    • 5385
    Read the label. Does it say 8S?
    • f4u ausie
      • 1227
      • Melbourne
      Yes i think its me that needs that gib slap,, from freewing,, was just looking at rc castle website,, and clearly it saiys 8s 1350 kv 5300 g thrust at 115 amps.. just
      was confused the box as hugh said,, says 150 amp for 8s.. thanx 4 everbodys help..
        • 5385
        I was thinking it but wasn't going to say slap yourself.... :)
        Hugh's is the older version.
        • themudduck
          -TMD- Foaming at the Mouth!
          • 1041
          • Burton OH (near Cleveland)
          hey - the only ESC that has reversing on the parts page is the 6S 100amp (for 80mm). Evan said in a previous post that the new 90mm planes are supplied with a larger 120amp reversing ESC... but its not for sale separately - will it be for sale in the future?
            • 5385
            Not sure about your search skills. I see it listed under the F-22, F-4, Zeus, Eurofighter and F/A-18C... For some it's listed in both 6S and 8S versions and for some multiple paint schemes. Looks like it's out of stock though.
            Freewing 120A ESC with 8A BEC with Reverse Thrust Function [070D002010] Motion RC
            In stock-
            Freewing 120A ESC with 8A BEC and Reverse Thrust Function [092D002001] Motion RC
            • locharrow
              • Feb 2020
              • 283
ID:	391656 Now the weather has cleared I thought I'd do a few circuits in the big model before taking out the Freewing F4..........
                • 4817
                locharrow Great photo. Best, LB
                • f4u ausie
                  • 1227
                  • Melbourne
                  Been learning again.. no maiden just yet,, we had lockarrow rain this past week ..i felt like daffy duck.... so been watchin scale modler etc.... new technuiqes( spelling wrong again) still learning but having fuuun 30 degrees now this week will dry out the runway water around 90 f desperatly hopeing maiden next sunday
                  • ElCid
                    • Oct 2017
                    • 114
                    Looks well used, nice job!
                      • 4817
                      f4u ausie, lookin' good, Sir. Best, LB
                      • themudduck
                        • 1041
                        In stock-
                        Thanks Evan, I was looking under Power/Electronic Speed Controls/Airplane and Heli ESCs and then sorted to show only ones more than 100A - and this one is NOT listed there. (There are 33 total) For some reason Motion doesn't seems to list all of the ESCs in the ESC section. Isn't it odd, these two seem identical but have two different part numbers. They can both handle 3S - 8S apparently. Anyway thanks a lot for posting the links....
                          • 5385
                          You are very welcome. It is confusing.
                          • f4u ausie
                            • 1227
                            • Melbourne
                            With regards to all this.. I did a calculation.. 2 actually.. 4.2 volts×6s × 1835 KV.... And same calculation for 8s. 1350 KV. .. I was surprised to see. That the 6s was around 1000 rpm more total.. so will that 120 amp esc still b good for the 6s. Or should I put in the 125 gecho I have
                            • locharrow
                              • Feb 2020
                              • 283
                              Miserable...cold..unwelcoming...foreboding...and that is just the wife, the weather is even worse! No flying for a few weeks now, weather and circumstances just ain't right at the moment. Can't see any more flying till 2024. New F4 is finished so I now have two to maiden. Still looking for the video of your maiden f4u aussie, hope that goes well...i.
                              • Mark 2
                                • Oct 2017
                                • 83
                                LOL! Same here, the weather that is!
                                • nuts-n-volts
                                  Duke City Electric Flyers
                                  • 251
                                  • Albuquerque, New Mexico
                                  That's funny, Loch. I had this old begruzzled drunk for a 1st Class Petty Officer on board my aircraft carrier. He'd tell us all these stories about weather conditions on this trip or that ship during those days. Every story ended with, "...and then it got worse!"
                                  Fly low, fly fast, turn left
                                  • f4u ausie
                                    • 1227
                                    • Melbourne
                                    Its been sh?..t here 2cople good days in the last 2 WEEKS of course only when ya gota go to work.... so off to work again (saturday morn here) and take my batteries to charge. So thisarvo or tmorra mornhoping... ye im sweating...nervous.. crashed 70 mm f35 on maiden but that was 4 years ago(about) way more flying since that howbout a pik of ya newy lockarrow i will also get a grey ghost after xmas arf plus cause i got that 1350 8s looking at me when out in the garage(hanger) which is every day after work... hope all of your weather improves still deciding on scheme ..for the next one i like sundowner,, but we will see.. buy 4 now
                                      • 4817
                                      F4uAussie, You will be fine, Sir. Keep power up a bit in your turns. You have much more power than older OEM stock set up. As stated, you will be fine. Best, LB
                                      • f4u ausie
                                        • 1227
                                        • Melbourne
                                        Done and dusted.... took alot to rotate,, but once up it jumped up.... bit pitch sensative may reduce elev travel but to be honest its ovrall very stable... timer was set at 240.. so down at 3 minuts and 3,8 per cell.. not enuf elev flap mix,, so no flaps on landing.... was a bit fast mayb.... released my flare a bit early ,, and it landed hard,, took out one main gear.. easy fix.. overall very happy.. to b honest the 6s is fast enuf.. cg was 180 not the190 (rich bakers fault)
                                          • 4817
                                          f4u ausie My congratulations, Sir. Bravo Zulu. Best, LB
