Mine has shipped!!! I have a lot of 3S 2200, so I am wondering how piggy it will fly with the larger size battery?
Official Freewing 64mm Lippisch P.15 Thread
Mine arrived today. It took about twice as long to get it out of the box, as it did to put it together!! (That's MRC's terrific packaging for you) I had about 12 inches of space on my workbench so, no problem. I just needed to move the bombs out of the way!
Perfect!
.Marc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
Got the P-15 today, took about 15 minutes to put it together including installing the Admiral 6ch receiver and setting up the radio, after the Foam-Tac cured a couple hours I took it out and flew it. I really like my F-8 and F-105 but the P-15 is a whole different story...it is crazy fast and stable but be careful doing rolls on high rate as it's hard to see when it gets out there. To help with orientation I repainted it in a fantasy livery and added some leftover decals, I did the underside in flat gray and just masked over the factory decals.
- Likes 4
Originally posted by dkalwishky View PostMine will be here tomorrow, for those that have it can you answer a question for me?
Are the two wing servos Y'ed together and then plugged into the elevator or aileron spot in the receiver? I know the transmitter will get set up as a delta wing.
Originally posted by goosekiller1 View PostTiredIronGRB Love The Tiger Stripes JG26 ( 'schneller machen ) ;)
- Likes 2
Originally posted by Bearcat View PostNot much of a build is it?
Can't wait!!
You insert the CF tube. Then apply glue to the wing, insert the connector wire, and stick the wing on. Then glue the other wing, insert the wire, and stick it on. Then glue the rudder on.
I just inserted the antenna (didn't glue that) and pooof ... done.. There are only 5 pieces including the antenna and fuselage. Super-easy.
Actually it took me longer to get the wires into the channel through the fuselage, they were being a bit stubborn. That increased my build time (and blood pressure) by 83%., but I got over it.Marc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
There was a Belgian F104 that was painted like TI's model. It was saved for a museum. I've always liked this scheme and I painted my F-104 this way.
Originally posted by themudduck View PostThere was a Belgian F104 that was painted like TI's model. It was saved for a museum. I've always liked this scheme and I painted my F-104 this way.
