Gross man,
Are you spraying or brushing on your Minwax?
I brush on two “primer” coats over the factory paint, the “rattle” can spray for larger sections. After the “base” coat of color, then the airbrush comes out to complete the paint. Then I’ll seal the graphics with spunged brush Minwax.
PS. Where on line do you get your FLAT Minwax?
:pop
:corsair:saywhaComment
My rule of thumb is...
For glossiest, use a brush, for flatest, use a spray gun. I found the Flat Minwax online, I'm at work right now, but I'll think it was on Amazon, I'll check when I get home.
Grossman56Team Gross!Comment
using this (Rust-Oleum clear dead flat) product. Dries Flat and offers UV protection. Costs less than $7.00 at Lowe’s. :Cool:Code:I’m
2 PhotosComment
Got 2 good flights on my Tcat today:). I had a scary first flight which scared the crap out of me. I took it up and went to bank to the left and it went to the right I had the ailerons reversed! I was able to get it back to the ground with no damage I cant believe I didn't catch it before I took off, stupid move on my part. After I set the ailerons to move correctly I was able to have two great flights! It sure looked great flying with the new paint scheme.2 PhotosComment
That paint scheme really stands out to me! It looks like a completely different aircraft. Well done as always, Mad Baron!
I'm glad you caught the aileron reversal issue before it became fatal!Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
You did see Ryan's Video, "How to make a grown man cry" didn't you?
I know how it is, you get excited and before you know it, if you're lucky, you're flying and suddenly, OOOPPS!
At least you got back on the ground!
Preflight, preflight, preflight !!!
I did it last season with a buddies brand new Pandora and managed to get it on he ground. got talking and didn't do a preflight. For all the preflights that I've done since my first year when I flew P-1 for the first time, and didn't do a preflight (GOTCHA!) and have nevr ran into an issue, the one time I forget and guess what, Murph's Law gets me.
Team Gross!Comment
Murphy had nothing to do with this. It was Nick's for not doing a proper preflight. I changed radios to my new Spectrum and didn't check the ailerons for proper movement. Glad it was stable enough to get back on the ground. I think I am going to make out a preflight checklist to follow before flying my planes.Comment
A good stable machine and don't forget a very attentive Pilot to bring it back to earth in one piece!;)Murphy had nothing to do with this. It was Nick's for not doing a proper preflight. I changed radios to my new Spectrum and didn't check the ailerons for proper movement. Glad it was stable enough to get back on the ground. I think I am going to make out a preflight checklist to follow before flying my planes.
Great job Nick! :Cool:Comment
MB:
Back in the “Day” I flew an Aeronca 7DC. It doesn’t get any simpler than that; I STILL USED A CHECK LIST (Five items I think).
You know the saying about “old” and “bold” pilots. ;)
I’m glad to be an “old” one - Thanks to Check Lists :Cool:
Keep ‘me flyin’ !Comment
I luckily one day was fixing to fly my Pandora in the taildragger mode and didn't take check and do a preflight and caught it when I wanted to go left and it went right. I stopped and reversed everything. I learned then to check and do a proper preflight every time before I go up.Still Learning:DComment
Been flying R/C for 40 years and lost my Pattern ship few weeks ago due to "reversed ailerons". In my case I had to plug each one in to its own channel in the Rx at assembly and ----------- ! I do dumb thumbs but thought I was beyond that one ! I always tell newbies that even though the surfaces wiggle when you move the sticks, they got to do it in the correct direction !
You have to admire the skills to get her back down safely even after figuring out the problem -- that is instant muscle memory reversal. Way more than my old brain can achieve.Comment
Quick question, I bought my TigerCat used and I want to do a slight custom paint job on the nacelles and I'm wondering, does it matter which prop goes on which nacelle? Does it matter if they turn inboard or outboard? It doesn't really say in the manual, so it probably doesn't matter, but I was just wondering. Currently they're set to turn outboard.
I realize it probably doesn't matter on these planes, but the P-38 initially turned inboard but the prop wash caused problems with the twin tail and it was changed to turning outboard.Comment
My rule of thumb is if I look down on the blade from the top. it should angle to the wing tip.
Thought I would add to what the other said - and tell you that you also need to look at the prop adapters. One of them is normal, the other has a reverse thread... chances are they weren't moved around, but they are like that so that the prop nut tightens against the prop rotation.Quick question, I bought my TigerCat used and I want to do a slight custom paint job on the nacelles and I'm wondering, does it matter which prop goes on which nacelle? Does it matter if they turn inboard or outboard? It doesn't really say in the manual, so it probably doesn't matter, but I was just wondering. Currently they're set to turn outboard.
I realize it probably doesn't matter on these planes, but the P-38 initially turned inboard but the prop wash caused problems with the twin tail and it was changed to turning outboard.Marc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
Rabid Models foamies, including my 8' B17 & 9' B36... and my Mud Ducks! www.rabidmodels.comComment
