  • Corsair nut
    Jets...warbirds...mmm hmmm
    • 218
    • Tehachapi ca
    Some shots outside..
      • 4817
      CN, Great repaint. Diggin' the extra attention you paid to the fuselage shaping and nozzle work. Nicely done. Best, LB
      • Mark 2
        • Oct 2017
        • 83
        Finally got to maiden my T33 today, what a sweet flying jet!
        Handled the well cut grass at the field easily, and landed nicely with one stage of flap. 45% left in the Admiral 5000 pack with 3 minutes set on the throttle activated timer, so I reckon I can cautiously increase the flight time a little.
        Very happy with this jet!
        • Knifeedge98
          AmericanAirfoil
          • Aug 2020
          • 3
          Originally posted by Radar-Guy
          Here are the final 3DP parts for the cockpit.
          - Front panel coaming. I trimmed mine by 4mm in height.
          - Canopy arch plus mirror and compass housing
          - Canopy frame cross brace (located above rear coaming).
          I found a nice file for a control stick and scaled it down:
          This is a replica of a B8 Flight Stick used in many helicopters and fighter jets. The model has holes cut out to place m10x1.25 nuts which is the thread size used for many shift knobs. I did my best to recreate the shape of the knob based on many photographs.
          Click image for larger version Name:	Final cockpit parts.jpg Views:	0 Size:	134.7 KB ID:	241316Click image for larger version Name:	IMG_3581.jpg Views:	0 Size:	64.2 KB ID:	241323Click image for larger version Name:	IMG_3584.jpg Views:	0 Size:	70.2 KB ID:	241324Click image for larger version Name:	IMG_3585.jpg Views:	0 Size:	78.4 KB ID:	241325
          How would i go about finding these additional canopy files to print ? I found the list of a handful of files just now , but i cant find the speed brakes or your mirror component set for the cockpit?
          can i buy them somewhere? Thanks in advance!
          • Knifeedge98
            AmericanAirfoil
            • Aug 2020
            • 3
            DISREGARD I FOUND THEM!! SORRY!
            • Corsair nut
              • 218
              • Tehachapi ca
              First video of my highly modded t33
              • timmybeetle
                Warbird addict
                • 132
                • Netherlands
                Testing EDF unit.
                I bought me EFlite F4 II with FMS 80mm 12 blade, ( 3270 2000Kv )
                So I was wondering difference between FW 80mm 9 blade ( 3658 1920Kv ) and FMS 80mm 12 blade.
                So I used Phantom as test plane.
                Results:
                1. FMS EDF Unit Static trust: 2.25 Kg, Amp: 96.7A, Volts: 22.85
                2. FW EDF Unit Static trust: 2.25 Kg, Amp: 108.1A, Volts: 22.83
                Conclusion:
                FW EDF Unit is consuming more current than the FMS EDF unit at full throttle testing static trust.
                Also I had thought that less blades would use less amps
                Greets Hans
                I will put FMS EDF Unit in my T33 and see how it will perform in flight compared to my FW EDF Unit.
                Well the FMS EDF unit does not fit in T33 ore I have to make adjustment sadly.
                Last edited by timmybeetle; Oct 21, 2021, 12:30 AM. Reason: FMS EDF doesn't fit in T33
                  • Nov 2013
                  • 2651
                  • Cody, WY
                  Superbly done, Corsair Nut!
                  davegee
                  • Justwingit
                    • 46
                    • Las Vegas, NV
                    First video of a two parter. In this one, Brent gives us a good walk around to discuss the various details and mods. He also tells a funny aviation tale, that involves the background of the model's subject matter 😉
                    Enjoy 😎!
                    • Justwingit
                      • 46
                      • Las Vegas, NV
                      And Brent's flight demo of his superb T-33 Shooting Star recently at St. George Utah 😎
                      Enjoy 😁!
                      • F22trainer
                        Piper PhD
                        • Mar 2018
                        • 1484
                        • Sun City, Az
                        Say bye to the Liftwaffe version
                          • 4817
                          F22, Ummm; something really , no doubt. Best, LB
                          • F22trainer
                            Piper PhD
                            • Mar 2018
                            • 1484
                            • Sun City, Az
                            Going this direction LB, without the tip tanks and with the Early round wing tips.
                              Elbee commented
                              Editing a comment
                              Definitely qualifies as "Cool". Aluminum Finish or a painted finish on the original livery? Looking forward to seeing your progress. Best, LB
                          • F22trainer
                            Piper PhD
                            • Mar 2018
                            • 1484
                            • Sun City, Az
                            I didn’t at all like the silver metallic, so I tried what was supposed to be metallic gray. So much for the T-bird scheme.
                              • 4817
                              F2, Do we get a sneak preview of the new livery? Best, LB
                              • F22trainer
                                Piper PhD
                                • Mar 2018
                                • 1484
                                • Sun City, Az
                                  Originally posted by timmybeetle
                                  Testing EDF unit.
                                  Results:
                                  Conclusion:
                                  Greets Hans
                                  That would probably be due to pitch differences? Or maybe the 9 blade is grabbing more air and the 12 blade is developing vacume pockets between blades allowing for alittle less load? Just some thoughts.. also if you have a 3d printer you can print a shorter ring to fit on the fms fan so you don't have to cut foam, I seen one on thingiverse. Just search for freewing.
                                    • 8747
                                    Unfortunately, it’s not just the ring. It’s the whole fan unit. On the most part, FMS fans are 1mm to 2mm bigger in diameter than the Freewing counterpart. Sometimes, even the length of the fans are not the same. This creates a further necessity to hog out some foam. I’ve installed FMS fans into FW planes and without gouging out foam, the hatch doesn’t fully seat flush. There is always about a 2mm hump. I use colored electrical tape and tape all around hatch to help with aerodynamics. To make it flush, I’d have to hog out about 1mm all the way around the fan housing.
                                    90mm EDFs tend to be more similar between FMS and FW.
                                      Ah gotcha, thats a bummer
                                      • F22trainer
                                        Piper PhD
                                        • Mar 2018
                                        • 1484
                                        • Sun City, Az
                                        Hint
