Well, maybe so Boots, but I have 650's in mine spinning the stock 4 bladed props and it works amazingly well. With BBD, I upgraded to 580 and then to 650 and there was an improvement albeit not a huge one. When I went directly from the 540 to the 650 in Shangrila it was a much bigger difference. BTW, I use Mantis 85A ESC's in them all (Don't forget the short ESC to Motor cables if you go this route. Order extensions). I agree that the 6s system from the P-47 would rock in the P-51, its awesome in the P-40. Now, that is the reverse to what you describe because I went from the stock 4 blade prop that powered the P-47 to the 3 blade prop that the P-40 uses. Now, CB changed out his prop on his P-40 because he had some issues with the stock prop when doing a power dive, if I remember correctly.
Bottom line is that all these systems will work on the P-51, just a matter of picking a route to finding your joy.
