Official RotorScale UH-1A Medic Green 450 Size Helicopter Discussion Thread
    • 2818
    • Arlington, TX
    My Seawolves Bird is almost finished now, paint is complete, ammo belts added! Just needs the decals, pilot windows, and a set of clear chin bubbles. I ordered a clear parts set from RC Aerodyne, but they only sent the windshield. Their customer support is shut down, so guess I may be waiting for a while. Happy with how things have turned out so far though, may need to get it out and do a few flights over my RC PBR riverboat!
      The light gray mast and blade grips really bring it all together! I need to do that for mine!
      Which PBR boat do you have?
        • 2818
        • Arlington, TX
        I have the Proboat PBR. Took it out a few times with the 500 Huey and had tons of fun! Will be great to do the same for the Seawolf.
          Great photos! I have the same one, awaiting a weathering/detailing summer, possibly a bucket mod. It's a fun boat to run, and it looks sharp alongside your heli!
          I need to repaint the teeth on mine:
          • RCFlyer51
            • 41
            • Lacey, WA
            Well, crap!!!!!!!!!!!! I got the stabilizer bar put together (Trex 250 pitch gauge, flybar, and wheels locks) and when I tried to attach it with the head screw found out that the threads in the top of the head are buggered-up/stripped. Oh well. Checked at MotionRC for a replacement head, but, they are still out of stock. Bummer.......just have to fly it without a head cap until I can get a new head assembly.
            Danny
            • CM_Aero
              • Nov 2018
              • 183
              • Central Texas
              Danny
              I am waiting for a replacement head to arrive because I stripped the blade grip socket heads when trying to remove them. Had a lot of play in the blade grips which was causing a lot of vibration. So I tried to tighten them up, but they wouldn't budge. Anyway, I ended up stripping them so I just ordered a replacement head from eBay a few weeks ago. Still waiting for it to arrive
              • RCFlyer51
                • 41
                • Lacey, WA
                What head (model number) did you order?
                Danny
                • CM_Aero
                  • Nov 2018
                  • 183
                  • Central Texas
                  Danny
                  I ordered this one. TL45110-01
                  Hope it fits!
                  • RCFlyer51
                    • 41
                    • Lacey, WA
                    Thanks CM. Let us know how it works out.
                    Danny
                      • 2818
                      • Arlington, TX
                      Decals arrived from Callie today, looks much better with the markings applied! All that remains is the chin bubbles and clear plastic in the pilot windows. Almost finished!
                      • RCFlyer51
                        • 41
                        • Lacey, WA
                        Nice. I am waiting for decal from Callie as well.
                        • wdmustang
                          • 8
                          Hello all, I am confused, please clarify, Motion is now selling this as a 4S, I have a 6S version, it appears that some of you have flown this as a 4S with the original speed control and motor. Alpha, can you clarify, what are the differences between the two versions? Thanks
                          • CM_Aero
                            • Nov 2018
                            • 183
                            • Central Texas
                            I have V2, if you want to call it that. The new ESC that comes with the Huey is a Platinum 40A which is rated 3-4s LIPO. (See my pic on page 9, post 180). I don't know which ESC came with the first batch of helicopters. As far as the motor is concerned, I believe its the same one based on reading thru the forums. 1800kv
                            • CM_Aero
                              • Nov 2018
                              • 183
                              • Central Texas
                              BTW...still waiting for the new rotorhead to arrive and then I can update y'all.
                              • wdmustang
                                • 8
                                Thanks Cm-Aero for the information. It seems from some of the previous discussions that some are flying the 6-cell speed control machine on 4-cells. Just curious.
                                • CM_Aero
                                  • Nov 2018
                                  • 183
                                  • Central Texas
                                  So the original replacement rotor head I ordered hasn't arrived yet; its been over 2 months. So I found a DFC head on ebay and thought, what the heck, why not try it. Got it in three days. Installed tonight and will finish up the install and rigging tomorrow (hopefully).
                                  • RCFlyer51
                                    • 41
                                    • Lacey, WA
                                    How did you attach the air vents, antenna, wipers, and bar to the top of the fuselage? I had a friend print these items and plan to get them on the fuse in the next day or so.
                                    Danny
                                      • 2818
                                      • Arlington, TX
                                      Danny
                                      I used CA glue for some of them, but they are all designed to be attached with small self tapping screws. For the wipers, I drilled a small hole for the pivot shaft in the fiberglass just above the windshield.
                                      • RCFlyer51
                                        • 41
                                        • Lacey, WA
                                        Thanks DeltaDart. Will post pictures once I get the items painted and attached. Got the decals from Callie a few weeks ago. Very nice quality.
                                        Danny
                                          • 2818
                                          • Arlington, TX
                                          For a while now, I’ve had my Huey finished except for 1 part; the chin bubbles. After waiting for 2 months now and searching for different sources, I finally decided to make my own. Built a few wooden molds, set up the vacuform machine, and pulled a new set of bubbles. Very happy with how they turned out for a quick job! All that remains, is to change out the tail servo for something a bit faster and I can call this project complete!
