Originally posted by RAPHAEL_CINTRA
View Post
Mine CG's with the 6s 5000 pack pushed back to almost the end of wooden tray, and it balances at about the aft attach point for the sidewinder pylon. My first couple flights were nose heavy, so pushed it back , now get nice rotations on takeoffs. Landings I finally dialed in with full flaps as you have at 45mm, but for full flaps mix in the "up" elev so the stab leading edge is about 15 mm total form the line( your neutral point at 8 mm leading edge down with flaps up looks good, that's where mine is) my plane pitches up a little with full flaps but once I throttle down more on final it settles in nicely and lands smooth as ever. ( I'm working on dropping full flaps a little later on final when speed is down more)
