  • Wobisch
    • 83
    • Merenschwand, Switzerland
    Hi,
    Today I did flight #3 to 6. My final settings are ok now. Took a while to find it. CG a bit further back and less flaps with a bit more up elevator for landing approach .
    Flight #5 resulted in a final approach with no front gear. Damaged it already on earlier flights. When I realized it, I set flaps to early and recovered from a stall in the last turn. Then I landed my Phantom with gear up on the tanks. That was pretty easy and no damage resulted from that.
    All in all I'm happy now. Sweet flyer.
    While I climbed fast with full throttle my Jeti Sensor reported more than 100 Amps. Good to know. But my black Admiral 6S 5000mAh are doing fine.
    Cheers
    Andy
    Click image for larger version  Name:	IMG-20190825-WA0002.jpg Views:	0 Size:	332.8 KB ID:	214151
      Awesome!!!! Great job on the F-4 bro!! Jerry in Texas!!
      • MACH2PHANTOM
        • Sep 2019
        • 8
        Oh Yeeea! Sweet job brother! and welcome to the crew!
        • t33jetman
          • 515
          Repairs completed from my maiden crash. Looks even better now and you cant even tell which wing was damaged. Needed some weathering done also to match the real VF-151 Vigilantes.
          She's ready for a remainder now. Click image for larger version
ID:	214243Click image for larger version
          • MACH2PHANTOM
            • Sep 2019
            • 8
            Damn good job on the weathering! I believe in order to weather properly, one must consider how the bugs and other granulated particles sandblast the front facing areas ( nose, wings, tail, tanks, ordinance, etc.) of every inch of the aircraft. Some will go as far as to say when the front edges of the plane looks "BAD" from the front, "YOUR THERE!". I chuckle because when I think about it, their absolutely RIGHT!. Most skins on real aircraft are all beat up. Almost to the point to where you can barely see details. Its like a hint of faded color and a blur of letters and numbers! Best of luck and fly on.
              • 4838
              Originally posted by t33jetman
              Repairs completed from my maiden crash. Looks even better now and you cant even tell which wing was damaged. Needed some weathering done also to match the real VF-151 Vigilantes.]
              T33JM, Most Excellent rework. Ditto M2P on the weathering. Bravo Zulu. Best, LB
              • t33jetman
                • 515
                Thank you sir.
                The weathering is not done yet, and I will show some updates pics soon . You are right , I looked at the real plane and it is bad so I'm doing more to match it with some more mods.
                • MACH2PHANTOM
                  • Sep 2019
                  • 8
                  I can't wait to see them brother!
                  • t33jetman
                    • 515
                    I checked this morning at 6 am and it looks even better as time goes on. I will have to make a video pics zare not good enough. But I took all of you guys advice this time.
                    • t33jetman
                      • 515
ID:	214401Click image for larger version
ID:	214402 Before and after, a wash in black then some dry brush strokes to highlight. Sorry dont have an airbrush.
                      Click image for larger version  Name:	20190923_055603.jpg Views:	0 Size:	110.9 KB ID:	214398Click image for larger version  Name:	20190924_191327.jpg Views:	0 Size:	157.2 KB ID:	214399
                        • 4838
                        Before and after, a wash in black then some dry brush strokes to highlight. Sorry don't have an airbrush.
                        T33JM, Great Rivet Detail, nice weathering, not too much, not too little. Truly beautiful work. Best, LB
                          Nice!!!!
                          • MACH2PHANTOM
                            • Sep 2019
                            • 8
                            Way to go brother! Looking sweet!🤙
                            • Jetman64
                              • Jun 2017
                              • 113
ID:	214493Click image for larger version
                              Originally posted by Wobisch
                              Hi,
                              Cheers
                              Andy
                              Nice work, here’s mine that I just finished today.
                              • MACH2PHANTOM
                                • Sep 2019
                                • 8
                                Awesome!!!!!!!!!!!
                                  • 4838
                                  Originally posted by Jetman64
                                  Here’s mine that I just finished today.
                                  JM64, Gorgeous Phantom, Sir. Well done. Best, LB
                                  • Jetman64
                                    • Jun 2017
                                    • 113
                                    Click image for larger version  Name:	4453F680-2596-47D5-93C6-24CC514DFA61.jpeg Views:	0 Size:	224.9 KB ID:	214560 Now if only Mother Nature would cooperate and let me maiden my 2 Phantoms. This FW/MRC F-4 is quickly becoming my favorite jet and I haven’t even flown either yet.
                                    • Jetman64
                                      • Jun 2017
                                      • 113
ID:	214562 This is the other Phantom I recently completed, my first art work done on any RC Jet. I do have a little secret when doing this part of the hobby, DON’T FORGET CALLIE GRAPHICS!!! The make you look like a seasoned pro...
                                      Thanks Callie, U ROCK!!!
                                      • MACH2PHANTOM
                                        • Sep 2019
                                        • 8
                                        That's Super Awesome and I would be Super psyc'd. Safe flight my friend!!!!!!!
                                        • t33jetman
                                          • 515
                                          Well it was bugging me, so I added one more mod this morning , before going to work.
ID:	214576Click image for larger version
ID:	214577Click image for larger version
ID:	214578Click image for larger version
ID:	214579Click image for larger version
Name:	Eduard 1190 Bicentennial Phantoms Final 010.JPG
ID:	214580Click image for larger version
                                          Not to bad getting it to look like the real one.
