  • I-fly-rc-aircraft
    Always learning
    • Jan 2019
    • 269
    • North Augusta, SC
    Ok, so the manual calls for only one setting for throws on the elevator and ailerons. 28mm and 15mm respectively. Are you pilots setting yours this way?
    Tom
      • 4856
      Originally posted by Indyflytime
ID:	253486 I don't have flight video yet but the maiden of the "Maiden" went great. 😁
      IFT, Just love that livery. Bravo Zulu, Sir. Best, LB
        • 8228
        Ditto what LB said.
        • I-fly-rc-aircraft
          Always learning
          • Jan 2019
          • 269
          • North Augusta, SC
          Ditto what Aros said.
          I took the easy way out and used the decals in the box, Lol
          Tom
          • I-fly-rc-aircraft
            Always learning
            • Jan 2019
            • 269
            • North Augusta, SC
            Here's mine. Received it yesterday. Ready for maiden. Click image for larger version
            • I-fly-rc-aircraft
              Always learning
              • Jan 2019
              • 269
              • North Augusta, SC
              I can't get the winglets back far enough on the AL37. Is there a fix I don't know about?
              Tom
                • 8814
                Tom
                Clean the slot of any excess material that might be blocking the pins from sliding in and also do same on the pins and winglet side of the mating surface.
                • I-fly-rc-aircraft
                  Always learning
                  • Jan 2019
                  • 269
                  • North Augusta, SC
                  I got it sorted with my trusty file. Thanks
                  Tom
                    • 8814
                    Finally maidened my WestJet 737 Max 8 today after having it hang from my ceiling for months. My camera failed to capture the flights but a friend (who is a WestJet pilot) came to watch and he took several videos of the 3 flights and put together a short video to show the essence of what this plane does. Not shown are the rolls and loops that I did just to see if it could (and it can with ease). It needed some heavy aileron trim but that's because the flaps weren't equal. Once I align the flaps properly, I should be able to take the trim out. Even with the heavy trim, this plane flies like it was on rails. Then I turned up the gain on the gyro and it was like it was glued in place in the air. No wing rock at all as seen in some examples of this model. This one is very sedate to fly and was definitely worth adding to the hanger. It's a great crowd pleaser at the field.
                    • I-fly-rc-aircraft
                      Always learning
                      • Jan 2019
                      • 269
                      • North Augusta, SC
                      Well done.
                      • GliderGuy
                        • 1412
                        Originally posted by Spinny Testaverde
                        Has anyone tried to do a cabin light modification yet?
                        Hi...Enter Window Lighting in the search box. You'll see some results.
                        • I-fly-rc-aircraft
                          Always learning
                          • Jan 2019
                          • 269
                          • North Augusta, SC
                          Maiden flight in the books.
                          • MikeT
                            Here......Hold my beer.
                            • 1060
                            Maiden complete. A bit windy but it flew great. I think this is a keeper. Sorry no video. Next time.
                            Mke
                            • I-fly-rc-aircraft
                              Always learning
                              • Jan 2019
                              • 269
                              • North Augusta, SC
                              Mke
                              Congrats Mike
                              • I-fly-rc-aircraft
                                Always learning
                                • Jan 2019
                                • 269
                                • North Augusta, SC
                                Tom
                                • MikeT
                                  • 1060
                                  I just dialed in some expo and flew it. 25% aileron and 30% on elevator.
                                  Mike
                                  • GliderGuy
                                    • 1412
                                    Click image for larger version  Name:	Phil Grease_Amazon.jpg Views:	0 Size:	34.3 KB ID:	254582
                                    Has anyone tried Phil ball and roller bearing waterproof grease to fix the "baby-coach" noise of the landing gear wheels? A bicycle shop owner suggested it will absolutely stop the noise.
                                    • I-fly-rc-aircraft
                                      Always learning
                                      • Jan 2019
                                      • 269
                                      • North Augusta, SC
                                      Grease and or oil will attract dirt. Try a dry lube which is safe for plastic.
                                      • avanti127
                                        • Apr 2018
                                        • 96
                                        TriFlow, works wonders!
                                          • 8814
                                          Grass ops on a windy day ................................
