  • Some pix of my buddies F-4 from the warbird event last weekend...
    • Originally posted by gooniac33 View Post
      Cool pics! Must have been fun. I just have to learn how to LAND mine first! (a required maneuver!)
        If it's 3-4 years old, the fan is probably the 9 blade 3748-17501 Kv outrunner that FW used to put in most of their 90mm EDF's. I used to have that fan in both my F-4's
        Hugh, I'm certain you have posted the answer to my question before, but did you change your ESC with your EDF/Motor upgrades? Best, LB
          No I didn't, all are using the stock FW 130 amp ESC, except my F16 which I got the ARF and put a Castle 130 amp ESC in. I did notice after bench testing and using a high C fully charged battery, I'm pulling 128 amps. No doubt it will be less than that when running free, but it got me thinking that maybe I should have gone to a higher amp ESC. But after upgrading 5 jets with the 12 blade inrunner, couldn't get my credit card to handle 5 new ESC's as well. Besides, the 9 blade inrunner comes with the same FW 130 amp ESC, so the 12 blade can't be that much different. It is a heavier motor with a 39mm diameter vs the 36mm diameter 9 blade, so time will tell. So far have only about 30 flights on the F4's and 20 on the F18 with the new fan/old ESC, and it hasn't fried yet. I do have over 80 flights on the F16 so that combo seems safe.
            Andy, 172mm is definitely too nose heavy, except maybe for a snow plow. I seem to like 195 to 200 mm, allows for a nice nose up landing.
            I know ... I really don’t know how I ended up with it so nose heavy, I like my jets tail heavy ... user error!
            Andy
              That second to last photo is the bomb 💣! Lovely!
                No I didn't, all are using the stock FW 130 amp ESC....
                I thank you, Sir. Best, LB
                • Originally posted by davegee View Post
                  Here is how I land mine......
                  Don't watch the whole video, its not good, just watch the last part with the landing, it was my sons first time filming me flying,,,,,,,
                  Its on 6S with the 12 blade 1835kv and stock ESC.
                  • Originally posted by DCORSAIR View Post
                    Here is how I land mine...... Its on 6S with the 12 blade 1835kv and stock ESC.
                    DC, That'll do just fine. Bravo Zulu. Best, LB
                      Nice landing! Your son did a nice job with the filming. A lot of people have difficulty tracking the plane or keeping it in focus through a little viewing window or monitor as it speeds past. Well done!!
                      davegee
                      • DCORSAIR Beautiful landing, but other than the sunset, what I really liked was the smoke trail (dust) on takeoff, looked very realistic!
                          Thanks guys, I have since sold that F-4 and I lost that runway where it was flown as well, nothing like walking across the street and flying all day long, but thanks to the High Speed rail project here in Ca., they took it out and now I have giant concrete pillars to stare at.
                            This has been my reference point for every landing since you first posted it a while back... it's easily the best rc jet landing I think I've seen (I'm including turbines in that).
                            If it were my landing I'd hang my flight jacket and retire, no improving on that ... 😎
                            • There's that old aviation saying that goes something like: "if you can walk away after you land an airplane, it is a good landing. If you can still fly it again, it's a Great landing!!"
                              Well, I haven't had many great landings lately with my jets, mostly breaking the plastic retract housings, folding the nose gear and dragging to a stop, etc., But today, after replacing the nose gear retract in my T-33, and other similar repairs to my new, but tortured F-4, I finally made some progress. Hopefully I'll climb out of this hole I've dug for myself making consistent, crappy landings. Took a couple of pics of the F-4 after today's flight, with it still resting on its gear!!
                              My Flightline 63 inch Corsair arrived at my home today, so I'll start on that a bit tonight. Click image for larger version
ID:	313411Click image for larger version
Name:	IMG-0418 (1)adjusted.jpg
                              Cheers
                              davegee
                                Cheers
                                davegee
                                Dave, OUTSTANDING looking F-4, looks no worse for the wear. A little actual flight damage for weathering is even more realistic. Always love the "skull & crossbones" on any tail, quite nefarious!
                                  Thanks, Hugh. Appreciate your ideas and help pushing me through this low spot. I may be wrong and prang the next landing in, but things seemed to click for me this time for the F-4 setting up on final to land. Back in the day with my SEA paint scheme F-4, I did get pretty consistent on fairly good landings, but I had definitely fallen off the wagon trying to land this thing.
                                  Still lots more test flights to confirm I can land it safely consistently. Plan to add different, detailed pilots, redo the cockpit with the printed parts, and add the afterburner simulator from Chris Wolfe of RC Geek, when they come in stock for him again.
                                  • I hadn’t flown this in over a year, which is hard to believe, but got in a few hot laps today. Reminded me just how fun it is. I may have to invest in the WPU. ( Weideman Power Upgrade)
                                    • Nice looking aircraft!
                                        That was really a beautiful, stable approach and landing. Well done.
                                        • "If it were my landing I'd hang my flight jacket and retire, no improving on that ... 😎" Quote of the month smithy .......wish I had done that to avoid the embarrassing misses that followed a great opening shot at a pheasant shoot once, heaven to hell in one day!!
