct it so be it. Thanks again.
    Well, there is another way BUT, you have to duplicate what you did the first time when you set only one brake. You'd have to plug in the batteries in the exact same order with the exact same delay. It's like hitting the bullseye twice in the same game of darts. Chances are against it, so ..............................................
  • boomer108
    You got to this point because you tried to calibrate the throttle of both ESCs in a single procedure but you didn't plug in the two batteries fast enough. You plugged one battery a bit too late and the two ESCs began to go into their programming sequence with a slight lag. When you pulled the throttle down, one ESC had already entered the brake ON/OFF menu, so you ended up calibrating one ESC but set the brake on the other.
    If one brake is ON and the other is OFF, you can't go into programming mode while both ESC "throttle" leads are connected at the same time. That will reverse BOTH. (Meaning, you will set the brake ON with one and set the brake OFF with the other.) You must separate them and only program the one that you want to change. IE, you must go find the ends of the "Y" where the two ESC "throttle" lines are hooked up and disconnect the one that is OK. NOW, power it all up and you should hear ONLY the one that you want to change. Go through the steps to get to the brake menu beeps. Lower the throttle when it's time and that should reverse the brake setting for that one. Hook up both throttles to the "Y". Now you should have both of them OFF.
    I'm thinking of trying a pair of 2500's, the lighter weight may help the performance and still provide long flight times, since the engines won't have to work as hard. We will see.
    Just finishing up my OV-10 and I noticed after throttle calibration that one engine brake is on and one is off. So went into the esc set up to set brake off and the opposite side is now off and the other side is on I even went to factory default setting but it did not change the problem. This is my first twin and not familiar with this problem. Any advice would be appreciated.Thanks
  • themudduck
    Really sorry to hear of these crashes, that sucks. I'd like to pipe in and say that I have had a few dozen flights in the past few weeks and I love the way it flies, I'm happy with the stock power (and I have no "relationship" with Motion other than I am a customer).
    Can I say that there are some RC pilots who overly rely on (or simply prefer) inappropriately huge amounts of power? <Present company excepted>
    Don't misunderstand, I enjoy flying fast. My red HK ME163 with a 4-cell goes around 125mph, I love screaming around with that thing and using the rocket. Its fun and appropriate for that model, I think. But I don't fly my B24 that way. Naturally there's no problem with anyone modding to bump up the performance, that's all good fun. All I'm saying that the OV10 doesn't need it to fly well. I can do loops all day (without firewalling it) and I can fly for more than 10 minutes (Admiral 3600's), mostly on medium power settings. It sips those electrons! When I'm flying slow I just use the takeoff flaps and I love doing lazy figure-eights around the field about 10 feet up. Flaps slow it down big time - and its 100% true that you can't fly it too slow, you do need to add power in a slow turn just like XViper said. Just my opinion, I think it flies very well as designed. I agree it would have benefitted from larger props and more powerful motors. But then it would fly for only 6 minutes instead of 10, and would need larger batteries which would make it heavier and things would start breaking.... There's always a tradeoff.
    I'd like to mention that last weekend the retracts on my Bronco became intermittent, one of the mains wouldn't come down. I cycled it about 10 times in the air and finally got three green - and landed. When I put the plane away, I retracted the gear and then all three of them stopped working. Afterwards I found that all three connectors for the gear were not completely tight in the connector sockets. How could that happen? its a pretty large pile of wires and I think maybe it was pulled around a bit when the tray was installed into the fuselage. I am thinking that perhaps one of KC8RCH's aileron connectors may have pulled out? Don't know of course. But I decided to secure the connectors so they can't loosen or come out. On Sunday I spent a little time making the wires neat to clean up the wiring compartment a bit as well.
