  • Daryl
    • Aug 2020
    • 48
    • Calgary, AB
    Late to the party...searched about grey only paint or blue angels. why no other liveries?
      • 2693
      From the grey you can make any livery your heart desires! Just assume the grey is the primer coat. Just imagine what you can do (especially with Callie's help), cause this started out as a "grey" (yes, I love to post pictures of my F-18 Canadian, have to get some satisfaction out of 6 weeks of painful work that caused my BP to run wild, sometimes I hate to fly it even, but it does fly outstanding and looks so nice in the air).
      • James
        Administrator
        • Aug 2017
        • 1543
        Hey Daryl - Welcome to Hobby Squawk! - With this version of the F-18 (C-model) it was done with the Blue Angels in mind and then since there are nearly endless liveries from all the years this bird served and still serves, we felt a base gray was necessary. Our good friend Callie-Graphics gets all the dimensions of all of our models and she has and will make any livery you wish. But our community is chock full of modelers and tinkerers who love nothing more than to make things their own.
        • Mizer67
          • 374
          Callie is a bit backed up. I understand the desire to not have to paint a livery also.
          I was pretty leery of trying and I have to say, there's a reason why I don't do it much, the result wasn't great without an airbrush and my modelling skills have never been stellar. But, I learned something and will do better the next time....if there is a next time.
          • Daryl
            • Aug 2020
            • 48
            • Calgary, AB
            Thank you guys, its all right that Callie is busy at the moment. Will be awhile till I pull the trigger on this..just pre ordered the Mig29 ;)
            btw nicely done Hugh!
            • Corsair nut
              Jets...warbirds...mmm hmmm
              • 218
              • Tehachapi ca
              Yes, I worked on them and other carrier based planes for years. Not to say that I do mixing that the real planes do though, I do mixing that I want to try and see how it works.
              Remember to make appropriate pitch mixing especially for the rudder airbrakes.
              On my f18 i had tailerons...flaperons..full span flaps. One thing i did to reduce top stalling on flare and also accerated stall on hard pulls...was to mix reflex into the the ailerons with elevator up input. So as i started to flare...the ailerons reduced their flap throw..to help reduce the tip stalling. It worked really well. I use the same thing on my f14 full span flaps
                • 4821
                Late to the party.
                D, You're not late, just in time actually. Welcome to "The Squawk". Best, LB
                • The43rdHammer
                  Smithy
                  • Aug 2019
                  • 118
                  • South East England
                  No, not late at all... I've only just got my high performance version which I'm busily making a pigs ear of converting into a bumble bee:
                    • 4821
                    The43rdHammer , Whoa, now that's some articulate work. Looking good, Sir. Best, LB
                    • Daryl
                      • Aug 2020
                      • 48
                      • Calgary, AB
                      That is amazing!
                      • The43rdHammer
                        Smithy
                        • Aug 2019
                        • 118
                        Thanks chaps, that's very nice of you to say so 😁
                        I'm going to attack the canopy and some of the fuselage as where the decal needed to be trimmed there are some join lines (admittedly you need to look closely to see them but still...)
                        I've yet to lacquer in matt yet, which will dull everything down and I bought some of these Army Painter sprays which are supposed to be very good. I know a lot of the professional model makers use them.
                        Will report back:
                        Andy
                          • 2693
                          Now that is outstanding, can't wait to see the final version, kudos to you, looks like that required a ton of patience!
                            • 2693
                            I know it definitely would be wrong, but wonder how the new Mig 29 would look in this Bumble Bee scheme, not like I'd ever do something that's outrageously off from scale!
                              • 8205
                              Wow kudos to your patience The43rdHammer ! If I had half of yours I could finally get some of these nagging projects done around the house!
                              • Necroscope
                                • Mar 2020
                                • 38
                                Finally pressed the button on a FW F-18 Blue Angels High Power. Its an itch that has been bothering me since that disaster of a plane, the E-Flite F-18.
                                I'm looking forward to the build, is there anything i need to check (other than the usual)? I will be using a Turnigy 5K HD pack with a AR637T RX (with a mild gyro mix).
                                She should keep me busy until the Fulcrum arrives in the UK. Happy flying.
                                • seaviper
                                  ATC retired
                                  • Aug 2016
                                  • 1092
                                  • Philadelphia Mississippi
                                  I think I will program in some reflex as well. Also, is the book CG correct? Or should it be a little more forward? It seems that the videos I have seen show people running the CG at about 10mm forward of the book value.
                                  • Corsair nut
                                    • 218
                                    • Tehachapi ca
                                    I found the factory cg to be pretty good. I actually went a lil bit aft of recomended. But i dont recomend that until you are comfortable with the airplane and the throws are dialed in. Mine flew inverted extremely well and did really nice flat slow rolls. Loved how it flew
                                      • 2693
                                      I actually fly mine about 3-4mm aft of the book CG and for me, that's where it seems best. You will find that at the book CG and especially forward of that, you will need a LOT of up trim.
                                      • Corsair nut
                                        • 218
                                        • Tehachapi ca
                                        Thats about whete i was. Just a lil bit aft of recomended. FW recomendrd cg's are nornally a bit on the nose heavy side for obvious reasons. Its a decent place to start anyways. I love experimenting with cg. On the a4 i ended up 18mm aft of the recomended aft location and tsmed down throws. Flies sbsolutely awesome...but i worked it back 3-4mm at a time
                                          • 4821
                                          Hornet Howners, It's all 'baby-steps' though making progress with the paint and install of a few more 3DP bits. Having big fun as she's starting to look like something again. Somewhere in the instructions I recall reading the 'build time' was 2 hours and thinking, "that would would awesome." More when there's more. Best, LB
