Official Roban 120mm A-10 Warthog V2 EDF Jet Thread
The bottom of the nacelle pod is solid, I'm cutting enough of that material away for easier access, I want the permanent mount for strengthComment
Is it just me, or does anyone else on this forum have a severe case of 'shop jealousy' from those photos? Ha ha.Comment
Shop envy? I lost my humble little workshop in the split when we sold the house. This is the first giant scale plane I've built on a kitchen table. Had it not been an arf for the most part, I'd have never attempted it, still no word on the maiden? wish you the best of luck
JinkComment
Listen guys , I have an idea. Everybody that's flown this bird says it's really hard to rotate on takeoff because the mains are so far behind the CG. I'm thinking of getting Mitch at Down and locked to make me a longer nose strut, there's room, just haven't measured how much I can get away with yet. And slightly shortening the mains so it's not terribly noticable that they are a little further back in the pods than normal. It would give it a better angle of attack on takeoff and should help with the rotation problem. Any thoughts
JinkComment
Ground stance (including nose AoA) is a concert with thrust line and other factors, but suffice to say I think increasing the nose AoA is more likely to help than hurt this model's rotation characteristics.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
thanks alpha, I think it will help alot, have you ever seen the CARF A-4 Skyhawk take off. It actually has an actuator on the nose wheel that raises the angle of attack considerably. The model and the real aircraft have a pretty extreme nose down attitude sitting on it's gear, the real bird takes a loooong take off roll to rotate. The model was the same if not worse that is why Mitch at D&L came up with the whole nose wheel actuator deal, and if you look at all the A-10 foamies, they all have a slightly positive angle of attack sitting on their gear. The roban A 10 has a slightly nose down AOA which I believe is scale, but I'm trying to build a model that flies and handles as good as it's going to look. And those mains are waaay behind the CG. All opinions from anyone is appreciated
Adding a little edit here, I believe the A-4 was primarily used launched off Aircraft Carriers. It's not like anyone has a mini 100 ft aircraft carrier to launch their 1/4 scale A-4 Skyhawk off of to start with, I'm pretty sure the whole nose actuator thing is to maintain scale look and taxi, but if you google the vid of the CARF model taking off you can see how much they raise the nose after getting lined up for take off. And if you remember back to the old Byron A-4 the gear was no where near scale. It had a really high AOA. I know that there are other factors involved in the rotation performance but changing the AOA on this A-10 is the only way I can come up with to try to improve takeoff performance. If there's something anyone else can suggest I'm all earsComment
I was totally wrong about the A-4's AOA sitting on it's gear, I don't why that big carf model has an actuator on the gear to raise the nose, it's probably a feature on the full size as well because I did see a couple picks of A-4's sitting slightly nose down.Comment
No issues rotating the Roban A-10 with the stock strut.
Yes, the full scale A-4 has a hydraulic actuator in the nose strut to increase the AOAComment
Life batteries don't self discharge and dont suffer when stored fully charged, you can charge them now and they will be ready to go at Christmas and it won't hurt the cells. It's one of the best features of A123/LiFe batteries
I really want to pull the trigger on this plane, but for a twin turbine conversion. The lack of talking about this model is really keeping me away. I wish there was more pilots talking and sharing about this plane.Comment
