Hey Brian,
Welcome to Hobby Squawk.
Glad to have you onboard, Sir.
Great gift and her heart was in the right place.
Can't go wrong with Evan D 's advice.
Best, LB
Money is power… a JetFan/HET would be best but expensive. FreeWing has a good fan too but my recommendation would be this, fairly cheap, good power and light weight. Also get the 120A reversing ESC.
Buy Freewing 90mm 12-Blade EDF 6S Power System w/ 3668-1960Kv Inrunner Motor online at Motion RC. Order online with fast delivery.
All looking for some help. IF you had it to do again which motor and speed control? My wife bought me this plane but got the one missing the EDJ and Speed control. I went to purchase the one they are installing in the PNP but it's out of stock. Any ideas? I want to keep it on 6 cell but want as much power as possible.
Thanks,
Brian
'Leave a comment:
Rich049, Welcome to Hobby Squawk. Glad to have you onboard, Sir.
I just measured my Hornet and it is just at or <12 inches top of the vertical stab to the bottom of the fuselage with the MG retracted.
I transport my Hornet with both wings on in the back of a pickup.
I store mine with one wing off and that side against the wall on a rack.
I hope this helps, you;re going to love this fast mover.
Keep the speed up with full flaps on landing, though, just sayin' as she has high wing loading and a thin rib profile.
Best, LB
Please tell me the height of the plane with retracts retracted as the rear shelf is low, about 17 inches clearance. Also, how do you guys transport this jet,... wings on or off? My hatchback is only 36 inches wide. Do you routinely remove both or just one wing? Thanks you in advance. This would be my first large edf.Leave a comment:
Watched it over the weekend. Agreed it's fantastic!https://www.amazon.com/Blue-Angels-B...o%2C101&sr=1-1
Hornet Homies, :ba_f18::ba_f18::ba_f18::ba_f18: :ba_f18::ba_f18:
For anyone who has Amazon Prime Video (comes with your Amazon Membership) there is an absolutely 'must watch' doc on the Blues.
Great in every respect IMHO.
Enjoy and "Never Forget".
Best, LBLeave a comment:
Has anybody put EFlite/FMS main gear struts on this jet? I've seen Brent Hecht's video with them and it looks amazing. Thinking of doing 90 degree rotating retract units - maybe the ones for the A-4 Skyhawk. Does anyone know if those will fit? Screw hole spacing the same? I'm determined to make this work :)Leave a comment:
Hi All ,
Lucky to have stumbled across this post. Just placed and order for a Blue Angels version , will be dropping a Xicoy45 into it for a turbine conversion .
Couple of questions straight up that my research hasn't' found me the answers ..
1. What turbine conversion kit does people recommend . I saw the BIGBOYRC , doesn't seem to do it anymore.. The NOVAJETS site is down .. So far my best option is the TOP-Design version.
2. What size main wheels are the Hornets.. I need to put electric Brakes on it . so want to order the same size Main Wheels.
3. Anything that i need to know / Modify Straight up on this Jet ? 290 pages .. im on page 14 .. ill Keep reading each post but a breakdown would be Great.
Thanks in Advance..
Brgds
MichaelLeave a comment:
Hi Hugh Wiedman I think the mystery has been solved by MRC tech support. The issue might be the battery connector i'm using. I purchased a parallel connector instead of series. This makes sense. I'll confirm once the new connector arrives.
Thanks Hugh Wiedman Thanks for sharing your experience and recommendation to recalibrate the throttle. I hope that's the fix. I'll let you know either way. I might also change the ESC all together. I read that the new Hobbywing ESC (rebranded ESC sold via Motion) act or sound are slightly different from previous ESC versions.
The new FW reversing ESC (which appears to be the same as the Hobbywing Skywalker V2) is in several new and updated EDFs from Freewing. If trying to program it with the programming card, the current one listed on MRC's site doesn't work. No new programming card is listed yet. If programming the ESC using the transmitter
Thanks, LB. This was V2, just "eyeballed" and dremmeled (is that a word?) from a small block of basswood. I can easily remove it for a V3 or V4 version, if I decide to go that far. For now, it'll work.
Cheers
davegeeLeave a comment:
DG, Well it's like I always say, "If the more scale tail hook end point "shoe" fits, wear it." Best, LB
This is only a guess, but have you recalibrated your throttle? I fly off grass as well and have 2 F-18's, both still on 6S with the 12 blade 4068-1835 Kv inrunners and they get off very quickly on a single 6S SMC HiV 5900, so yours on 8S should be even better. I did convert 2 F-4's and my F16 to 8S with the same fan you are using in the F-18 and fly all of them on the SMC 8S HiV 5900 packs. Those "rocket" off the grass so I would think your F18 would also, especially since the SMC 5300 packs have a slightly higher C than the 5900's. I felt the F18 on grass with the 12 blade 6S fan flew just fine (and didn't want to add any more weight in using an 8S fan and battery) so I have yet to convert the F18's to 8S.
If you can, put a power meter on and confirm the amps and watts drawn. If I'm not mistaken, my 8S fans with SMC HiV packs are drawing about 138 Ah and 4300 watts at full throttle with a fresh pack (static on the bench). If you're not close to that, you are not getting to max output. Let me know as I'm very curious to find out how the F18 would be on 8S, as I'm loving it with the F4 and F16.
did an experiment carving out a more scale tail hook end point "shoe" for the Hornet. First attempt out of basswood, might try another one but this one suits me, for now.I just finished up another mod for the F/A-18C Hornet. This is a movable tail hook via a small servo in the tail. 3D printed parts courtesy of Elbee that I printed up from his STL files and put it together. I had to order a small Du Bro connector pin that came today, so once I had it in hand, the finishing up went relatively quickly. There's always a bit of fiddling to do on these things like servo travel, checking security of the mechanism, and all that. But it is well worth doing, for me. I have put a movable tail hook in my F-14D, A-4E, and a Grumman F6F Hellcat years ago. This one is not stressed to actually "catch" the airplane, but I'll probably do some photos of it in the air with the hook down, just for yuks.
Cheers
Davegee
Cheers
Davegee
This is only a guess, but have you recalibrated your throttle? I fly off grass as well and have 2 F-18's, both still on 6S with the 12 blade 4068-1835 Kv inrunners and they get off very quickly on a single 6S SMC HiV 5900, so yours on 8S should be even better. I did convert 2 F-4's and my F16 to 8S with the same fan you are using in the F-18 and fly all of them on the SMC 8S HiV 5900 packs. Those "rocket" off the grass so I would think your F18 would also, especially since the SMC 5300 packs have a slightly higher C than the 5900's. I felt the F18 on grass with the 12 blade 6S fan flew just fine (and didn't want to add any more weight in using an 8S fan and battery) so I have yet to convert the F18's to 8S.I need some help. I decided to upgrade to a 8s setup. I'm using the 4075-1350kv FW 8s edf w/ the 120a reversing ESC which is rated for 8s. I'm barely getting any thrust for the jet to roll on a nicely manicured RC grass field. I've ensured my throttle is calibrated and ESC is programmed. I'm using 2 - 5300 4s LiHV SMC packs.
Any ideas to why the power is anemic? I'm more than happy to provide additional details if anyone has any ideas.
If you can, put a power meter on and confirm the amps and watts drawn. If I'm not mistaken, my 8S fans with SMC HiV packs are drawing about 138 Ah and 4300 watts at full throttle with a fresh pack (static on the bench). If you're not close to that, you are not getting to max output. Let me know as I'm very curious to find out how the F18 would be on 8S, as I'm loving it with the F4 and F16.Leave a comment:
Any ideas to why the power is anemic? I'm more than happy to provide additional details if anyone has any ideas.Leave a comment:
: Check. Functioning unit
: Check. Nicely done, Sir. :trophy: Best, LB
