  • Dr Dave Of Death
    David Upton
    • Aug 2019
    • 2
    We fly exclusively off grass. The FW SU35 stock out of the box with outrunners has a pretty short take take off roll. And the thrust vectoring allows you to rotate sooner and maintain flight. All I can say is the power to weight ratio of the new Mig29 will be beast mode. I suspect a shorter take off roll on grass then the SU35. Or very similar. I am waiting for the order button to pop up for the TV unit. Hoping Alpha can price this ad on at under $75.
    • Mizer67
      • 374
      I don't think the T/W ratio of the Mig-29 is any better or worse than any other recent 6S large format FW jet.
      4300 grams empty, maybe ~5900 grams AUW with two 5000's with a couple of fans that put out maybe 2400 * 2 = 4800 grams static (once installed). So give or take .8 or so, depending on battery or perhaps .85 at peak thrust and ~.75 settled ~3.7V/per cell.
      I'd bet dollars to dimes even with TV the Mig won't take off shorter than the SU-35. The SU has a natural advantage lighter EPS foam and fewer (heavier) scale features, even on older EDFs.
        • 8756
        I agree with your assessment. The SU-35 has a published "flying weight" of 2600g. Even with the stock EDFs, the stock static thrust is 4100g. Not hard to do the math on this one. If you upgraded to the "high speed" EDFs, you'd have 4400g of thrust. It really becomes a rocket ship.
        I think anyone who thinks the stock Mig will get off the grass in shorter distance than an SU-35 is going to be in for a nasty surprise. They may find themselves picking foam splinters out of the tall weeds at the end of the runway.
        You can almost always rotate sooner with TV, but that doesn't mean the plane will be going fast enough to actually fly. Without a very good thrust to weight ratio, that only spells stall and an embarrassing 6kg auger into the dirt, more because most of those maneuvers are accompanied by power when the pilot desperately tries to save it.
        PS. I have the SU-35 with the "high speed" EDFs in it. It's very impressive for what it can do. I seriously don't think the new Mig will out perform it - not even close. That won't stop me from getting one. It's still going to be a wonderful airplane.
        • HellHathNoFury
          • 247
          2 batteries vs 1 battery & the difference in weight of the landing gears immediately spells Porkiness in favour of the Mig29..Can’t compare Oranges to Apples .. At least the Mig29 doesn’t dint at the slightest glance Also the Mig29 Fuselage won’t be Egg crate Fragile like the SU-35 out of the Box ..
            • 8756
            You forgot to mention the retracts on the SU-35 that are made from toothpicks and mounts made from dry pasta.
            • HellHathNoFury
              • 247
              Such Fond Memories.. Or Not Much on par with the 90mm F-18 V1 landing gear..
              • Jacckall
                L-39, Mig-29, Su-29
                • Aug 2020
                • 22
                • Slovakia
                First crash! Oh my god! Freewing Mig 29 maiden and crash! Its not my plane, i just found this video now... oh...
                • Skosh25
                  • Mar 2019
                  • 177
                  • Denver
                  ^Why doing a thorough pre-flight is so important.
                  • Gringotuerto
                    • 409
                    • San Diego
                    Nice that he returned it to the field for a dramatic crash on the runway instead of an anti-climactic disappearance into the trees. But I am concerned that the landing gear are not strong enough to withstand 100mph directly into solid asphalt. Faulty design?
                    • AceMigKiller
                      Insta: Check5_Av8r
                      • 175
                      Yeaaa looks like he never really had positive control of the model. Rammed it right in at full throttle too - Go big or go home!
                        • 8756
                        Man, that thing was in the air for 20 seconds. In Canuck bucks, that's $3000.00/min. Appears to be Taiwan or China. It's only reasonable to think that since they got it first, someone there would be first to crash one.
                        PS. A "pre-flight" or two or three may not have helped here. He may have been in waaaay over his head with this model - likely just didn't know what to do with the sticks when it was coming down and back towards him.
                          • 8756
                          That just sent a chill down my spine.
                          BTW, I still have and fly my RAAF V1 F/A-18. It's got a noticeable lean to one side from a heavy duty repair to one retract, but in the air, you can't tell. (Biggest gopher hole dirt mound I've ever seen.)
                          • Vic
                            • Sep 2020
                            • România
                            Hi, Mig -29 is made from hi density foam?
                            • Skosh25
                              • Mar 2019
                              • 177
                              • Denver
                              True. I was going under the assumption people wouldn’t attempt to fly this without the skills/experience needed. Clearly that’s not the case and we’ve seen it over and over in this hobby.
                              • vdanger
                                Major Danger
                                • 144
                                • Oswego, Il
                                Apparently not high-enough density!
                                Super Airliner, Corsair, Viper, BAE Hawk, L-39, A-6, PC-21, B-25, T-28, GeeBee, Wildcat, Stinson, F-16, F-4
                                  • 8756
                                  Yup!
                                  "But that's a real nice airplane. One that I've always wanted. I've been flying my Apprentice with SAFE select for months now and I'm real good at it. I'm ready. I'll even get my buddy to build it and set it up for me 'cause he's been in the hobby for decades. It's going to be so great. I'm so excited."
                                  (Later that month and the CC charges just arrived ........................... )
                                  "I QUIT!"
                                  • sfcfury
                                    • Mar 2019
                                    • 490
                                    • Baton Rouge, La
                                    That'll buff out....
                                    • FLYBOY777
                                      • Aug 2020
                                      • 18
                                      Well they are already tearing them up guys and we havnt even gotten the pleassure of building ours yet lol. https://youtu.be/U27tP40nabg
                                      • Fett vision
                                        • Mar 2020
                                        • 3
                                        Honestly that first crashed looked intentional, no panic, silence as it was going down and the silence after. Not too mention it looked perfectly placed.
                                        This one appears to be a real wreck
                                          • 2693
                                          https://youtu.be/if95iHaSi8M
                                          I've seen so many spectacular crashes of large planes/jets on videos at this field in the last few years, must be "Crash Central", and I've never flown there, so how are they doing this without me!
