Yeah I would have expected yours to be more than just 0.4 lbs. with everything you have added.
I definitely think the TT drive is not helping your gears from stripping. But I also wonder if lower KV lower pinion and higher voltage isn’t amplifying the TT torque issue
Your setup is not working as hard as mine which will allow it to spin up fast and with more available torque, where mine would stall out quicker, rather than push through.
it will be interesting to see where pawpaw’s shacks out at. He’s using same power set up a you but I believe he’s keeping belt drive.
Gravy
Gravy
