  • themudduck
    -TMD- Foaming at the Mouth!
    • 1041
    • Burton OH (near Cleveland)
    Have any of you matched the white paint (Home Depot) - if so, please post a picture of the jar showing the color codes. Would greatly appreciate the favor!
    • Woodcock
      Old Returning Pilot
      • Apr 2018
      • 830
      • SoCal
      Originally posted by Corinator
      I’m actually sitting here off the A1A in Cape Canaveral waiting for the launch. Flew down here from Scottsdale, Arizona to see it. 50/50 likelihood they’ll light the candle at 1633.
      Nice!
      • themudduck
        • 1041
        OK well I went out today and got a jar, I think its a very close match.
        I used the Behr "satin enamel" base, #UL220, and the color code is: AXL:2 (just two drops of something). Anyway it seems a like a really close match. I touched up a couple of dings.
        • I-fly-rc-aircraft
          Always learning
          • Jan 2019
          • 269
          • North Augusta, SC
          I thought the steering was supposed to stop when the gear is up.
          • MikeT
            Here......Hold my beer.
            • 1060
            Nope. There's a link that keeps it from totally turning but it still turns some.
            Mike
            • I-fly-rc-aircraft
              Always learning
              • Jan 2019
              • 269
              • North Augusta, SC
              I printed a double LED landing light and don't want it interfering with anything. May have to design another light holder.
              Tom
                • 8835
                Besides what Mike said, you can stop the steering servo from working completely if you put it on a separate channel and mix it with Rudder and activate via the gear switch so that it only works when the gear is down.
                • I-fly-rc-aircraft
                  Always learning
                  • Jan 2019
                  • 269
                  • North Augusta, SC
                  I'm all out of channels. Thanks just the same.
                    • 8835
                    Then you must rely upon the slider mechanism to NOT move the strut when the servo moves OR, like I do, get a higher channel RX.
                    • LowandSlow
                      • 40
                      • Lake Tapps Washington
                      Doesn't the blue box take care of that? When my retracts are up the steering is disabled.
                      I came into this a little late so maybe I misunderstood the original post.
                        • 8835
                        It might. I've never paid much attention to it. I do the mix thing on planes where it's hard to zero the steering independent of the rudder. This one never presented a problem so I didn't have to deal with it. The plane is hanging in the next room. When I get a chance (and remember), I'll throw a battery in it and check. If it's works through the blue box, then it should stop moving completely when the gear is up. If there is still some movement, then we go back to my theory that these blue boxes can have some slight "cross talk".
                          • 8835
                          Just tested the steering relative to the gear position. As soon as the switch is thrown to retract the gear, the steering servo on the front retract goes dead and remains that way. As soon as the switch is thrown to put the gear down, the servo begins to work even if the retract has not fully extended. When it's "dead" there is absolutely no movement in the servo, not even a little when the rudder stick is moved, even to its fullest. If yours has some movement, then that tells me there is some "crosstalk" within the blue board.
                          • Swarick
                            • 36
                            There is NO lights on the nose strut of the Boeing 8MAX. Older models of the 737 had a taxi light on the nose strut, but the 8MAX has LED light arrays in the wing roots that are aimed where the taxi light used to point.
                            • I-fly-rc-aircraft
                              Always learning
                              • Jan 2019
                              • 269
                              • North Augusta, SC
                              Mine must be "crosstalking" since it still steers when up.
                              Tom
                              • MikeT
                                • 1060
                                Tom
                                Than why is there a need for that rod on the nosegear that the servo arm slides on when in the up position? I need to look at mine next time I'm flying it but I know for a fact that the servo is moving when in the up position I can hear it.
                                Mike
                                • I-fly-rc-aircraft
                                  Always learning
                                  • Jan 2019
                                  • 269
                                  • North Augusta, SC
                                  Mike
                                  The rod is there to rotate the strut when the gear is down. The rod from the servo is to adjust center so it tracks straight. If I understand it correctly, the blue box (MCB-E board) is supposed to inhibit the steering servo when the gear is up. If/when the blue box isn't doing it's job the steering will still be enabled when gear is up.
                                  Tom
                                  • MikeT
                                    • 1060
                                    Tom
                                    The servo connector slides up and down , forward or back as the retract is retracted or extended. When retracted the slider moves freely back and forth ( at least on mine it does) as rudder input is applied. The tracking adjustment is on the servo end, If the connector on the slider rod moved up and down when the gear was extended you would have no steering. This set up is commonly used.Like I said I need to check mine out closer next time I fly it.
                                    Mike
                                    • I-fly-rc-aircraft
                                      Always learning
                                      • Jan 2019
                                      • 269
                                      • North Augusta, SC
                                      MikeT. Mine does what yours is doing but it isn't supposed to.
                                      Tom
                                      • MikeT
                                        • 1060
                                        Tom
                                        Sent a info request to Motion just to clear this up.
                                        Mike
                                          • 8835
                                          On other planes, the slider does what Mike says. It slides both as the retract is being operated AND when the steering is worked when retracted. In the AL37, it only is there so that the rod does't bind when the retract is operated (since the steering servo doesn't move anytime the gear switch is in the "gear UP" position. On mine, as I said, when the switch is thrown to "gear up", the steering servo goes dead, even if the retract is still moving. Listen carefully, it may be the rudder servo you are hearing.
                                          In the case where the steering servo IS moving no matter what the gear switch position is, double check to make sure that the steering servo is plugged into the correct pins on the blue box. There should be a unique pin set just for "steering" and another for "rudder".
                                          In a defective blue box, "crosstalk" should be minimal, usually not full travel.
                                          NOTE: EDIT --- WRONG INFORMATION!! MY APOLOGIES!
                                          I took a look at my TX. I HAVE A MIX FOR THE STEERING SERVO. That's why mine does what it does.
