  • Jpmcdo
    I pulled the trigger and purchased the Bronco today. Supposed to be delivered tomorrow. What batteries are being used besides the Admirals? I bought two but would like backups. And has any one used the Admiral 600sp receiver? I didn't include that in my order but can of course get one.
  • Ric
    Xviper and MrD,
    Thanks for your reply's and helpful information. I got her all sorted out and will probably maiden tomorrow.
  • MikeT
    Assembling mine today. I'm really impressed by the finish and parts fit on this.
    Mike
  • Phantom
    ALQ-144 is what was standard on my Hawks back during my 1st deployment. I was enlisted then and everytime we landed and shut down I was up on top cleaning it, keeping those mirrors shiny. It's not exactly a jammer.... that's all I can say about that.
  • sam51401
    Ok, you got me curious and i did find pics of several with disco ball on A's. 454, 459 and 473 have them mounted.in several photos in DS.
  • themudduck
    Originally posted by vduniec View Post
    I don’t have the wing pylons made yet. Hoping to design and print them at some point. If you’re going to do a Desert Storm bird, you may want to add this. It is the ALQ-144 IRCM “Disco light” jammer. It goes on the bulge on the top at the back of the fuselage.
    Here’s the link on Thingiverse: https://www.thingiverse.com/search?q...&sort=relevant
    I looked it up, here's what the real thing looks like. Pretty cool!
  • sam51401
    I seen this earlier and i think they were on the D and D+ versions but i havent seen any photos of it on the A's. I will be looking for your pylons when ready and are you going to use the FW clips for attachments?
  • themudduck
    Originally posted by Narly View Post
    OK, "build" complete w/ a few hanger rash spots. Tried to match OD with extensive collection of Model Masters, Floquil, Testers, Tamiya & Revell bit nothing very close. So, has anyone found the OD matching paint??
    ..... and what a beaut her is!! 😄
    Sunday evening I picked up a jar of paint at Home Depot, color matched - I needed to touch up a couple of spots after my "tree adventure". But this isn't OD. Its a medium forest green.
    I think its extremely close to the OEM color.
    Base: Behr PP103 (flat)
    Color Codes: CL:88 DL:36 KXL:12 LL:187
    In this picture, this paint was used to touch up the bottom edge of the cockpit below the plastic. I'm happy with it.
  • Narly
  • Gilatrout
    cool, I hope some of you geniuses with the 3d design skills can do something about that cockpit too.
  • Mr D
    Originally posted by Ric View Post
    Looking for some help reprogramming ESC's. Mine are set to "Brake On". Need to reprogram to "Brake Off".
    Download the ESC manual found on the MRC website for the B-24. It is the same power system and gives you the tone sequence for changing the brake and setting throttle calibration. See attached.
    It's similar to throttle calibration. Throttle stick to max, plug in plane (with one throttle input at a time), wait for initialization beeps, then at the end of the next set of beeps, lower stick. Repeat for the other throttle input. If you need a visualization of this, go to YouTube and search for "ESC brake set". Or download most any ESC instruction manual.
  • Ric
    Originally posted by Mr D View Post
    but then why fly a warbird?
  • vduniec
    Originally posted by sam51401 View Post
    I’m in need of some wing pylons for the desert storm load out. Any ideas? I have the keyed adapters from some spare a10 parts so got those parts covered. Plane is sanded to remove all vent tits and ready for a base coat of primer white.
  • Mr D
    Originally posted by CFIT rob View Post
    To achieve the throws recommended in the manual i had to move the linkage in a hole on the servo arms (i did that rather than reduce travel in radio.) Has everyone been going with recommended throws? Everyone needed to reduce travels?
    Flown 6 times using the recommended servo arm holes. Flies perfectly well (scale like handling) using mid rates for all three axes. If you are looking for aggressive non scale flight you could definitely diverge from the manual, but then why fly a warbird?
  • AussieHoppy
    Originally posted by 68Strat View Post
    Man this plane is cool! Just mocked up a 4s4p Li-ion pack consisting of 21700 cells. Seems like it'll fit and balance perfectly, and give me 16.8Ah on tap. Off to do some spot welding.
    Wowser! That's a serious collection of electrons! It'll be just as interesting how she performs weight/speed, as will flight duration... 😁
  • CFIT rob
  • 68Strat
  • James
    Hey guys, I made a 5 page diagram for you all to download (PDF in attachments) on how to wire your OV-10A Bronco and a video that goes over it in detail.
Name:	OV-10 Wiring 1 MRC.jpg
Name:	OV-10 Wiring 2 MRC.jpg
Name:	OV-10 Wiring 3 MRC.jpg
Name:	OV-10 Wiring 4 MRC.jpg
Name:	OV-10 Wiring 5 MRC.jpg
