Good comments - Xviper thanks for the flight report. I have some other models that have tendencies that mirror some of the characteristics of the full-scale plane... for example the F104 with its small wings requires some careful handling, you have to keep the speed up in turns or it will just fall out. Apparently the model Marauder needs to be flown "fast" just like its big brother and flaps are needed at slower speeds - well that seems appropriate. In some ways, I think this is part of the fun of having a scale model and helps builds better flying skills. I am happy that the Marauder is very close to the correct shape - the designers could have lengthened the fuselage or enlarged the tail to make it fly more gently, but I do like that it's scale.
I'm just not completely convinced (yet) that its nose-heavy. The elevator trim may be off due to a slight stab incidence error. (I'm experimenting with that and will report my results after this weekend's adventures).
A nose-heavy plane will have other characteristics which can be observed, such as not wanting to flare during landing (which it does very nicely with flaps) and heading downhill fast when it's inverted. (I don't remember). So far I've had 4 flights, with the 4000mah battery not pushed all the way back. Its sitting where the front strap can grab the front of the battery. That's about a full inch forward of where XViper described his.
I had very similar results as what XViper described. But at high speed, I could induce an instant snap-roll by giving it full elevator. Since it doesn't seem to be really tail-heavy, that snap might be due to high wing-loading - the plane may simply be heavy. Anyway that's what I'm leaning towards. Just my opinion. So I took out my tail weight and I want to try flying it with a smaller battery to see how it does.... With a smaller battery it will less nose heavy, and lighter overall. The balance point will be further back and I'm guessing it will fly better, at least that's what I'm hoping.
